Question about Panasonic DMR-EH60 DVD Recorder/HDD Recorder
I have a panasonic DMR-EH60 DEB RECORDER (had it for about 4 years) and this week I have lost the sound from the unit and just get a hissing. Have tried all connections and tried swapping scart leads but still the same. The digital box feeds through the recorder to the tv and I can get sound from this with the recorder on standby but as soon as it it switched on I lose the sound. Have you got any ideas.
4 Suggested Answers
SOURCE: panasonic DMR ES20DEB blank screen but sound
Posted on Jan 21, 2009
SOURCE: Panasonic DMR-E85 DVD recorder TV Guide problem
Try unplugging the DMR-E85 power cord. It is important that you unplug it from the back of the recorder, not the wall. Leave it unplugged for 10 or 15 minutes. For good measure disconnect the cable 'in' connection as well. Once both lines are plugged back in it will go through its self-check diagnostics. Leave it alone for awhile (give it time to consider the error of it's ways). If you are lucky, when you turn it back on it will ask you to verify the channel lineup. If this does work, and all the channel info is correct, press 'enter' (lineup 1 highlighted). Good luck! This is an awesome machine, WHEN IT WORKS!
Posted on Jan 24, 2009
SOURCE: Recorder has stopped decoding SD digital TV but analogue TV is OK
Dry joint - faulty capacitor on the PC board of the decoder. Found by wiggling the components and resoldering
Posted on Apr 18, 2010
Have lost chanel 5 and others on my panasonic dvd recorder since national retune.How do i retune my dvd recorder?
It seems others have had this problem too, but there seems to be a generic solution to it. Unplug the device from the mains and leave it without power for a few minutes. Then, reconnect your device. That should solve your problem.
Back to your question about retuning it, you have to hold the channel up and channel down buttons at the same time for a few seconds. Auto-setup should start.
Hope that helps,
Oct 10, 2009 | Panasonic DMR-EH60 DVD Recorder/HDD...
How to convert dvd +r to dvd -r
Use DVD Shrink & Nero Burning Rom
1. Put the DVD +R in your computer's DVD burner drive
2. Open DVD Shrink
3. With 'Full Disc' checked, click 'Open Disc' button.
4. Choose settings as required.
5. After it does the quick preview, click 'Backup'
6. When it prompts you to insert a DVD insert a DVD-R
7. Close the dvd DVD drive.
8. When done, enjoy the movie.
Sep 27, 2009 | Panasonic DMR-EH60 DVD Recorder/HDD...
Everything has been working perfectly for 3 years or so/ done nothing different,use almost exclusively the HDD on my DMR-EH60, then suddenly the TV no longer responds to my commands. Unit goes off and on...
The DMR-EH60 has been working fine for a good five years then it started intermittedly loosing sound when using it as tuner for our display panel. Now there is not sound at all even recordings from TV onto the HDD. Any ideas?
Jul 19, 2009 | Panasonic DMR-EH60 DVD Recorder/HDD...
Panasonic DMR-EZ28 won't talk with remote
hi you need to reprogram the remote to fit with the unit there have 3 codes for remote 1 or 2 or 3 to reprogram your remote with the code indicated on your display press and hold the [3] and [ENTER/OK] buttons together for approx 5 to 10 seconds, then release
Jun 24, 2009 | Panasonic DMR-EZ28K DVD Recorder
DMReh60D finalizing problem
spindle motor
you will need a scope
and alignment disc to make final adjustments
Apr 25, 2017 | Panasonic DMR-EH60 DVD Recorder/HDD...
Cannot finalize disc with a panasonic DMREH60D
I also have a DMR-EH60 which after some time failed to finalize recorded dvd's. When finalizing the dvd unit was making grating noises and then would display the finalized failed note.
The machine was sent in for servicing which worked fine for a few months and failed again.
In dicussion with the technican we found that the rubber drive plater for the disc was getting contaminated with a dust type residue which allows the disc to slip in it's drive causing the reader to be confused, with the result of a failed finalizing function.
If you are game disconnect from the power and open the unit up and carefully take the top off the dvd unit and clean the plater with is-propyl alcohol, this seemed to work fine.The residue problem will be an on going problem however once you have cleaned it once it's pretty straight forward.Just be careful removing and reinstalling the dvd top cover.
Dec 05, 2008 | Panasonic DMR-EH60 DVD Recorder/HDD...
Can't Finalize a disk on Panasonic DMR-EH60 DVD Recorder
It sounds like you haven't selected DVD first. When dubbing to DVD, you need to do this in HDD mode. When finalizing, you need to be in DVD mode for the finalizing options to come up.
Mar 16, 2008 | Panasonic DMR-EH60 DVD Recorder/HDD...
Unlock code to play any dvd and record to hard drive
You need a special remote, there are no codes. Have a google for "panasonic region free" and you'll see what I mean. I have the same model and had to take to a dealer to unlock for me. Panasonic are a bit unfriendly about unlocking dvds as I think they are part of the whole DVD organisation. there are ways to do it with a Palm device or something like it (even a pc with IR port) but it is tricky. You can also rent a suitable remote for about £20 I think, again google it and you'll find companies that offer that.
Hope that help, though I guess you may have sorted it by now as you posted about 6 months ago,
Dec 22, 2007 | Panasonic DMR-EH60 DVD Recorder/HDD...
Panasonic DMR-EH60 DVD Recorder/HDD Recorder Logo
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
