Question about SYMA Toys industrial New Syma S107 Mini Indoor Gyro
How do I change the ballance bar on my Syma S107? Is there a repair manual? Jeff
SOURCE: syma s107 take off problem
The blades could be on up-side-down or The battery may not be holding enough of a charge anymore. If it's the battery, check out these Syma S107 Battery replacement instructions.
Posted on Sep 16, 2010
  • 3 Answers
SOURCE: i bought 3 of the
For one thing, there are only two channels. Although the transmitter shows a,b,c the switch has only two positions. The way to assign a channel to a heli is to turn it on and then simply operate the transmitter. The heli will lock itself onto the first frequency it receives, and start working. Before turning on the second heli, make the first transmitter is OFF, and set the second transmitter to the other channel. Turn on the second heli and simply operate the transmitter. The heli will lock itself onto the second transmitter's frequency, and start working. Then you can turn the first transmitter back on.
Posted on Nov 07, 2010
SOURCE: my syma s107 will not
Assuming the battery is fully charged, the shaft could be dry, purchase a WD-40 pen, they have a magic marker type tip that dispenses controlled amounts of lube by pressing the tip on a surface to get a drop then use a toothpick to put a small amount on the rotor shaft top and bottom. I did that to mine and the shaft spins a lot smoother. Mine always lifted off with no problem, but it got the gitters and and would drop a few feet now and then. after I oiled the shaft the gitters went away. Give it a try. John.
Posted on Dec 09, 2010
SOURCE: the top rotor of my syma S107 is not working and
This is a counter rotational craft and thus there should be two electric engines turning one rotor each. The top rotor is probably connected to the lover gear, and thus this is where you should start looking.
When you turn your top rotor, do any of the gears move? Try holding the gear while turning the rotor also, if the rotor is spin able while holding the gear then your rotor shaft is damaged and the entire rotor should be replaced if possible.
Also, try turning both rotors and see if one spins heavier than the other. This should
also indicate damage to the construction, or the engine.
If everything is looking all right, and all the gears turns all the way to the engine, and everything looks tight, then it is a great possibility your engine is fried.
Many of the sets have easily changeable rotors and rotor shafts, and some also have easily changeable gears. However, most cheap crafts like this do not have easily changeable engines. I do not know this model, so this you have to investigate. Now, it is possible to do engine shifts by yourself even if the manufacturer does not provide spare parts, but I
Posted on Dec 23, 2010
SOURCE: my Syma S107 will not lift off the ground. what
Had the same problem - the rotors would spin but the helicopter would not take off. Finally tried tightening both screws on the piece just below the Balance bar. I tightened one of the screws about 1/8 turn, and now it works great.
Posted on Dec 26, 2010
My syma s107 isnt responding to my controler
change the batteries in remote controller,,sure for charging indication in flying kit s107,,otherwise describe the fault completely to me
Jan 19, 2015 | SYMA Toys industrial New Syma S107 Radio...
Syma S107 Heli quit in the middle of flight.
Most likely to be a faulty PCB circuit board.
We have all spares available on our website.
Kind regards, Julian.
rccontrolfreak.co.uk
Dec 09, 2012 | SYMA Toys industrial New Syma S107 Radio...
My Syma S107 bottom rotors won't turn. What is the fix?
Probably just the cog on the motor not meshing with the main shaft gear.
Aug 07, 2012 | SYMA Toys industrial New Syma S107 Radio...
The tail rotor on my Syma s107 metal series helicopter won't spin. the battery is fully charged. the top rotor still spins. i don't know what to do
It seems tail motor is not working.
S107 knows to come with faulty tail motor.
If you open pilot cabin, you should see blue and red (or green and red) wire. See if they are welded on the motherboard.
If they are, then tail rotor is not working properly.
Mar 25, 2011 | SYMA Toys industrial New Syma S107 Radio...
My S107 does not hover very well. It moves in a large circle on its own. It isn't the trim as it doesn't spin around the axis of the rotor. It points in the same direction but slowly moves left, back,...
The upper shaft 'T' head has a broken pin in it (the part that holds the blades. You can flip the heli upside down and slightly rotate the blade housing back and forth and IT SHOULDN'T do that. Another way to instantly identify it is dislocate the rotor head links and the upper blade housing should instantly separate) It's made of plastic.
Anyway, It's also called the "T.B.E." Toilet Bowl Effect. It's not 'really' what's taking place, it's move of a cyclic issue but the effect looks like it's swirling in a toilet bowl... You need to replace the inner shaft basically on the upper rotor. They cost anywhere from $4-7.00 bucks. It took me about 2 days of researching and purchasing another one to finally figure it out. There was another website that says the balance bar is it or the gyro has gone bad; this simply isn't true.
Cheers!
Jan 05, 2011 | SYMA Toys industrial New Syma S107 Radio...
My Syma S107 will not lift off the ground. what can i do to sort this out?
Dec 05, 2010 | SYMA Toys industrial New Syma S107 Radio...
Syma s107 take off problem
Jul 30, 2010 | SYMA Toys industrial New Syma S107 Mini...
SYMA Toys industrial New Syma S107 Mini Indoor Gyro Logo
278 people viewed this question
Top SYMA Toys industrial Toys Experts
MeAndMyBrain
Level 1 Expert
Terry Hair
GI Consulting
Are you a SYMA Toys industrial Toy Expert? Answer questions, earn points and help others
