Question about Kitchen Ranges
Triton t90si keeps going hot and cold does it need a new element
  • Kitchen Ranges Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Posted on Sep 08, 2010
My Triton t80si shower "cycles " going hot then cold then back to desired temperature - only just started happening no problem with flow of water
It sounds like the cartridge has to be changed. Pressure balance is not working in the cartridge.
Apr 13, 2013 | Home
No water, hot or cold from Triton T90si. Any ideas please?
The Triton t90si is fed from the tank in your attic.This also feeds the cold water in your bathroom.If you still have cold water in the bathroom tap,it means that there is water in the attic tank so the problem is somewhere else.I believe there is a bleed valve on these showers so maybe that is the problem. It may also be that the pipes are clogged up with dirt or limescale.The water filter may need cleaning. Hope this will help with your thinking on the problem.
Dec 19, 2010 | Home
Triton shower t90si will not cool the water. water is absolutly scalding
hello :>
have a look at ur geyser and what tempreture the thermostat is set on. dont set it lower then 55 degrees or swams will grow in geyser and not higher then 65 degrees or the water will be scolding to qwite hot. plz rate, and let me know if u need more help. thermostat is located on geyser at power point. take off outside shell. put off power when worinking it hehe .U will see a devise with a pin conected with wiers that says most comenly 0-80 degrees. hope that solves it . let me know
Jul 01, 2010 | Home
I have a triton T90si that wont heat yhe water ,when i turn it up to 9 the water is only luke warm , could you please tell me what could be wrong?.ta.
Check your heating elements..Turn up all the way and listen to each element..You'll hear the one not working..Or you can put your hand by each one and feel for the ones that the coolest.Thats the one thats bad...
Apr 03, 2009 | Home
Triton T90si electric shower temperature stuck on hot.
It sounds as though the valve is not closing and opening properly. I would have a proffesional come out to have a look. I could also be the control board not working correctly or a combination of both.
Mar 22, 2009 | Home
Triton electric shower T90si ran dry and not now working.
pump needs attention and the heating element has burnt out
pump needs water to run and the heater element needs water to keep it cool
Sep 07, 2017 | Heating & Cooling
MY Triton T90si electric shower continues to run when it is turned off. It is not fully on , but water keeps coming from the shower head evev when the electric isolation swithc has been turned off. Also it...
Most conventional showers have brass seats or rubber seats that can deteriorate over time. these will leak or dribble and not maintain your temp.. Rubber and brass seats are a fairly common and easy replacement. It sure beats trying to rip out a shower valve.
Jul 11, 2008 | Heating & Cooling
Kitchen Ranges Logo
481 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
