Question about GE GSS20IEP Side by Side Refrigerator
How to change water filter on GE fridge model no. GSS20GEWJ Serial No. LS221464
applianceboy
  • 77 Answers
SOURCE: Water dripping on GE Fridge model TFX24ZR
check your water filter. water preasure is important in the operation of the water valves. if the filter is ok replace the valve. water filter should be changed at least once every year.
Posted on Sep 26, 2007
roadbird383
  • 40 Answers
SOURCE: Fridge Makes Cubes But No Water
Sounds like a bad water solinoid valve.
Posted on Dec 09, 2007
  • 150 Answers
SOURCE: GE SmartWater Filter - Model MWF
make sure filter is installed correctly (not to doubt you but it can happen) make sure there isn't some foriegn object or packing materialetc in the filter end. You could have a bad filter. also make sure the unit is purged well
Posted on May 15, 2008
Maytag317
  • 1136 Answers
SOURCE: how can I change the water filter on a frigidaire fridge
Hi, The filter is in the upper right hand corner of the fresh food section. Turn the filter cup counter clockwise to remove it. There will be a filter cartridge in the cup that you replace.
Please let me know if this has been helpfull or if I can assist you further
Thanks
Vic
Posted on Jul 17, 2009
MNTECH
  • 1543 Answers
SOURCE: GE Fridge - The water filter bypass plug is stuck
Should just take a quarter turn CCW to remove. You may loose a few drips of water, but the water shuts off automatically when the plug or a filter is removed. A wrench should not be needed to do this.
Posted on Jul 26, 2010
LEAKING FRIDGE
A magnitude of problems could be caused by this, you should really call someone to come out and look at the refrigerator. With that model having a ice maker and water dispenser, it could be a crack in the water filtration which is typically located in the lower read of the refrigerator. If nothing else seems to be wet on the inside of the refrigerator you can almost guarantee that its the filter and pump in the back leaking which will require a skilled professional to look at it.
Dec 08, 2011 | GE Refrigerators
Water dispenser and ice maker are not working, water supply to refrigerator is ok.
Check / replace the filter. Many fridges have a filter readily accessible from the fresh food compartment. The filter should be changed at regular intervals for best performance. A filter that is never changed will reduce and eventually stop water flow through it.
Check the temperature of the fresh food compartment near the filter. It may be "flirting" with the 32 degree mark. If it is this low, water has turned to ice - and will stop water from flowing. Bump the temperature up a tad to see if it solves the problem.
Lastly, the water supply solenoid may have failed. You didn't provide the model fridge - so I can't give specific info about it - but many fridges have one or two solenoids at the rear of the fridge for water supply and ice makers. You should hear a clicking sound from the rear of the fridge on many models when dispensing water or when the ice maker cycles on. If one has failed, you may expect to pay about $15 to $50 for a replacement - depending model.
Typical GE Refrigerator Single Solenoid Water Inlet Valve "WR57X10033"
Solenoid valve replacement is pretty straight forward. Usually all the is needed are some simple hand tools and a rag to pick up spilled water. Make sure the water supply is shut off and unplug the fridge before attempting.
If my answer was helpful - please rate it. Thanks & good luck!
Oct 05, 2011 | GE Refrigerators
GE Eterna side by side fridge Model ESS2SLGMAWW
I've got the same problem...have de-thawed everything, (this was how we fixed it before) and still can't get water to dispense. Guess another 75 bucks service call...urgggg...
Dec 27, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE MWF water filter that is dripping water into the refrigerator. Fridge is about 8 yrs old and have changed many of the MWF water filters. 1st time with this problem.
Many times fines from these filters become dislodged and plug up the filter housing. If you have the bypass plug for the filter, install it and run a couple gallons of water through fridge to flush the system completely. The install the filter again. Make sure none of the water lines feeding fridge are pinched or kinked and valve is on all the way.
RJ
Nov 30, 2010 | General Electric GE SmartWater Household...
Where is the water filter on GSS20GEWJ? This is a GE side by side.
This model number is not coming up. The 'J' on the end, is that a typo? There is no model with the 'J' on the end that I can find.
If your model is GE GSS20GEW, then the spec sheet indicates there is no water filtration system on this refrigerator. Although the manufacturer's generic blurb on it says "...fresh, filtered water...".
Here is the link to the specifications:
http://www.rainbowappliance.com/GSS20GEWBB.html#
If you're sure it has a filtration system and there is not an obvious canister shaped filter inside the cabinet then they are usually located underneath the unit on the front. There will be a round looking thing protruding from the bottom-front grill or the grill will have to be snapped out to get to the filter. I would look here for it.
If this information was useful, please select YES to the first to rating questios. Good Luck and thank you!
Oct 22, 2009 | Refrigerators
We purchased foreclosure house that has a GE fridge tpx21prx-possibly 13 years old-no info but does it need filter for ice and water use? There is no filter inside fridge-does copper line need replacing...
This model does not have a filter for the ice and water, you can add an inline filter in back of fridge water line, they sell them at any hardware store, you dont need to change copper line unless it is corroded.
Sep 19, 2009 | Refrigerators
Do we need to replace a water filter on this GE model TFX25JRBA ?
I have a problem with my refrigerator , has a funky smell and when you taste the water is funky smell too, so waht is the problem the model is tfx25jrbbww serial vt231111.
Jul 05, 2009 | GE 25.2 cu. ft. Side-by-Side Refrigerator...
WATER FILTER
All of the cabinets I have worked on have had external water filters, so unless yours is really special you will normally find the water filter located behind the fridge freezer in the incoming water supply line (typically 4 - 6 inches long 2 inches diameter). Some cabinets now have a timer to indicate a long duration, none that i have come across monitor water quality. Hope this helps.
Mar 09, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Sep 10, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSS20IEP Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
