Question about Microsoft IntelliMouse Explorer 3.0
Microsoft IntelliMouse Explorer 3.0 is brand new , when i plug it in it works perfectly, after a few seconds its starts to stutter and the left right movement get less and less until it stops working altogether .it still moves up and down but not perfectly, i have the latest drivers and i have changed it to different usb ports but always the same thing happens. There is no problems in device manager and my dell mouse is working perfectly.
ijay
  • 82 Answers
SOURCE: Wireless Intellimouse Explorer 2.0 problem
DEAR, Once again install fresh driver of your mouse
Posted on Sep 25, 2007
SOURCE: Right mouse button, wireless intellimouse explorer 2.0
how is the switch replaced and by whom? cost?
thx
Richard
Posted on Jan 02, 2008
dutchman05
  • 487 Answers
SOURCE: Microsoft Natural Wireless Laser Mouse 6000 doesn't work
Hi
If you take the batteries out there is a screw in there. unscrew and open (not easy) with flat knife in the edges wiggling.
attach and touch all the inside wires. I have had the same problem and it is an internal connector problem. Opening and closing aint easy and will take a little patience but it will work.
Good luck
Posted on May 03, 2008
buzzwood
  • 65 Answers
SOURCE: DELL Dimension E510-mouse erratic, usb pop ups
Did you check to see if your type mouse is compatible with your unit and your operating system? (XP or Vista?)
Posted on Jan 05, 2009
yooperbud
  • 8637 Answers
SOURCE: Wireless Intellimouse Explorer Not Working.
Normal 0 Normal 0 Recheck the magnifier to see if its set right.
Go to Control Panel and click on the Mouse icon. Then the mouse properties will appear showing the mouse buttons. In the Left column is the button settings. The bottom one is the Right Button, which is set for Magnify. Whenever you hit the Right Side button the magnifier will turn on. To turn it off, hit the Right Side Button and off it goes. You can change any of the button settings by clicking on the drop down.
Hope this helps. Bud
Posted on Feb 06, 2009
Left mouse key is sticking on Microsoft optical intellimouse
You need to replace your mouse my friend. I guess its time for it to rest.
Apr 08, 2010 | Microsoft Intellimouse Explorer OEM Pack...
Left button stop working
Try cleaning it if you can. otherwise get a new mouse.
Mar 09, 2010 | Microsoft Wireless IntelliMouse Explorer
MS Wireless IntelliMouse 2.0 pointer direction reversed (up/down)
Go into the control panel and click on the mouse icon and see if you can change to settings back to normal.
If not then check under your start menu and see if the intellimouse software is installed there and go into it to change the settings from there.
Feb 14, 2009 | Microsoft Wireless IntelliMouse Explorer
Mouse scroll wheel doesn't work properly
have you tried clicking on the bar that moves the page left to right and then tried using the scroll wheel?
Sep 19, 2008 | Microsoft Wireless IntelliMouse Explorer
Sep 01, 2008 | Microsoft Wireless IntelliMouse Explorer
Mouse Has Quit Working All Together. Help!!
I had the same problem with my Microsoft Intellimouse 1007 (Explorer 2.0) Tried various solutions (reinstall/update drivers). In the end I went into the board bios and found that enabling the motherboards 'USB mouse' controller and 'USB keyboard' controller solved the problem. Hope this helps.
Jun 26, 2008 | Microsoft Wireless IntelliMouse Explorer
Keyboard stopped working after installing mouse
Apparently your issue has been resolved, as there has been no additional information posted, and so this issue should be closed. If not, please feel free to post back for additional assistance. Thank you for using and rating FixYa.
May 22, 2008 | Microsoft Wireless IntelliMouse Explorer
Microsoft wireless intelimouse explorer 2.0
Having experienced the same problem with (2) Intellimouse Explorers I analyzed the problem and found a solution after driver updates failed to correct it.
Remove the single screw inside the battery compartment, lift off the rear portion of the mouse top cover, then gently lift up the back end of the remaining shell.
Once you have the inner workings exposed, use a Q-Tip to dab rubbing alcohol on the right click button's micro switch, manually clicking it a couple dozen times to clean the button's inner workings. Do not work about shorting out the mouse, as alcohol is non-conductive, and non-corrosive. It will not harm the electronic circuitry.
It doesn't hurt to do the same for the left click micro switch and the side button switches as well, as long as the mouse is disassembled.
Next use a clean Q-Tip to clean the edges of the top & bottom housing. This is the most likely cause of the right click button failure - there are small particles of debris lodged along the edge where the travel of the right click button is supposed to depress, but cannot.
Next, turn the top cover over and move the catch on the right underside forward and push it gently downward to uncatch the edge of that latching clip. The click on the left underside is a bit more complicated and requires a gentle lifting of the rear pins and moving the left clip more to the left and downward to release it from it's locking position.
Once you have freed the actual button's cover from the rest of the top cover, clean it thoroughly with a Q-Tip swab soaked with rubbing alcohol.
While the works are exposed, check for hair and debris around the scroll wheel as well. The small plastic wheel cover lifts off starting from the read and tipping up and forward.
Carefully reassemble all parts and hte right click function should now be restored. The debris has been removed and the right click now has it's full range of travel restored.
Apr 29, 2008 | Microsoft Wireless IntelliMouse Explorer
Mouse buttons not working
try unscrewing the mouse and see if the mouse clips are engaging on the sensors or clips
Feb 08, 2008 | Microsoft Wireless IntelliMouse Explorer
the right and left buttons are controlled by a switch you need to replace the switch
Dec 07, 2007 | Microsoft Wireless IntelliMouse Explorer
Open Questions:
can you please help ms drunel broussard who just received custody of 2 of her abused grandchildren in nov 2017 have a great xmas not having a home with furnishings..she no longer have stable housing ms drunels daughter and boyfriend had been abusing her children..shes a great person with such agood heart and shes struggling to keep the kids..while in moms care the kids was sleeping on the ..have very min clothing..ms drunel took her car notes monies to get the kids basic clothing and hygiene needs..shes help so many7 ppl and always been an strong person..not knowing where they would lay their heads at..i watch her go and visit ,pray for ppl in the hospital..when you ask herhow is things going shell say all will be well..but today i seen her breakdown and crying..letting the kids know she might have to let them go to foster care because she cant provide them with a stable place..to know her is to truly love her..and to see her not be able to care for them the way she cared for hewr children and other ppl children is taking a toll on her.but she keeps smiling..she really need help and an agency in jax fl where she lives told her to give them up or go to a shelter...she replied ok ..and left..doors is not opening and due to the NATURE OF THE abuse..and physical abuse these babies been through she said no..they have nothing i mean nothing for xmas...less alone shes facing losing her means of transportation to get them to and from school...counseling ...and dr.appt...PLEASE PLEASE I BEG OF YOU HELP THIS FAMILY...THANK YOU FOR YOUR TIME
Dec 14, 2017 | The Computers & Internet
See all Microsoft IntelliMouse Explorer 3.0 Questions
Microsoft IntelliMouse Explorer 3.0 Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
