Question about Toshiba 57H81 57" Rear Projection Television
My remote has stopped working. Fresh batteries are in.
  • Toshiba Master
  • 8,457 Answers
Take out the batteries,put it back in an hour later.Now,the remote is resetting.Should work now.Not,than the remote CPU Chip is dead.Sorry the remote it junk now.Try website like Remotes.com to buy an exact to the original remote or very close compatible one.
Posted on Sep 08, 2010
FLASHING RED LIGHT ON MY SHARP LCDTV REMOTE RC1910
Check it with fresh batteries. For some remote controls; if battery became low, this should happen. Electro help
Oct 24, 2014 | Sharp LC Televison & Video
REMOTE HAS STOPPED WORKING, HAVE REPLACED BATTERIES, BUT STILL NOT WORKING
Check the remote control for its infrared emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
Apr 04, 2014 | Vizio VR2 Remote Control
Samsung LE32C450E1W TV remote control stopped working, changed batteries no luck, turned off at power source for 30 min which fixed prob temp but has happened again and now turn off doesn't help....
Check the remote control for its infrared emission. Check it with fresh batteries. Clean the battery contacts inside its battery compartment. If these do not help you, you remote control need cleaning. If you wish to know more about how to clean and repair a remote control check this site. Pull up older posts. One among it has details.
Mar 24, 2013 | Samsung TV Remote Control
REMOTE HAS JUST STOPPED WORKING
Check it with fresh batteries. Check the battery contacts in the battery compartment for any rust or dust accumulated.
Dec 29, 2012 | Samsung Remote Control HTBD1252...
Sony remote keypad not working
Try removing the batteries and either reinstalling them or replacing them with fresh ones
Oct 30, 2012 | Sony Remote Control RM-YD017 p/n:148030111
Remote control stopped working
If the remote batteries are "ok", have you tried replacing them with fresh ones?
Oct 29, 2012 | Televison & Video
Remote control stops working
Sounds like it may simply be the batteries dying in your remote. Try putting a fresh set in to see if that helps at all.
Also be sure to check the battery terminal contacts inside the remote control's battery compartment as well to ensure there is no corrosion deposits which may cause intermittent faults. Clean / scrape off any rust or deposits with a flat head screwdriver or something similar until the metal contact is shiny again.
Good luck.
May 03, 2012 | LG 32LD550 32 in. LCD HDTV
The remote control has simply stopped working! The batteries have been changed! Nothing on the remote is accepted by the TV. There is no response, not even a flicker from the TV.
Try resetting your remote:
* Remove batteries
* Press each button on your remote, twice. (one button at a time). This should discharge any current left in the capacitors.
* Insert fresh batteries.
If the above fails, then your remote is faulty.
Cheers,
Jul 31, 2011 | Hitachi Televison & Video
My devices suddenly stopped responding to my remote even though the remote looks to be working normally
Remove batteries, let it sit for a minuit then put in some fresh batteries.
Still not working?
Plug it back into your computer and load Harmony Remote software. Click on "update remote" this will reload the firmware and programming.
I've had a couple harmony remotes go wackey on me but normally re-loading the programming or putting in fresh batteries fixes em right up!
Cheers,
Kevin
Feb 01, 2010 | Logitech Harmony 670 LCD Remote Control
Toshiba 57H81 57" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
