Question about Texas Instruments TI-Nspire Graphic Calculator
How do you adjust the column width in a Function Table? I can't see the numbers in the f(x) column because it goes off the edge of the screen.
    Problem Solver:
  • 10 Answers
When you press menu it should give options for resizing the width of the columns, otherwise you could scroll over with the touchpad
Posted on Mar 05, 2011
Ray the belts or gone thought someone might have one of these tiller and could get numbers off their forward & reverse belts
try this
set the belt adjustment at minimum
run a tape measure around the pulleys to get a dimension as if a belt was fitted
measure across the top of the v of the pulley to determine belt width
now for discussion purposes the length is 856 mm and is 11 mm wide then go to a belt supplier and try for a belt that reads 865 (33") to 870 mm (341/4") x11mm (.43")
talk with the supplier to see if it is possible to change the belt for larger or smaller
10 mm or 1/2" makes a difference in the length but the width will be 9mm , 11,or 13mm
a proper width belt will fit in the pulley with the edge of the belt just proud of the edge of the pulley or level with the edge if the pulley
correct length should put the adjustment about 1/4 adjusted to allow for stretch of a working belt
Jul 20, 2016 | Garden
I need to enter two columns of,values, x and y, to determine the linear equation but my table,only,displays the x column. How do,I get the y column back to enter numbers in?
Use the STAT function
Press STAT>EDIT >1:EDIT
Enter independent x_variable in L1, and y-variable in L2
To do calculations, Look under CALC (see 3rd screen capture).
950b71d3-25e1-4a5b-b0b4-d4d0e82c0d11.png 90b5ca2a-98e9-4ccc-9052-249dc893a0ae.png ffc1318e-337e-4a81-b00d-4150b0b0ee8e.png
Apr 15, 2014 | Texas Instruments TI-84 Plus Silver...
I have a TI 84 plus and when I hit second graph it goes to table where I can insert y values. by accident erased my Y values and only have the x column. Can I get the Y values back?
If you have a function that generated the table, you can recreate both columns again. Just enter the function, then press SHIFT GRAPH. The table will be regenerated.
For values you entered yourself there is no way to recover them. You will have to reenter them again.
Sep 02, 2011 | Texas Instruments TI-84 Plus Calculator
I can not draw a table in microsoft word
hi ermelitacapa,
To create a table in Microsoft Word please do the following:
1. Go to the Table menu and select 'Insert Table'. The Insert Table window will open.
2. Select the number of rows and columns you want in your table.
3. Select the column width (up to 22 inches) or choose 'Auto' to have the column with adjust automatically, making the table extend across the width of the page.
4. Select the AutoFormat button to select one of Word's pre-formatted table styles. The Table AutoFormat window opens.
5. Click one of the styles in the Formats box in the upper left side of the window.
6. Preview each format, after selecting it, in the Preview box in the upper right side of window.
7. To customize a pre-selected format, select or de-select the borders, shading, font, color, heading rows, first column, last row and last column boxes.
8. Select AutoFit, and Word will automatically fit the table to your page.
(To manually change the width of a table or column after you have created it, use the mouse to place the pointer over the vertical line you want to move. When the pointer turns into a double-headed arrow, drag the line to the position you want it in the table.)'
I hope this helps!
** If you find this information helpful please leave feedback to help us help others **
Feb 24, 2011 | Microsoft Windows 7 Home Premium 64BIT...
I need to know how to get to Table Set on the TI-85 because I need to find the x intercepts on the graph, but I can't find it. How do I get to it?
try this one:
(first). Set up a function in the TI85. how?
Step 1. Press the [Y=] key to open the function editor.
Step 2. Type in the function you want in the Y1= line.
Step 3. Press [2nd] [QUIT].
(second). Create a table of numbers using the Y1 function.
Step 1. Press [2nd] [TBLSET] to open the table setup menu. On the line "Indpnt", highlight "Ask" and press enter. On the line "Depend", highlight "Auto" and press enter.
Step 2. Now press [2nd] [TABLE] , type in a value for "X", and press [ENTER].
Step 3. Continue typing more values for X to fill up the table.
(third). How can I see more decimal places for the numbers in a table?
Answer:
Step 1. Use the arrow keys to move the highlight over the number you are interested in seeing to more decimal places.
Step 2. Read the number at the bottom of the screen. You should be able to see anywhere from 9 to 14 significant figures for your number.
(fourth). Delete the numbers in a table by:
(The following procedure will work when the table setup has been set to ask for the values of the independent variable.)
Step 1. In the table screen, check the bottom of the screen to make sure that the cursor is not blinking at the bottom of the screen. If the cursor is blinking, press the [ENTER] key to stop the cursor from blinking.
Step 2. Use the arrow keys to move the highlight to the first number in the first column of the table (the "X" column).
Step 3. Press and hold the [DEL] key to delete the numbers in the first column of the table. The entire table should become clear with this procedure.
Thanks! I wish it can help you..
Feb 16, 2011 | Texas Instruments TI-85 Calculator
How do you determine the amount of columns to be used in a web design table?
You need to decide how you want the web page to appear. Most simple web pages have 2 or 3 colums to separate the content. If you are adding images, this may influence the width of a colum. e.g. if an image is 300px wide, then the column should be at least 300px wide. A web page may be set to a size suitable for viewing in browsers, the most common widths being between 600 and 925px. So if a web page is 600px wide, you would only get 2 columns of 300px width, or 3 columns of 200px width.
Nov 10, 2009 | Computers & Internet
Table issue
You will have to assign an onclick function to each of those 5 column headers. There is no way to group those into another element.
Another option is that you can assign an ID to each of those TDs and create a javascript funtion that will loop through those IDs and assign the onclick function dynamically.
Oct 22, 2008 | Computers & Internet
Lg flatron 775ft screen size problem
Hi Edit123,
U can chane output width and height from buttons given on LCD panel manually
Sep 19, 2008 | LG Flatron L1750S 17" LCD Monitor
Screen width unadjustable
chk the resolution is as mentioned by the makers in the user mannul.
Jun 16, 2008 | Computers & Internet
Most likely width control circuit has developed a problem. Most common causes are a failed diode in the yoke return circuit or open capacitor near the flyback.
Sep 23, 2006 | Envision EFT720 17" Flat-Screen CRT...
Texas Instruments TI-Nspire Graphic Calculator Logo
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
