Question about Clarion VX409 Car Video Player
Clarion password reset - Clarion VX409 Car Video Player
I want to reset password for Clarion NX-208...
Here is a youtube video that may prove useful: Clarion NX310 Unlocking process and password
If that does not work for you, then I recommend contacting a local car audio professional or Clarion customer support directly here:
https://clarion.com/xe/en/user-support/inquiry/contactus
I trust this information proves beneficial.
May 18, 2017 | Clarion Car Audio & Video
Clarion nx500 parental control reset
Unknown.
Recommend contacting a local car audio professional or Clarion customer support directly here:
Sep 01, 2014 | Clarion NX500 Car Video Player
I have a clarion double din max675vdii and it is locked but i have the right code now but i cant get the incorrect code reading to go away so i can type it in...any help??
You may need to drive around for about 20 minutes. Mine is locked out since my battery had died on my car, and the people I bought the car from don't know the password. So about every 20 minutes or so of driving it lets me give one try. Clarion says the only way I can reset it without the password is to get it uninstalled and pay for shipping all the way across the country to their office where they will reset it, and pay for shipping all they way back here again, and then pay for the uninstall and reinstall fees at the audio shops here. Thats way too much money and effort for this stereo.
Apr 16, 2011 | Clarion MAX675VD Car DVD Player
I just installed a clarion vx409 and i set a password, i had to disconnect the battery and it asked for a password and it didnt work... now my system is locked and i need to unlock it can you help me
Yes I just had my problem solved today it is actually in your manual. But I will just give it 2 you the password I was giving 4356. This will reset it back to 0000 password. I hope I was able to help a lot people with the same problem. :)
Jan 27, 2011 | Clarion VX409 Car Video Player
I did not creat a password for my Clarion VZ400. The system is now asking me for a password in order access the system. Is there generic password to the system ? HELP !
Try '0000' and if you locked it by trying too many times, take a pen and press the reset button which is actually the small red light under the AUX in put once you reset it, it will turn off and turn on, when it turns on power it off by holding the SRC button which is the middle big one. Then it should allow you to enter the password and try '0000' it should work cause I have had the same problem and figured it out. Also if its still locked reset it a few more times in that order it'll work.
Jan 03, 2011 | Clarion VZ400 Car Video Player
I changed the battery on my truck and the stereo went into enter password and dont know what it is and now it is locked
Assuming you have tried standard default codes 0000, 1111, 1234...
Clarion models keep the security code in non-magnetic memory inside the unit.
The only way to reset is to return it to clarion to have it cracked and reset using their proprietay software, and/or replace the flash memory chip.
Clarion authorized service centers cannot even do it (like Kenwood can)
If it says CODE, you can attempt to enter a code. If it says LOCK - after 7 attempts, you must wait 15 minutes.
Hope this helps
Regards
Dan
Jan 02, 2011 | Car Audio & Video
I locked myself out of my vx409 and it says password lock and has a lock symbol is there any way to reset the keypad?
If you power on the unit, wait for it to display the "password [lock]". Then hold down the power button and menu button simultaneously, it will bring the keypad back up. But if you don't know your password and the default of 0000 doesn't work, you have to send it in to Clarion (for a nominal fee, I'm sure).
Jun 29, 2010 | Clarion VRX485VD Car DVD Player
Unlock code for clarion in dash dvd playervrx485vd
if you leave it unpluggede for a couple hours from the factory connection it should reset back to factory setting.... it turns off your anti theft tho but you can type your password *** many times a you need.... hope this helps
Dec 10, 2008 | Clarion VRX485VD Car DVD Player
Clarion VX409 Car Video Player Logo
512 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
