I Know The speakers work because the radio and tape player are fine. The records, however, you can only faintly hear on full volume. I followed the instructions about removing the plastic shield from the needle etc. Can you tell me what is wrong? What I should do? It is more than 90 days since we bought it. thanks, kathy
    Novelist:
  • 169 Answers
Hi Kathy, record players put out a very low level signal, you need a phono input stage for the amp to handle this input. If your amp does not have a phono input, many new amps do not ( check your instruction manual) .. then you will need to buy a phono pre amp which will match the record player to your amp. You can get this from your dealer.
Hope this helps
Thanks for using FixYa
Posted on Sep 08, 2010
I have a Magnavox stereo console: Astrosonic Series. The record player was playing fine until a month ago. The volume is now so low you can hardly hear the record playing
Since the volume of the radio seems to be fine it is doubtful that the amplifier is malfunctioning. I will check the stylus to see that it's fully seated and examine the wires in the tonearm that connect to the cartridge. If they seem okay then I suspect the cartridge may be bad
Mar 02, 2015 | Audio Players & Recorders
Hello,can any one help.i have a technics su-x955 amp that has has finally after mant years has packed up.when i power up i hear the usual click sound in the amp and all the other separates fire into...
If you hear something faint this would not be a fuse issue.
NEVER USE MAXIMUM VOLUME FOR TROUBLESHOOTING.
Turn the volume control to something medium.
The errant switch, control or condition may change and you will suddenly release the
amp's full power and possibly destroying your speakers. If a signal isn't audible at 1/2
volume it's probably not there.
Carefully examine the front panel for clues like a misplaced Mute or Tape Monitor control
or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or
'dead' spot through idleness and is causing your symptom. Turn the POWER OFF and operate
every control throughout its range a number of times, especially rarely-used ones like
Tape Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
May 08, 2011 | Audio Players & Recorders
I have a set of SUN-115H speakers that has a volume problem. When testing with DXDIAG, you can hear the sound but it is very faint even with the volume knob turned to full. Any ideas? ? ?
Is the power to the speakers correct? Since these are computer speakers,have you checked that the volume on the computer is turned up all the way? Have you tried the speakers on another computer or portable radio of something?
May 06, 2011 | Sun -115H Computer Speakers
The volume on my coby 600 mp3 player is very very low. i can only hear very faint sounds from the music file and most of the radio stations, although a couple of radio stations come in at a volume i can...
There could be multiple reasons for this. Is the volume at maximum? Were all audio hardware fully plugged in? It is possible the audio jack for this device may be worn down or damaged.
After looking at common opinion regarding this device, it would seem that a lot of people had complaints about it having low volume, perhaps this is a defect from Coby.
Mar 29, 2011 | Coby Audio Players & Recorders
Low to no volume output from Integra DTR-5.2 receiver
most higher end integra's have a input level adjusment or input selection for each and every input. Perhaps you are not on the correct input, go to onscreen programming and check out the input level and input select - also try the tape in another input like tape 2 or cd. It will not hurt the receiver for a test. Also, if you are using the cheap cables from the manufacturer - try a pair of cables that you know work or go by some. BTW, you don't need to spend $40 for cables order them online through amazon or other store. Gold / sliver plated oxygen free are best.
Jun 30, 2009 | Integra DTR-5.2 Receiver
There is a problem with my Sony icf-sw7600gr's speaker,it is not working (there is a faint volume however). Ear-phone works fine. What has happened to my speaker? Jack, Ireland
Seems speaker voice coil is not working due to stiffness and its irreparable. You should replace speaker of radio as per following part number..
1-529-942-11 SPEAKER (7.7cm)
Available in Part Store.
Apr 03, 2009 | Sony ICF-SW7600 AM/FM/SW Radio
Nokia 1208 - I can't hear what folk are saying
ur speaker phone is not working fine try to replace it or check it with your voice recording so it will confirm that u need to replace it or not
Mar 04, 2009 | Nokia 1208 Cellular Phone
Kenwood KDC-BT838U -- Low audio on incoming phone calls only.
Patrick -
I have the reverse problem.  Callers can hardly hear me. I saw a setting in the headunit that allows you to specify where the audio plays for incoming calls.  You can choose the Left Front Speaker, the Right Front Speaker or Both.  Check the manual and make sure its set to both.
Regards, Charlie
Feb 02, 2009 | Kenwood KDC-BT838U Car CD Player
No sound is being produced from the cd player unit. I get sound from the radio receiver and the tape deck. Also, when the CD player is on and the volume is turned up to the max, I can hear the music very...
Try looking for the reset button usually a little pin button like the ones on digital wrist watches hard to notice. If this is a home stereo are you sure the tape monitor button isn't on?
Dec 01, 2008 | Audio Players & Recorders
My speakers are working, and i can hear them very faint but i cant seem to hear music at full volume
1-try another media(other music source).
2-disconnect your speaker cables and reconnect it again..
3-bring an a contact cleaner from radio shack and apply it over volume control.while you are moving it forward and backward.
also apply some spray in the socket where you plug your speaker jacks
Jul 01, 2008 | Audio Players & Recorders
 Grubhead
Grubhead
