Question about Dell (E210882) Motherboard
Can not get computer to boot up. No Post, no signal to monitor. This a Dell 4700
  • Dell Master
  • 27,725 Answers
Replace your PSU then test all leads that are attached to your hard drive sounds like a faulty lead of some sorts then
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty because a computer has to have an end to the circuit any fulty leads will lead to no boot up
good luck
Posted on Sep 08, 2010
Green power light comes on but disk drive lights keep blinking and my screen is black on my dell dimension 4700
Remove ALL media from the machine DVD, CD, USB, etc. Check/reseat all Monitor cables. Reboot. If that fails, unplug , plug back in in 30 seconds or so. reboot, if you get a Dell Logo, Open the boot Menu and select Boot from HDD first.
Dec 23, 2012 | Dell Dimension 4700 PC Desktop
My desktop 4700 when turned on there is a buzzing soud about 6 times off/on-also the mouse,monitor,keyboard inop.monitor shows power saver on & goes off
I am going off of the assumption that the buzzing sound you refer to is actually the BIOS Post Code since your are not seeing the post check screen. With that in mind, you should reseat your motherboards memory sticks (not the hard drive, the RAM). Be sure to of course power off the computer, use a grounding strap and generally follow all safety steps for basic PC maintenance.
May 14, 2012 | Dell Dimension 4700 PC Desktop
Message on monitor says " no analog signal".
If you are getting no post display on boot up (dell spash screen, and windows loading screen):
First step is to plug a different monitor into the computer. If this works you most likely have a bad monitor. If not then it is a hardware issue with the video card on the computer.
If you getting the post screen then you may have your resolution set to high, boot in safe mode (F8 on the key board right after the post screen) and chose safe mode. once windows comes up, right click the back ground and chose a lower resolution setting.
Hope this helps
Oct 17, 2011 | Dell OptiPlex GX620 PC Desktop
Dell 4700 wont boot up
to boot up:
1.Restart Your computer Press Delete until BIOS setup appears.
2.Go to Advance BIOS setup then Boot sequence.
3.First Boot Your CD-Rom, 2nd Boot the HDD-0.
4.Save The Settings Then restart.
5)when appear "press any key to boot" then click ENTER button of your keyboard it will automatically boot.
Aug 17, 2011 | Dell Dimension 4700 PC Desktop
My dell 4700 won't come out of sleep mode, i've rebooted and changed the internal battery but still no luck
Get some canned air - 2 cans
unplug the monitor and computer.
Use canned air to blow out all the vent holes of the monitor.
Leave it unplugged for about 1 day.
Open the computer case. Use the canned air to blow out the computer. pay special attention to fans and the power supply - actuall blow the air through the power supply vents on both sides.
If you have an add on video card (not on the motherboard), remove the screw at the back of the case, and remove the video card. Reinsert the card and make sure it is tight. replace the screw.
After the day is up plug the monitor back in and use the buttons on the front to enter the monitor menu. Choose to reset or factory settings.
Hook it back up to the computer and boot the computer.
If the problem still occurs try the monitor on another computer or laptop.
If the problem goes away by hooking it up elsewhere - replace the video card.If you are not sure what type to purchase just post back model and serial of the computer.
If the problem is still there after hooking the monitor up elsewhere,
Try changing the video cable or seek rpelacement through warranty or purchase a new one. Check newegg.com for best prices.
Any doubts you can get the help of a technician through
www.thebestpcdoctor.com
Toll free: 877 407 9229
Nov 20, 2010 | Dell Dimension 4700 PC Desktop
When you first start your computer how do get it to read the disc first?
You go into Boot Menu, and set the - first boot device to CDROM.
The computer will then read what is in the optical drive, first.
Computer off, press the Power On button. Watch closely for the blue dell logo.
Looking at the bottom of the monitor screen when the blue Dell logo comes up, you will see - F2 = Setup.
At the top right of the screen you will see F12 = Boot Menu.
This screen goes by F-A-S-T!
As SOON as you see the blue Dell logo press the F12 key.
If you miss this small window of opportunity, just wait for Windows to fully load, then click on Start, Turn Off Computer, and Restart.
If Windows is not loading, then press the CTRL, ALT, and DELete keys at the SAME TIME. (Not shouting)
This will restart your computer so you can try again.
Upon entering Boot Menu you cannot use your mouse anymore, you have to use the keyboard.
The Boot Device Menu has the devices listed, and each device has a number next to it.
At the bottom of the menu, type the number that is next to CDROM, then press the Enter key.
This is Dell Support, and the main page for the Dell Dimension 4700 Service Manual,
http://support.dell.com/support/edocs/systems/dim4700/sm/index.htm
Left-click on - Entering System Setup
Should you have any questions concerning this, simply state so in a Comment.
May 03, 2010 | Dell Dimension 4700 PC Desktop
Video Card upgrade for Dim 4700 to 1920 x 1200
go to dell's web site.
http://support.dell.com/support/topics/global.aspx/support/upgrades/en/segmenter?c=us&l=en&s=gen&~ck=mn
Fill in the requested information and they will give you the details of your computer, and recommended upgrades.
Does your current card meet your needs? The 24 inch should not need any thing special other than loading its drivers, and setting up the video. You will of course be using the "D"
15 connector on this monitor and a mating video cable. These have to be purchased on their own sometimes, so make sure one comes with your monitor.
Aug 07, 2009 | Dell Dimension 4700 PC Desktop
Dell 4700 network card install
You can find all needed information on the Dell website.
Look here.
How to open your computer is explained here.
Please post some feedback
Apr 22, 2008 | Dell Dimension 4700 PC Desktop
Dell (E210882) Motherboard Logo
62 people viewed this question
Alun Cox
