Question about DISH Network IR Remote Control
I replace the tv to the bed room 2 remote and it doesnt work I cant watch cable and the remote is responding to the tv
  • Official Brand Answer
  • 263 Answers
Hey brandonericm, sounds like the remote may need to be readdressed to the receiver. I can definitely help with that. Here are some steps to help you:
1. Access System Information from main TV.
2. Note the number on the bottom by Primary/Secondary Remote Address.
3. Hold SAT on TV2 remote until all lights on top come on.
4. Let go and while SAT is blinking enter a number between 1-15 and press #.
5. Press record 3 times and the number should change to the one you chose.
Tommy Faust
DISH Network
Posted on Jan 29, 2011
Dstv remote not working on any blue dials? Two tv's in separate rooms, one pvr decoder. Only the red dial works on both tv's & both remotes are working & both tvs responding properly.
Is this a newly installed system? If both tv's are responding to the same remote setting (red in case), it means both tv's are set to the same channel. The tv that is connected to the decoder directly (via AV cables, I presume) is supposed to respond to if the remote is set to red. In order for the second tv to respond when the remote is set to blue, you need to tune the second tv until you find the picture of tv2 (the decoder transmits both tv1 and tv2 on the RF/coaxial output and it seems that your remote tv is tuned to tv1 instead of tv2).
Apr 02, 2013 | Televison & Video
Toshiba 42SL417U doesnt respond to remote and shuts off
you have a bad power supply or mainboard causing the shutdown most likely the mainboard.
Mar 02, 2013 | Toshiba 42sl417 42 1080p Led Tv 42sl417u /...
My original remote for my Element TV has gone bad and the Universal that I bought for it will not work. Is there another place to get a Universal that will work>
Hello there,
If you're going to replace the remote, I would advise replacing it with an original Element remote. Finding a universal remote to work with Element TVs is purely trial and error - in many cases error!
I can help you to find either a replacement original remote or a universal that will work with your TV, but before doing so, you really need to check whether it's the remote that needs to be replaced. When TVs fail to respond to the remote control, it can be due to a fault with the infra-red (IR) receiver in the TV. Before buying a replacement, please test your remotes as follows:
1. Get someone to point the remote at you and press some buttons while you look through the viewfinder of a digital-camera or camera-phone. You should be able to see white flashes from the end of the remote through the viewfinder. This works better in a darkened room but it needs to be light enough for the digital camera to function.
If you don't have a camera-phone or digital camera . . .
2. Take the remote into a dark room - totally black works best. Point the end of the remote which you point at the TV towards you and press some buttons. You should be able to see faint red flashes emitted from the end of the remote. This is not to be confused with the indicator light near the top of many remote which illuminates when you press a button.
If the remote is working, it may still be possible to get the TV to respond again. Please try this first and let me know the results of the test. I will then be able to assist you in finding a replacement remote - or possibly even get the TV to respond again. Please reply to me by clicking on "Add a Comment" below your question.
Regards,
BElectric
Feb 25, 2011 | Element Televison & Video
Tv doesnt respond to buttons or remote
this is looking like a common LG problem our tv started doing this tonight
May 15, 2010 | LG 42LC2D 42 in. LCD HDTV
DISH DVR doesn't respond to remote
  1. If this is a TV2 location take the remote to the location of the DVR.
  2. Open the door on the right side of your receiver.
  3. Press SYS INFO.
  4. Press Record multiple times on your remote.
  5. Exit the screen and see if the remote works, if not replace the batteries and repeat steps 1-4
  6. If the remote still doesnt work, and this is a tv2 location (no receiver in the room with the tv) check the antenna on the back of your receiver, make sure that it is connected tightly and standing straight up.
  7. If none of this works call Dish and ask for a new remote.
Jan 22, 2010 | DISH Network ViP622 DVR DTV Receiver /...
The Emerson TV won't respond to the remote
If the Duraband doesn't work the Philips remote below worked on mine. If it doesn't then it probably is the sensor. I just purchased one of these televisions and it didn't come with a remote. However, a Philips Universal Remote (SRU2103/27)
with a code 0520 works fine. I haven't explored all the codes but I can easily change from tv stations to Video 1 and Video 2 merely by pressing the "Input" button on the remote.
May 11, 2009 | Emerson EWF2006 TV
Should be controllng one box. is controlling 2 boxes
Unfortunately, there is no solution for this issue.  The remote control sends out an infrared signal, which can be picked up as far as 40' away from the device.  And to make things worse, the signal will reflect off any surface such as glass, mirrors, or even brightly painted walls.
The only way to solve the problem is to block the path of the beam to the other room.  This may require closing a door or drawing heavy drapes closed.
Mar 03, 2008 | Logitech Harmony 880 LCD Remote Control
Intermitten remote sensor issue
Evidently 2 good remotes point at the problem being the remote sensor on the TV itself. I have about 4 remotes I can adjust volume w/ including the remote that came w/ my samsung. The TV exhibits the same behavior w/ all of them.
Per the samsung site, the "test" for this (remote vs sensor) is to us a digital camera, (including the kind that's on most cell phones) to "see" if the remote lights up. Just point it at the camera/phone, and press any button. You should see a bright flashing light on the camera/phone's LCD screen. If not, REJOICE! All you need to replace is the remote or batteries in it. If you do see the light, good luck if you're not in warranty. I've been unable to find any procedures for replacing this kind of item.
Nov 13, 2007 | Samsung DLP HL-P5663W 56" TV
Can't find a channel to watch a DVD pre-recorded DVD
you should have a input select button on your remote. video 1 should be the front and video 2 should be the back. i had to buy 3 or 4 different universal remotes when mine messed up just to get the one button to change to change it to the inputs because there is no other way to change it to that with he buttons on the tv. kinda surprised that you didn't try and push that button yet.
Aug 31, 2007 | Televison & Video
DISH Network IR Remote Control Logo
1,121 people viewed this question
Top DISH Network Televison & Video Experts
brian soufane
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
