Question about Candy CNW136 Front Load Washer/Dryer
Candy CNW 136 washer dryer not spnning - Candy CNW136 Front Load Washer/Dryer
  • Candy Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 08, 2010
Candy Washer/dryer Stalls
Have you checked the drain hose connection? Make sure the bung is clear in the trap
Aug 07, 2012 | Candy CNW136 Front Load Washer/Dryer
How do I remove drum bearing from Candy CNW136 WASHER / DRYER
How do I remove bearing from Candy CNW136 washer/dryer.
Thanks
Reply to rsparling@manutec.ie
Jan 20, 2011 | Candy AQW130 Front Load Washer / Dryer
Washer dryer nova cnw 156 does not dry
Sounds like your problem may be with the heating coil.
If you plan to try to repair the problem yourself, then the first thing you want to do is unplug the dryer from the electric.
Remove the back of the machine and try to locate the air duct going from the blower to the drum. Normally inside the air duct you will find the heating coil and the thermostats/thermistor.
Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the saftey of overheat from the machine.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
Hope this helps
Oct 19, 2009 | Candy Dryers
Washer/dryer problems
If you can locate the filter, remove and clean it.
They are usually found at the bottom front, behind a removable plastic panel.
Plz rate my solution,
Thanks.
Jan 13, 2009 | Candy CNW136 Front Load Washer/Dryer
Water not pumping out
HI
I had a similar problem which I solved by cleaning the filter which had a blockage. It then worked fine. Hope this helps
Jamie B
Aug 14, 2008 | Candy CNW136 Front Load Washer/Dryer
Candy Washer Dryer CNWD 136
18 months isn't enough for a bearing to die so I guess that perhaps a shock absorber snapped or got disconnected from the drum or machine casing. It is not an expensive part and can be replaced by experienced DIY guy. Perhaps the bolt and nut which hold the shock absorber haven't been tightened properly in factory so in time they got loose completely before falling off. I'm just guessing. Call a repairman to take a look at it and don't use it before it gets repaired.
Apr 22, 2008 | Candy CNW136 Front Load Washer/Dryer
Door lock , wont light up , therefor wont start washing.
Click on "Candy" (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
You can also go to "troubleshooting" above, you are sure to find some solutions. And dont forget to rate me on this great site.
Jan 07, 2008 | Candy CNW136 Front Load Washer/Dryer
Candy CNW136 Front Load Washer/Dryer Logo
106 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
