Question about NorStar M7324 Telephone
When i pick up the phone, callers can't hear me but i can hear them
Try a new curly cord and handset...see if that if the problem.
Posted on Sep 08, 2010
I can hear callers through my s11 plantronics headset but after using and trying all configuration no.'s they can't hear me at all
Make sure the Plantronics S11 headset is plugged into your handset jack on your phone, not the headset jack, this will make a difference on most phones. After plugging the S11 into the handset jack on your phone, you will need to pick up your handset receiver and sit it off to the side of the phone to place a call or to receive a call, after you are finished with your call sit the handset receiver back in the cradle on your phone.
Good luck from Headsets Direct!
Nov 07, 2011 | Plantronics S11 Headset
Phone rings but cant hear caller they can hear me
This is a problem that has to do with the speaker of the phone(not your loudspeaker but the small one). It is probably broken and as a result, there is no way you can hear your callers.
One way to confirm this is for you to put your call on loudspeaker when it comes in and you have picked it, if you can hear your caller then you are sure that the smaller speaker is faulty.
Also, you can try to use a very compatible earpiece or headset and see if you can hear your callers.
If this happens to be the case there is only one way you can get this to work and that is by sending it to a qualified repairer as the phone requires serious expertise so as not to damage it an further.
hope this solution helped solve your problem? please comment for more information and thank you for using the fixya.com website
Jan 01, 2011 | Pantech Duo Smartphone
I can hear the caller but caller cannot hear me on 29870GE1-A digital answering machine
Hi, Please check whether the mic has gone bad in your handset.
the connectivity is just fine as your are able to hear the caller. but if you think there must be something wrong with the caller's phone, try calling someone else and check.
please let me know if you need more help. Thank you:)
Oct 23, 2010 | GE 29870GE1 Corded Phone
Low volume once call is established
Try and locate where the volume control of the phone is so that when your making calls, immediately the caller your calling picks up the call, increase the volume by the side of the phone.I think you will hear your caller clearer.
Take care.
Mar 11, 2010 | Palm Treo 750 Smartphone
The phone rings,states the number calling but you can't talk to the caller. When you answer the phone, the person on the other end can hear you, but you can't hear anything. You can't get a dial tone when...
The switch that the handpiece activates is not working. Could be optical, magnetic or physical. It may need cleaning, adjusting or a wire connection repaired. Also check the curly cord and its connections between the handpiece and telephone.
Nov 17, 2009 | Sakar Talking Caller-ID Speaker Phone
I can't hear the caller but the caller can hear me!
just need a new earpiece speaker or it simply needs to be adjusted into place. If there is no repair shop around you or you do not want to mess with it, then just buy a $20 bluetooth headset to bypass the whole earpiece.
Mar 10, 2009 | Palm Treo 650 Handheld
Dial tone is active as I'm dialing, callers cannot hear me speak
Your phone is broken, the only solution is to replace it. Call Uniden Customer Service and they should be able to help you. 1-800-297-1023. ( I'm serious, there is no way you can fix this problem with out opening the base unit up and replacing a bad transistor)
Feb 24, 2009 | Uniden DECT 6.0 Cordless Telephone...
Phone dialing problem
I had to switch the spy prevention function (IPP) off
Jan 10, 2009 | Lands Phones
Can not hear caller..
Replace the handset and cord with one from a known working phone. If this solves the problem, order the parts needed. Otherwise, send the entire phone for repair.
Hope this helps!
Feb 14, 2008 | NorStar M7324 Corded Phone
For incoming calls, the caller cannot hear me for 2-10 seconds after I pick up
You've got an IP issue somewhere in your setup. It sounds like the call is being lost and then the phone is querying the DNS server to find out where it should be looking for the call. Do you have a VOIP server name or it's IP address in the setup? Are you using DHCP or manually assigning IP addresses? If the VOIP server is not on a static IP, I would fix that first. Post back here the answers and we can look at it further.
Aug 04, 2006 | Polycom SoundPoint IP 501 IP Phone
NorStar M7324 Telephone Logo
76 people viewed this question
Top NorStar Lands Phones Experts
george  peters
george peters
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
