Question about Hotpoint Refrigerators
I HAVE A HOTPOINT FZM80 UPRIGHT FREEZER. THE INSIDE BACK OF THE FREEZER IS SWELLING LIKE A BELLY. THIS IS FORCING THE DRAWERS OUT AND THE DOOR WONT SHUT. ANY IDEAS?
Won't help you now at this late stage but I also have a Hotpoint FZM 80 freezer. The top drawer, then top 2 started defrosting slowly. Freezer overtemp light never appeared but eventually I thought I was going to have to buy a new one so having lost nothing I decided to have a look. Took the drawers out and the back panel is held in with about eleven 8mm hex head screws. Had a little difficulty pulling the bottom part of the plastic back away from the freezer as it was stuck with ice.
I suspect this is what was happening with yours and the ice was expanding, pushing the back out.
The ice had formed from the bottom half of the condenser to the bottom of the fridge, blocking the hole where the moisture should drain to then evaporate on a tray above the warm compressor. Buried deep in this ice was the temperature sensor. Thus the freezer stopped cooling because it thought it was very cold already. Now defrosted with a hairdryer it's all OK again.
Shame Hotpoint didn't put the sensor higher in the freezer.
Posted on Oct 13, 2017
  • Hotpoint Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 11, 2010
Hotpoint fzA50 freezer red light on but still freezing food
This is not abig problem , but you may want to do a general cleaning and maintenance on it. Unplug it for about a minute or so. If it still persists, call your mfr and see what they say.
Mar 02, 2013 | Hotpoint 6.92 cu. ft. / 196 liter Upright...
Inside rear panel bulging
Unplug the unit and take out all the drawers and remove the back (behind the drawers) panel carefully. (This back panel has foamy thermal insulation behind it and this will be probably be enmeshed with ice - you may have to wait awhile for this ice to melt before you can remove the panel, even after you have unscrewed it.
When you have got the back panel off, you will see a large solid block of ice, probably halfway up the cooling coils, right down to the bottom of the exposed space. You have to melt all this ice (I used a hair dryer to blow warm air onto the ice (have towels and a bucket ready to mop up the melted water, otherwise it will run over the floor. When you have melted all this ice, you will see a drain hole at the bottom of the exposed space. This will have ice in it and it must be cleared.
Then replace the back panel and all should be OK.
The panel bulges because ice/water is accumulating behind the panel, water, when it freezes, expands, forcing the panel forwards.
I reckon it's a Hotpoint Design fault. What is supposed to happen is that during the heating cycle, melted ice drops down from the cooling coils and down the drain hole onto a plate over the compressor unit, where it evaporates. BUT, during the cooling cycle, a fan circulates cold air from the cooling coils, through the entire unit, which includes the chamber behind the panel that is below the coils. Thus this chamber gets cold (-18 deg.C) so that water dripping down during the heating cycle is frozen before it has a chance to fall down the drain hole.
I now defrost in this manner every six months or so. Sadly, very sadly, Hotpoint, like other white goods manufacturers (Baxi Potterton boilers for instance) do not reply to my enquiries.
Hope this helps.
Feb 19, 2013 | Hotpoint 6.92 cu. ft. / 196 liter Upright...
RED HIGH TEMPRETURE LIGHT IS ON.WHAT IS THE USUAL
if the temperature rises above 30 degrees then this is to let you know that there is a problem.
it could be one of these problems:
dirty condender
condenser fan not running (if available)
freezer fan stop working
compressor valves bad
lost of freon (under charge)
defrost heaters not working
bi-metal t'stat not working
timer bad
if you need more help let me know
Mar 27, 2010 | Hotpoint 6.92 cu. ft. / 196 liter Upright...
Hotpoint FFA75 Fridge Frezzer. Freezer door not shuting when drawers are in but does when drawers are out. It's as if the back of the freezer has expanded.
This could indicate that your defrost cycle system is nor working and frost(ice) is building-up on the cold coil in the back of the freezer compartment. This will definitely expand the back plate and the drawers wont go in completely. You need to have the defrost system checked: either the timer, the defrodt coil, or the defrost thermostat. Goodluck, Macgivor
Jan 02, 2010 | Hotpoint FFA60 Bottom Freezer Refrigerator
My Upright freezer Hotpoint Product code 755703
My FZA 84 regularly has to be defrosted as it overheats.We do this by taking off the back panel - as shown by the Hotpoint service man here in Dublin. We use lukewarm water or a hairdryer to defrost the buildup of ice. Why its building up is anyones guess.The repairman suggested we might be leaving the door open but we certainly aren't. I'm very disappointed with the product and I wouldn't be purchasing Hotpoint again.
Jul 21, 2009 | Hotpoint Freezers
Hotpoint FZA80 freezer: water leaking
There's a drain hole inside the freezer in the bottom of the back wall ;probably is clogh .Put hot water into it to melt the ice and then blow it with air pressure;keep it clean pouring bleach throught it every 2 or 3 months.
Jul 18, 2009 | Hotpoint 6.92 cu. ft. / 196 liter Upright...
HOTPOINT FZA80 FREEZER
Red light is indicating temp is too high, this can be caused by a variety of reasons.
You need to call an engineer to sort the problem out.
Jul 28, 2008 | Hotpoint 6.92 cu. ft. / 196 liter Upright...
Hotpoint FFS70 fridge problem with draws.
Not sure which drawers you are talking about BUT have you tried switching over the two crisper drawers? They are not interchangeable, i.e. there is only one way the will fit inside the fridge.
Jun 12, 2008 | Hotpoint FFS70 Bottom Freezer Refrigerator
Top half not freezing
If this is not a frost free unit , it probably has a freon leak. This is usually not worth fixing in a deep freeze. If it is a frost free unit the fan could be bad. This is an easy repair.
Mar 26, 2008 | Hotpoint 6.92 cu. ft. / 196 liter Upright...
Refrigerators Logo
114 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
