Question about Rangemaster 110 (Gas) Kitchen Range
Oven ignites but the ignition continues to click
  • Rangemaster Master
  • 43,501 Answers
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Posted on Sep 08, 2010
  • Desy99
    Desy99 May 08, 2014
    But if I disconnect the wires as you say then the solenoid will not open and let me light the gas manually
Oven,broiler won't light
The igniter is the most commonly defective part for a gas oven that won't turn on. The igniter has two main functions. First, the igniter draws electrical current through the oven safety valve to open it. Second, the igniter gets hot enough to glow and ignite the gas in the burner assembly. If the igniter gets weak, it will fail to open the safety valve correctly. If the valve does not open, the oven will not heat. To determine if the igniter is defective, observe the igniter when the oven is on. If the igniter glows for more than 90 seconds without igniting the gas flame, this indicates that the igniter is too weak to open the valve. If the igniter is weak, replace it. If the igniter does not glow at all, use a multimeter to test the igniter for continuity. If the igniter does not have continuity, replace it.
Kenmore Oven Won Turn on
Jan 20, 2016 | Kenmore Kitchen Ranges
Oven and broiler won't work surface burners ok
Troubleshooting Why Your Gas Oven Won Ignite or Heat PartSelect com
Oven igniter
Igniter Knob replacement.
Jan 10, 2014 | Roper FGP215KQ Gas Kitchen Range
Svd48600w clock out can't turn on oven, or down draft fan
see this causes and fix it: God bless you
IGNITER
If your gas oven is not heating, the igniter is the most likely the cause. This is a simple gas oven repair. To check the igniter, remove the storage drawer and the bottom of the oven (only if you are working on the bake burner). Now turn on the oven and observe, from a distance, the burner that is not heating. In a minute or so the igniter should glow red. If not, unplug power from oven. Then unplug the igniter and using your ohmmeter ,check to see if you have continuity between the two wires going to the igniter. If you don't have continuity, replace the igniter. If you do have continuity the igniter is still the likely problem, If you turned on the oven and the igniter did glow red, the igniter still is most likely the problem. This video will walk you through properly testing an oven igniter. You have to have an amp meter to check for sure, but I would not suggest buying an amp meter just to check this because 99% of the time its going to be the igniter. So I suggest just replacing the igniter. For those of you that already have an amp meter, clamp the amp meter on one of the wires going to the igniter then turn on the oven. If your igniter is round, the amp meter should read 2.6 to 3.0. If you have a flat igniter then the amp meter should read 3.3 to 3.6. If the amps are not in this range, the gas valve will not open to release gas to the igniter. To repair this, replace the igniter.
BURNER CLOGGED
This is another simple gas oven repair and it's one thing you may need to check before you change any parts. The burner has a lot of small holes that connect the flame all the way around the burner. If one of these small holes is stopped up, the burner will not light properly. To repair this, simply use a large needle or thin wire to clean each hole out. Note that this is not a very common problem but if this does fix your oven, it will save you a lot of money.
GAS VALVE
If your gas oven is not heating, the gas valve may be your problem. If your igniter isn't bad then the gas valve is the problem. This is a very uncommon failure in most ovens. But this is not a simple gas oven repair and it's best if this is changed by a professional because if the gas valve leaks it can be a major fire hazard and you have to adjust the valve to the kind of gas you are using.
Main Control
This is the last thing to check. If you have no power to the igniter when the oven is turned on the main control is the likely problem. On glowbar style igniters if you have no reading and there is continuity of the igniter replace the main control. On ovens with electronic igniters (these are the ones that click) these ovens have a separate spark control module that sends the power to the igniter. This can be difficult to check but in general if you have no power reaching the igniter the spark module or igniter module (there are many different names for this part) would need replacing.
Jul 20, 2012 | Kitchen Ranges
When oven is turned on the ignition continues to operate (can be heard clicking)
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jul 07, 2011 | Microwave Ovens
We have a 6 burner, nat gas cooktop....all unit light but the igniter clicking will not stop...unplugged it . question: all mechanics are closed is this safe gaswise?
What happens in this style ignition system is that the thermostat or electronic control switches power to the oven ignitor and gas valve circuit which are connected in series (one after the other). As power flows through the ignitor it heats and draws current (measured in amperage). Once the oven ignitor draws a specific amount of current the oven valve opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it. Power must continually flow through the ignitor and oven gas valve for gas to be released into the oven burner to create a flame. Once the set temperature is achieved the control stops all power to the ignition circuit which causes the ignitor to dim and the oven gas valve to close, stopping any burner flame. Cycling on and off continues to maintain the specific temperature the control is set for.
Jan 09, 2010 | Microwave Ovens
How do you light the oven? We turn the dial and
I take it the range is electric ignition because you say the top burners have a clicking(igniter) noise. If the top burners are electric ignition then the oven is also. The oven probably uses a hot surface igniter and that is why you do not hear any clicking. Turn the oven on and open the broiler compartment. You should see a bright glow from the hot surface igniter. If you do not see any glow there may be a grounding issue or the igniter could be bad. If you do see a glow but the burner does not come on in a few minutes then give the gas valve a tap with a wrench and see if the burner comes on. Shut it off and then back on several times. If the burner continues to light after this you may have fixed the problem. If it does not come on gas valve could be sticking or igniter is weak.
Sep 10, 2009 | Magic Chef 31000 Gas Kitchen Range
Cooker
I just installed one in my house. I found that when you start the lower (gas) oven you need to turn the dial all the way on to 500*, push the knob in (you should hear the igniters clicking), then even when you see flames coming out of the burner, continue the ignition for 10 to 15 seconds. It should continue to stay lit thereafter.
Apr 01, 2008 | DeLonghi DEBIGE 2440 Electric Double Oven
Rangemaster 110 (Gas) Kitchen Range Logo
977 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Mike Carew
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
