Question about Akai LCT2721AD 27 in. LCD Television
Akai lct2721ad The TV was working fine when we turned it off and now it won't come back on. No red lite. The tv has had very little use. Is there a master power switch that might be tripped. thank you , chuck
  • Akai Master
  • 8,457 Answers
Check the power source?Yes.Try tv unplug,replug it back an hour later.The tv now resetting it back to factory setting.The tv should work now.Not,than the power supply board is dead.That the board,where the power a/c cord plug into.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacemrnt.
Posted on Sep 08, 2010
Akai LCT2721AD TV just has a red light on. it wont power up at all.
I had the same problem with mine. I took the back off of it and found 3 blown 1000uF capacitators in the power supply. I replaced them and now it works fine. Cost me about $1 compared to $100 at the shop.
Nov 20, 2009 | Akai LCT2721AD 27 in. LCD Television
TV will not start easily. Akai LCT2721AD
You only have to unplug it for 30 seconds. Also, make sure it does not have a DVD in it when you turn it off as the TV will try to default to the DVD all the time. Resetting the power (I use a surge protector) allows it to turn back on normally. Based on the comments I've seen this TV has terrible sound with DVD, doesn't want to turn on, and is hard to mount on a wall.
Nov 18, 2009 | Televison & Video
I have 32" akai that won't turn on - it is plugged in
I had the same problem witht he same tv that was given to me! I just took off the cover to the DVD player and unpluged all the connectors to it and then the TV worked. Now you will not be able to use the DVD player but you can hook one up externally
Oct 23, 2009 | Akai LCT3201TD 32 in. LCD Television
Akai TV remote is not working correctly
I don't think the Akai remote is designed to work with cable or satellite service. I have to use both remotes & I have Direct TV.
Try unplugging the TV for a few minutes then plug it in and try the remote again. I had the same problem shortly before my Akai LCT2721AD quit working altogether. Three 1000uF capacitors blew in the power supply. Bought 3 new ones and replaced the blown ones myself rather than pay over $100 for a new power supply. Works fine now.
Oct 23, 2009 | Akai LCT2721AD 27 in. LCD Television
Dishnetwork Remote
the way i program a remote is hold the tv botton on top for five sec. till all lite up on top, then press tv power botton (little red)then slowly channel up till tv turns off, then press pound to set. some combo tvs wont take
Jun 11, 2008 | Akai LCT2716 27 in. LCD Television
Attaching Wall Mount Support to AKAI Flat Panel
You use the four outer holes as suggested in the manual on page 12, see below:
Apr 23, 2008 | Akai LCT2721AD 27 in. LCD Television
AKAI LCT2721AD On/Off Problem
My Philips LCD TV had the same problem. If your Voltage system is 110 AC till 127 AC and no transformator, then it is probably caused by one of the 4 main transistors, which are likely not originalfrom AKAI, but made in Malaysia or closeby there.
My TV works perfectly after 1. Replacing the burned or semi-burend transistors (in the back panel) 2. After repair (=US 60 plug the TV in a outlet from transformator set to 100 V.Good Luck!
Apr 15, 2008 | Akai LCT2721AD 27 in. LCD Television
Tivo DirecTV Remote-Program AKAI LCT2721AD
Try this: On the Tivo remote press and hold the TV Power button and the Directv/TIVO button at the same time. Hold both buttons down for about 4 seconds or until remote light stays red. Then press the channel up button until the tv turns off. You may press the button over 100 times. You need to go slow. When the TV turns off press the enter button (or select button).
Dec 09, 2007 | Tivo DirectTV Remote Remote Control
Akai lct2721ad flashing red light
I would bet on the power supply....these (and other Akai LCD) are notorious for filter capacitors. Look for electrolytic capacitors with a dome-like bulge on the top of them. They are usually located at the top of the power supply board where the power output lines run out.
Hpe this helps you out....
Sep 23, 2007 | Akai LCT2721AD 27 in. LCD Television
Akai LCT2721AD 27 in. LCD Television Logo
119 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
