Question about Maytag Dishwashers
I need a wiring diagram to troubleshoot a non-working Dishwasher (Maytag DWU9200) The cycle doesn't advance, and none of the loads function when the timer is advanced manually
I had the problem years ago on a Maytag DWU9200. The problem was that a tiny wire was broken on the motor that is running the timer and the timer was not working. I had to replace the complete timer assembly. I got an electrical schematic with the new timer.
This has now worked for 5 years...
Today the float for the float switch was stocked, preventing the water to fill the dishwasher during the cycle. I moved the float up and down several times and it works now.
JP.DHD@comcast.net
Posted on Nov 05, 2010
My dishwasher is a year old and the buttons don't want to work right if I push on the cycle before it will come on but wont run that cycle what should I look for
your computewr panel is shot...i purchased this sAME MODEL AND LUCKILY i PURCHASED A 4 YR EXTENDED WARRANTY ON IT..BECAUSE IT HAS BEEN NON FUNCTIONING MORE THAN FUNCTIONING..:(..WONT BUY THIS MODEL AGAIN.
Oct 08, 2014 | Maytag Dishwashers
It wont start. the hi temp and heavy button are the only buttons that come on
OK I am not an expert but I have spent the last two weeks learning about and fixing my dishwasher! Hopefully I can save you a headache. Try the following:
* Flip the switch off and on in your breaker/circuit box. May reset your washer.
* If that doesn't work, try running diagnostic/reset cycles by pressing heated dry -normal- heated dry or heated dry-sanitize-heated dry in sequence. If the cycles run fine, you will rule out a power, latch, motor/drying issue. It also may (hopefully) reset your system.
* If normal function still does not resume, make sure your power (from the breaker box) is turned off and unscrew (with a star-shaped screwdriver bit - check your car emergency kit/toolbox, you may find you have it) and open the front button control panel and check all connections. Try carefully unplugging and replugging wires and look for any corrosion/moisture on the circuit board.
* If that does not work, test the circuit board by unplugging the green ribbon cable from the control panel, reassembling with the ribbon cable unplugged, flipping your circuit back on and then closing the dishwasher door. If the drain motor runs, it will show you that there is still some function with the circuit board. Although it doesn't rule out the circuit board completely, it will point to a most likely control (button) panel issue and try replacing that. If the drain test does NOT run, it may be the circuit board that needs to be replaced.
Hopefully some of that helps!
Jul 08, 2012 | Maytag 24 in. MDBH950AWS Built-in...
Older model dishwasher doesn't drain at the begin of cycle or turn on water.The timer seems to work all the way through turning off and on at each function and the fan seems to work alright.
Hello, welcome to FixYa. I understand you have a Maytag dishwasher based on your post, correct ? If so could you post a reply with the model number of this machine and I'll see what I can find for you. There were some recalls on Maytag units a while back, but I don't want to speculate...it's better to wait for the model number, in fact a serial number as well would be even more beneficial. I look forward to your reply and assisting you going forward. I hope you can appreciate there are many scenarios even within the "Maytag" brand. Thank you. Regards, Macmarkus :)
Sep 24, 2011 | Maytag Dishwashers
I have a Bosch SHE4AM15UC Dishwasher that short cycles. After about 2 minutes it quits and the clean light comes on. The unit doesn't fill with water and the soap dispenser does not open when this...
they will send out an engineer not supply you the part while still under warranty if you fit parts under warranty you will in validate it get the engineer out.
Mar 03, 2017 | Bosch SHX65P05UC Dishwasher
Brand new Matytag MDB7749AWB Dishwasher does not work correctly. As soon as the power was turned on, all three cycle indicator lights ('Wash', 'Dry', and 'Clean') came on and always...
Try putting the unit into a test mode. This my clear your issues otherwise call for service.
One of two ways to do this.
In standby (no lights) Press the combination of buttons:
hi temp wash > sanitize > hi temp wash > sanitize > hi temp wash
All lights will come on and the washer will run a test cycle anywhere from 5 to 10 minutes.
If that button comb doesn't work use:
heated dry > sanitize > heated dry > sanitize > heated dry
May 27, 2011 | Maytag Dishwasher
I have a kenmore 665-15684. I have clear standing water in the dishwasher and doesn't seem to drain. No lights are on (or blinking) on the control panel and none of the buttons seem to work on the...
It is very likely the computer has failed.
Try to empty the dishwasher with a small container and try it on a short cycle to see if it starts the cycle.
If there is no action then it is time to decide if you want to replace the computer. See item 6 in this diagram.
Hope this helps.
May 16, 2011 | Kenmore Dishwashers
Maytag DWU6602AAE. My Maytag dishwasher (14 years
SOUNDS LIKE A TIMER PROBLEM. YOU MAY WANT TO PRICE A REPLACEMENT TIMER. AND PRICE OUT NEW DISHWASHERS. GOOD LUCK!
Feb 25, 2010 | Dishwashers
The bottom rack has a broken moveable dish holder
That would have to be purchased from the manufacturer or one of the appliance parts suppliers. Most should be able to get one for you or contact the store where you purchased the unit.
Good luck,
Gilshultz
Dec 03, 2009 | Maytag Dishwashers
Maytag Dishwasher Leak
HI. this is a inlet assembly issue. The water inlet valve can be identified by the water hoses connected to it. One hose will lead from the valve to the pump/motor assembly in the center of the dishwasher. Check that the hoses are securely connected to the valve and that there are no kinks in the hoses which could restrict water flow. There are two wires (four, if it has two solenoids) connected to the water inlet valve. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Use a continuity tester or multimeter to test for continuity. Set the multimeter to the ohms setting X1. Touch one probe to each terminal. A reading of infinity indicates a bad solenoid that must be replaced. Different brands and models will have various measurements, but the valve should show some resistance if it is functioning properly. If your valve has two solenoids, test the second one in the same way as the first.
If the solenoid is working properly, but water leaks through the valve even when the dishwasher is off, then the valve itself is the problem. Debris may be preventing the valve from closing. If the valve cannot be cleaned, it will have to be replaced. The valve can also fail mechanically. So even if it passes the electrical test, it may still require replacement. If you have ruled out all other possibilities, go ahead and replace the valve.
***(((NOTE-- It i possible that the valve housing has cracked as well. make sure that the hoses are connected properly during your testing. If there are no hose issues, this will be a defective valve assembly)))
Sep 12, 2009 | Maytag MDB6000 Dishwasher
Maytag Dishwasher: MDB/C-2 Suddenly Stopped Worked
I have had this dishwasher since 2003 and haven't had a problem whatsoever. This is one of the best dishwashers I have purchased out of the 4 I have had.
Jul 21, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Dishwashers Logo
296 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
