Question about Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive
Hello, My name is Cornel from Romania. I have a WD Passport, and right now is not any more rocognizable. I have windows 7 on my laptop. Can you give me some advice? Thanks, Cornel
  • Western Digital Master
  • 27,725 Answers
Fist clean your computer of dust using a fine air blower from a compressor specifically around your central processing unit making sure there is no moisture in the air line
as dust will cause a lot of static which will make a computer overheat and cause lots of problems
then test your power supply unit PSU
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive one bad lead will cause a computer to shut down
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
then you have a dirty hard drive give?the hard drive?a firm tap on one side to free up the read arm
then click start?run type?cmd then type?chkdsk/f which will automatically fix any corrupt files on your hard drive then defragment your hard drive
you have to keep?a computer very clean & free of dust ?and? give it regular?maintanance
good luck with this
Posted on Sep 08, 2010
WD Passport write protection removal
click start click to open on my computer you should see your usb drive E: right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
hope it helps
Apr 14, 2012 | Western Digital My Passport Essential...
WD Pasport USB Storage. Light goes on whirring sound but does not show connection to laptop with windows 7
Once connected to the computer via cables or wireless signals, the passport storage device is recogniseable from the list of devices added. Search from the computers storage devices area to ascertian that devices as successfully added. Also attempt to store data on the device to ascertain functionality.
Feb 06, 2011 | Western Digital Passport WDXML800UE...
I tried to format my 500gb WD passport essential with exfat using windows 7 for my mediastar pvr . Now neither pvr or windows 7 can see the harddrive
Windows 7 does _NOT_ support 'exfat' drives, as you have found out.
You can "format" the drive, to use 'FAT32' or 'NTFS' file-systems.
Dec 27, 2010 | Western Digital My Passport Essential...
Can only see one WD Passport 320GB drive at a time.
This is most likely a classic case of them trying to occupy the same drive letter. If you open disk management Start > Run > type 'diskmgmt.msc' and you should see them both there - One with a drive letter and one without, simply right click on the drive which doesn't have a drive letter and select 'change drive letters and path...'. Change the drive letter to something you know doesn't really get used and they should both appear in my computer.
Hope this solves your problem.
Jan 12, 2010 | Western Digital Passport 320GB External...
How to format WD Passport 1TB to FAT32 I have used WD external 500GB passport drive with my samsung 1080p9 dvd player successfully WD 1TB passport drive is not recognised by dvd player
Plug the drive into your PC.
Right Click on My Computer (or Computer in Vista/Windows 7) and select Manage.
Click on Disk Management.
Right Click the Volume in question and select Format. Select FAT32 in the options.
Dec 24, 2009 | Western Digital My Book Essential Edition...
I forgot my password how can I open WD passport?
This one way for unlocking your WD passport but assume you will lost your data
Download wdsmartwareupdate here : http://www.wdc.com/wdproducts/wdsmartwareupdate/
Download instructions :
1- Locate you WD disk entry, click on Windows or Mac according to your operating system.
2 - Click on Download now link at the bottom and download the soft.
Unlock instructions :
1- extract the zip file you've downloaded en run the.exe.
2- select Continue to update and accept Licence Agreement.
3 - Next select Update Firmware
4- Check the check box "I understand ......" under Warning section, a button "drive erasure" will appear.
5- Click on drive erasur button
6- Wait until the end of the process and quit
7- Unplug/turn off the passport and plug it back in. Your WD passport is unlocked
Dec 16, 2009 | Western Digital Passport WDXML800UE...
How do I completely remove the WD Sync software so I can use my 500GB WD external hard drive for manual copy-and-paste
Assuming you are using XP, Vista, or 2000 you can format it as a NTFS drive. while a lt of folks do not like Vista, this is one area where it really shines.
Plug in your WD PASSPORT.
Bring up the START menu -> right click COMPUTER-> select MANAGE -> select STORAGE ->select DISK MANAGEMENT.
Find the dive -> select/highlight the WD PASSPORT -> right click and select FORMAT. make sure to format as an NTFS drive. Depending on the size of the drive this might take a while - so go have dinner and a movie.
Jul 01, 2009 | Western Digital WD Passport 250GB Portable...
WD Passport 160 won't open
Before deciding if you have to check your computer or the disk, you might want to try this pasport on another laptop. If the same problem occurs, change the USB cable with a new (short) one and see if the problem is still there. If it is, then the drive is fried. You may want to take the disk out of the passport, hook it onto a desktop system using the sata bus of the drive and try recover programs like recuva or similar to retrieve the data.
May 11, 2017 | Western Digital Passport 160GB External...
WD My Passport Essential 250GB USB2.0 is not working in WIn 98SE
Try using a Usb 2 cable "The one that came with the WD My Passport " And put it directly to the PC...
In some cases, Like mine, I used an extended cable + the cable that came with the "WD My Passport" and i got the same problem ..
So i simply removed the extended cable and put the put "WD My Passport " directly to the PC with its own cable and the problem was solved to me ..
Samer.F
Dec 26, 2008 | Western Digital WD Passport 250GB Portable...
Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive Logo
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
