Kenmore 27032 Logo
Posted on Sep 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Kenmore Elite Oasis wash machine and every time turn off with F1 code. I look internet and said that's factory problem. Please help me
Anonymous
Level 3:
  • Master 15,935 Answers
  • Posted on Sep 18, 2010
Anonymous
Master
Level 3:
Answers
15935
Questions
19
Helped
5033484
Points
35540
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
2 Related Answers
Anonymous
  • 3 Answers
  • Posted on Feb 27, 2010
SOURCE: kenmore elite oasis washing machine gives the code F1
the machine needs to be rebooted. Unplug the machine for at least 10 min then plug back in and push pause or stop 2 time.
Anonymous
  • 15935 Answers
SOURCE: have kenmore elite oasis, type 580. when starting
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question!!!!!!
9helpful
Toploader kenmore elite oasis is showing F1 code for error. I do not have an owners manual. What does F1 mean?
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
Gene
Code F
These units have several very common error codes. the most common being error code F1. Oasis washer repair is simple. The link below has a video that explains how to replace the main control board on a Oasis washing machine.
Oasis Washing Machine Repair Video
http://www.appliancerepairlesson.com/
1helpful
F1 error
yep electronis control board in the console is bad.
The Kenmore Elite washing machine gets an F1 code on the digital readout then stops. Once the start and stop buttons are cycled a couple of times the machine starts running again.
Check to see if the screens for your hot and cold water connections are plugged with grit.
Or else the problem might be due to factory defect in the control circuit board of this washer.
1helpful
Machine stops several times shows F1 code
this is a main control board failure and needs to be replaced
8helpful
2answers
F1 error
there is a factory defect in the control circuit board of this washer, read and call the number. post is from another owner.
I called 800-659-7026, which seems to be a 3rd party "recall" center for appliance companies, for my F1 error code. All Kenmore HE Elite Oasis machines with Serial Numbers beginning with CS48-CT49 are in the process of being recalled; however the mailings haven't gone out to customers due to hold-ups in legal with wording. Machines with these serial numbers require an upgraded control board and it takes about 10 business days for the part to come in. They ordered it with no questions asked and are coming out July 14th to replace it free-of-charge
Kenmore Elite Oasis Washer Error Code F1
per sears unplug the washer for at least 10 min then plug back in and push pause or stop 2 time.
1helpful
F1 error code on Kenmore Oasis He
Moister can get in between the contacts,is it in a high moister environment? Try using a hair dryer on the panel to dry it out.Also unplug it to reset.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Alexander
vince
