Question about Ovens
The LED Display is out completely, but the oven still works - just can't see what you're doing. The complete LED display & board is $160 - $200 Q # 1. Can it be repaired by replacing a capacitor or LED or another part - OR.... Q # 2. Will I need to spend the $200 to get the LED display & board to fix it?
  • 1 more comment
  • sherrycookl Sep 08, 2010
    PS. It is a Jenn - Air Model # SVD00W. A slide in dual fuel range
    How do I find an Oven Service Center near me that "repairs" boards.
    The appliance repair store in my small town of Newnan (35 miles south of Atlanta) does not fix boards - only replaces the boards.
    OR - i guess i should have asked - how do I find an "LED board repair service center"?
  • 2,272 Answers
Led boards are not easily repairable,until the exact faulty component is located.It has to be tested with meter for voltage and power in each component and faulty has to be replaced.But this repairing does not last long,even if it gets repaired.The component in the front panel board gets weak and starts blowing out and getting Short.Going for the replacement board is very much advisable. For getting required parts you can get it from the online site like www.repairclinic.com Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Posted on Sep 09, 2010
  • 944 Answers
1)Yes you can repair LED display or capacitor part alone
If you take it to a Oven service center they will ask for full replacement you have to specify that the problem is with capacitors or LED.Ask him to do continuity testing with ohm meter on the board and change the appropriate part in the board.If you have to take to LED board repair service center he will change you the capacitor or LED as you said.
2)The cost for this will not cost more than 30$-50$.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 08, 2010
  • Natarajan Ramasamy
    Natarajan Ramasamy Sep 09, 2010
    sorry i am from India so i don't know these type of information.
    "LED board repair service center" you can refer your yellow directory for this.
The display has stopped working, the oven light works, the gas burners work.
There may be a fuse inside the oven which has failed or it could be the electronic display board.
Sep 18, 2015 | Ovens
Faulty lights and timer bleeper on neon clock display on front of electric oven.
It is very possible the control board is going bad. Before replaceing the control board pull the connectors and reinstall them. There could be a bad connection causing the display not to lioght up completly. If that doesn't work then it looks like control board time.
Nov 17, 2014 | Stoves 720EF Electric Double Oven
Lcd display is dead - oven heats up and oven light work
The display could have a bad connection on the board or just have failed. Either way you are looking at replacing the complete board assembly. Eric
Aug 18, 2010 | Maytag Ovens
Double oven (WW30430B) got the similar display dim/disappear prob
If you haven't already, replace the capacitors on the clock module. I had the same problem with a similar oven. See this link for more info:
http://www.badcaps.net/forum/showthread.php?t=7902
Aug 23, 2009 | Jenn-Air JJW8530C Expressions Collection...
Display on my Jenn-Air electric wall oven is very dim
douglas9101,
I had the same problem and found the solution on-line.
Replace the C3 capacitor on the dispaly module. (100 UF, 35 volt, high temperature)
The local Jenn Air dealer wanted $211 for a new display module.
I purchased a Cap from a local electronics supply store for 79cents.
The only problem is that you need to have a soldering pencil/iron, a solder ******/wick and a small amount of solder.
Steps I had to take on my oven:
- Flip the AC breaker supplying the oven to off to be save
- remove 3 screws on top and 4 on the bottom of the display panel
- gently pull out the display panel and unplug the 2 cables to the display
- unclip the ribbon cable to the display module
- unclip the module itself by pushing on the 2 black tabs
- locate C3
- unsolder C3 and replace with new Cap- keeping the polarity strip the same as theh old Cap
- reasemble in reverse order.
It took me all of 20 minutes. It may sound difficult but is very easy if you have the tools
Good Luck
K
May 11, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Oven's digital temp display too dim to read
The electronic control board will have to be replaced
Jun 07, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Jenn Air oven
Does anyone know the part number to replace on model W30400P - the digital display is completely out - the oven heats up but can't read time/temp - not a thing on the LED display - thanks!
Nov 19, 2007 | Jenn-Air W30400P Stainless Steel Electric...
Digital Display
July 8, 2009
My display went completely dead. Been dead for a while. Just today I fixed it. You have to change a small capacitor, on display board labelled C3. Very hard to find the exact one which is, 35V - 68 microfarad, so I replaced it with 35V - 100 microfarad. Works just fine. You have to be handy, or find a friend that can do this, cause you will need to solder.
Anyways hope this helps. By the way the capacitor cost me 15 cents canadian.
Good Luck
Nov 17, 2007 | Jenn-Air JJW8230D Electric Double Oven
Problems with Jenn-Air Electric Double-Wall Oven
that board supplies power to the light unit and it is very easy to replace if that is what is wrong. it can also be the led display unit also. cost about $150 each i think.
Oct 26, 2007 | Jenn-Air WW30430P Stainless Steel Electric...
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
