Question about Toshiba Satellite M45-S331 Notebook
Toshiba Satellite M45-S331 notebook, os xp. Change hard drive couldn't use recovery disk, put in each driver from recovery disk after installing os. Blue screen states the bios in this system is not fully acpi compliant. I can't find updated acpi bios even if I could need advise how to install.
  • Toshiba Master
  • 4,924 Answers
The thing is that windows xp ..usually does not have the drivers for teh acpi or achi mode and you need to get into bios and disable teh mode and let the hard disk to run in IDE compatible or sata as ide..
the function can be disabled in the same screen where teh hard disk and other sata and ide devices are presented..
After you disable the achi mode..it will work ..remember that you have to save changes with F10 before exit bios..
another way to make this work ..is install the windows xp in this mode..after you are done ..just install all drivers for it ..including raid and ahci drivers..and change it back from bios..It may work ..if it sees the drivers..
or ..you need to install the drivers when you get to teh press F6 to install 3rd party drivers....and you have to find a way to get them ...cause this operation is done usually b yusing a floppy diskette so ..to have a chance to do it .. you need to try to install them from a usb or install windows from usb and use the disk with drivers in the optical drive ..
If I would be in your place I would not complicate myself and just go to bios and change the bus mode for the hard disk ..save changes and reinstall operation system if needed..or go on from where it was..It will see the hard disk and no longer give you the blue screen
Posted on Jan 07, 2012
In need of restoring to factory settings, (Toshiba Satellite M45). Held down zero, powered on, no beeps occur. The recovery utility never appears. Not listed in All Programs for Hard Disk Utility nor in...
It appears the recovery partition has been removed from your hard disk. You need to obtain a Recovery CD from Toshiba.
OR
If you have a Windows XP Home installation CD then you can use it to reinstall Windows on your Toshiba and the product installation code will be on the Windows label on the bottom of your laptop.
You can download thedevice drivers for your model laptop from the Toshiba WEB site from theirdownload page. Make sure you enter the model of your laptop so you can get thecorrect drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsphttp://blitware.com/adpages/driverfetch/manufacturer/?manufacturer=Toshiba&gclid=CMOVxNCBx6ACFSgnawodoHNGbA
Jun 18, 2011 | Toshiba Satellite M45-S165 Notebook
When my m45-s331 laptop is turn on for a long time, if i put the monitor off, maybe in not be turn on again and it's brightness become very low and hardly it can be seen! what should i do?
if you're using win xp, try to check the power option.(click start, go to control panel & power management/power option).from there, you have an option to adjust your screen brightness settings everytime you wake up your system from sleep mode/hibernation mode.
other option, you can update your video driver. here's the link http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=882862&rpn=PSM40U&modelFilter=M45-S331&selCategory=2756709&selFamily=1073768663
then choose display driver. download and install it. It will update your video display driver. It might help to improve your brightness issue.
Good Luck,
Ryan
Jan 17, 2011 | Toshiba Satellite M45-S331 Notebook
Can't find updated ACPI Bios for toshiba satellite m45 s331. If found how to install? Getting blue screen Bios in this system not fully ACPI compliant.
I already explained in the other post ..The action required is either install a 3rd party raid and ahci driver ..and if you do not have the possibility ..just c\go to bios and enable the hard disk bus to work as ide..(disable ahci mode) I'm not sure how it will appear ..but you have to look under the bus mode..where the hard disk is seen ..It will appear as ahci enabled..and need to be disabled or ..will have raid mode enabled..and need to set it as native ..or ide compatible
Sep 08, 2010 | Toshiba Satellite M45-S331 Notebook
Toshiba Satellite M45 S331 Use to power all the time.When we went to install old hard drive to load Windows Xp.It went to screen to start set,then it shut Down.It will Not Power up,Why?
remove eh hard disk and see if the laptop boots up at least to bios settings ..If it does ..I suggest to reinstall the computer but first go to bios and change the ahci mode for hdd into ide compatible or native ..and save changes..This will eliminate the need for 3rd party drivers and will install proper..
No matter what you have on the disk ..it can not do this right the way ...It need s the operation system in order to work and make damages..and if you wipe it out it will not be there anymore. (in case of a virus) ..
I suggest to use a disk to install and not the old recovery ..
let me know how it works and what it does..and I will further advice in this matter
Aug 08, 2010 | Toshiba Satellite M45-S331 Notebook
I dont find sound drive for this mdel
hi
go to this link
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
1, click Download
2, select laptops
3, select satellite
4, just scrol down you will fine M45-S331
5, and select go
6, select operating system
and download
have a nice day...
Jun 02, 2009 | Toshiba Satellite M45-S331 Notebook
I went from XP Home Edition to Vista Ultimate.
You need to go to the Toshiba website for your location at this location: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp# and select "Download" then type "M45-S331" into the search box. I would suggest you download all the drivers for Vista and install them. Good fortune to you.
May 30, 2009 | Toshiba Satellite M45-S351 Notebook
Internal Hard Disk Upgrade
Yes, there is. Match the type of drive (Serial ATA or Parallel ATA) you get with what you have. Make sure your Satellite sees the drive in the BIOS. For drives larger than 120 GB, recommend operating systems Windows XP (Service Pack 2 or higher) or Vista. Older OS's have a 137 GB limitation (they only see the first 137 GB of the hard drive despite its size).
Mar 01, 2009 | Toshiba Satellite M45-S359: M45-S359...
Tosiba satellite m45
Not sure but I believe the M45-S331 came w/ a standard PATA drive and that could be a problem if you replaced the old drive.
Oct 17, 2008 | Toshiba Satellite M45-S331 Notebook
Toshiba Satellite M45-S331 Notebook Logo
315 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
