Question about DeLonghi Pinguino PACL90 Portable Air Conditioner
No longer cooling; water that drains from unit has an oily substance. Is this the refrigerant?
  • DeLonghi Master
  • 43,501 Answers
No it isn't the refrigerant but it is the oil that is mixed with it and it means that you have a leak in the system...
heatman101
Posted on Sep 08, 2010
There is a thick sticky black substance leaking from my refrigerator for the past two weeks on the left front side. Frigidaire model p/n 241543966
Hello Melanie;
My name is Peter. I am a retired field service technician.
You do not have a refrigerant leak. Refrigerant is clear in color.
You have a water leak. The black sticky substance is either coming from your bottom condenser cooling coil or just general dirt under your refrigerator that accumulates over time. The coil under your refrigerator collects dirt as well.
You need to pull the refrigerator out so you can get behind it.
Unscrew the bottom back cover. Inspect for the water leak source. Your condensate drain pan may be leaking or dislodged.
The water line to your ice maker may be leaking.
Your water supply shut off valve to your refrigerator may be leaking.
Nov 01, 2014 | Refrigerators
Scottsman ice maker putting black oily substance in the ice. What needs to be checked??
you need to call a refrigeration mechanic because the worm gear seals and transmission needs to be reseald.
Jan 24, 2014 | Scotsman Modular Flaker Ice Machine Water...
Oil in water
Sometimes that is a sign of a sealed system leak. If that is the case unit will start having cooling issues. Most of the time repairs cost more then replacements.
Aug 17, 2012 | Heating & Cooling
Liquid leaked out know fridge isnt working. model dcb412bls
When you say liquid, are you meaning an oily substance or water. Since it isn't working, I have to assume oily substance which could mean either the cap or freon. If it is the capactor that has blown up then it is worth changing (change the contactor at the same time). If it is the compressor leaking freon, then it is usally not cost effective to change out and recharge the system and would take a professional to do.
Aug 28, 2011 | Danby (DAR604BLS) Refrigerator
No Cooling. Everything seems to be running. Tubing at cooling coil seems to have an oily substance on it.
You have a leak and the refrigerant leaves the oil behind when it comes out...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
May 31, 2011 | Heating & Cooling
LG la125hv mini split not cooling; one of theoutside lines have thin ice on it. Small leaking from the inside unit. Water and oily substance as well
You have arefrigerant leak and the unit is low on charge....you will need to have the leak fixed and the unit recharged by a professional...
heatman101
Aug 28, 2010 | LG Heating & Cooling
My kenmore window unit AC started blowing a white smoke like substance. It seems to be cooling fine. What is this and is it a concern?
The two things it could be, #1 - evaporator leaking refrigerant - unlikely if unit is still cooling o.k. because window units do not hold a lot of refrigerant and if there is a leak bad enough to blow smoke it would have stopped cooling by now. #2 - the humidity is high and the unit has cooled the air right at the discharge down below the dewpoint, a common occurence in window units and automobiles due to the short duct distance from the evaporator to the air outlet whereas with central air systems having longer duct systems the air gains more heat before being discharged into the room.
Aug 26, 2010 | Kenmore Heating & Cooling
Dometic refrig not cooling but found yellow oil at service panel
if you find an oily substance its most likely freon. this looks pretty new so i would say you have a bad soldered joint on a copper to steel line. theses usually ar fot the high side. where the condensor coil or loop runs either to underref or up in the ref walls
Aug 01, 2010 | Dometic RM2652 Refrigerator
Odor emitting fro refrigerator
I wish i did know what exactly the problem could be from. One possible cause of this oily looking substance is that you have a compressor line leak somewhere within the walls of your side by side. you may want to look into your warranty to see if this an be covered if under warranty. there is a product however that is a charcoal based air purifier for fridges it is called fridge aid. and can be purchased at a cheap cost.hope this helps
Thanks
Oct 12, 2009 | Kenmore Refrigerators
Heating & Cooling Logo
103 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
