I have a Whirlpool 3953954 two speed automatic. When I got to start it, It will fill up with water and then just make a noise like the motor is running but nothing else works
JR JR
  • 116 Answers
SOURCE: washer fills with water, then stops
OBVIOUS REPL LID SWITCH AND SHOULD SOLVE YOURE PROBLEM 100 % MAYBE INSTALLED IN CORRECTLY,, TAKE A LOOK AT YOUR LID MAKE SURE BUMBER IS ON AND NOT TWIKED
Posted on Nov 30, 2008
  • 234 Answers
SOURCE: whirlpool wshser-dryer: water won't drain, cycles won't start
You need to give more info in order for a diagnosis. Is this a compact stack unit or an all -in -one unit or an interconnected washer/dryer pair ? Is it front load or top load washer ? What do you mean by "dry cycle"? Is that dryer cycle or is it washer cycle without water ?
Usually when water cannot be drained it is a bad coupling connector on the motor drive, or a bad or clogged pump (small socks have been known to get sucked in an lodged in the pumps); in either case you need a good mechanic or a service person to handle the repair because it requires opening up the shell of the unit and getting to the motor/pump assembly.As always, disconnect the power cord before diving into the unit. Good Luck, Macgivor.
Posted on Sep 20, 2009
canbruce75
  • 1776 Answers
SOURCE: Won't Rinsing
Check for a cold water supply problem, since cold water is what is used in the rinse cycle. Check the water inlet valve (pay special attention to the cold water side). Unplug the machine, turn off the water, and remove the water supply hoses. Check the small metal screens inside the openings on the valve. Make sure they are clear of rust or debris. Check the solenoids using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a bad solenoid and the water inlet valve assy will need replaced. Very sorry for your trouble and I hope this helped. Best wishes.
Posted on Sep 25, 2009
  • 3 Answers
SOURCE: Whirlpool Top Loader LSB6000PQ0 fills up with water but that's it
you probably closed the lid to hard and broke the switch that tells the machine that it is closed. So the machine thinks the lid is open and for saftey reasons will not operate. I had the same problem. You can buy a new switch for about $10 or you can simply cuts the wires for the switch and wire them together. If you do this be warned that the machine will never know if the lid is open or closed. The machine will assume that the lid is always closed. But it will work also.
Posted on Dec 09, 2009
  • 185 Answers
SOURCE: Kenmore series 80, model 110-25842400, and serial
thabks for being through... i wish everyone was like you.. i get alot of Its not working? i hate that what does that mean... wish they were like you.. please check the harness on the motor while it is spinning.. i had that problem before... also it could be the speed selector switch.. sometimes it will get caught running 2 speeds at once and it will click like that...
checks these things and let me know if you need more assistance.... you sound like a tech.. wanna job? lol
Posted on Apr 12, 2010
Whirlpool Top Load WTW4800XQ wont agitate but will drain
Check the plastic/rubber motor to gearbox coupling hasn't broken.
Aug 03, 2014 | Whirlpool Washing Machines
Loud constant noise (metal on metal clicking / whirring / grinding) during spin cycle
renault laguna 2006 diesel. unlock code for radio... modell renrdw100-10 .
n874 security...
pls..
thanks
Nov 22, 2013 | Whirlpool Washing Machines
Whirlpool Dishwasher will fill water then stops
If it fills with water properly then stops, and especially if there is a humming noise, it is possible that
- motor start capacitor has failed
- drive belt has slipped or snapped
- belt tensioner spring has broken
Nov 07, 2013 | Whirlpool Gold 24 in. Built-In Dishwasher...
MY whirlpool WASHER MACHINE FILLS WITH WATER BUT DOES NOT WORK AFTER THAT. IT DOES MAKE SMALL NOISE LIKE MOTOR BUT DOES NOT WORK.
Maytag LAT3600A Top Load Washer
1 Points
Nov 27, 2012 | Maytag LAT3600A Top Load Washer
Whirlpool dishwasher misbehaving
What it sounds like to me is the water fill solonoid plugged or not opening all the way. Check to see if the washer fills with water when starting, that should be the first thing it should do. If it does, then the whining noise could be your water pump inside the washer trying to run, which means it could be a bad motor or the impeller may have come off of the motor shaft. I would pull the screen off the inside of the machine and inspect for damage from a bad impeller. You will have to pull the washer arms off first, they just pull up and off, and the screen you can do the same to. If it is motor or impeller problems I would suggest calling an appliance repair man or just check to see what it might close to get repaired.
Sep 06, 2012 | Whirlpool Dishwashers
I bought a new Speed Queen AWN432. Installed it, filled it with water. When the water stopped filling the motor does not run.I've pushed the lid switch on the back side to make sure it was close
If there is too much weight to 1 side, sensors in it will stop it from spinning. If you evenly distribute the weight of your clothes this may fix it.
Jan 29, 2012 | Speed Queen AWN432 Washer
Whirlpool DU1055XTSQ2 Quiet Partner 1 Has grinding noise at start up. Can you send a diaghram so I can take off the bottom sprayer and what do you gthink it could be?
Is start up after filling with water? After it fills the wash motor starts to work. Some times the spray arm could hit the heating coil when it turns. Make sure the spray arm is not loose. But most likely its the wash motor.
Dec 12, 2011 | Whirlpool Dishwashers
Whirlpool GU1500X dishwasher motor noise got loud
Hello- Yep- it's toast. A small seal on motor shaft failed, causing water to destroy bearings. Motor is about 100$. Installation instructions available if you choose that route. Let me know if this info helps- have more if needed.- Thanks - Ed
Mar 12, 2010 | Whirlpool 24 in. GU1500XT - Multiple Color...
Won't Rinsing
Sep 25, 2009 | Washing Machines
Machine will not agitate, but it allows the water to drain.
soundsas if you have possibly broken youor motor coupling( this machines "belt") easy repair, yo can see video as to how to replaceit by searching you tube for whirlpool motor coupling
Mar 16, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
97 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
