Question about GE 18.2 Cu. Ft. Top-Mount Refrigerator - Black-on-Black
Refrig does not cool to only 45 degrees Freezer is
Refrig does not cool to only 45 degrees Freezer is at zero or colder
  • GE Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 08, 2010
My refrig and freezer wasn't working good, i replaced the heater that goes underneath the coils. now my problem is the freezer is on 0 degrees and the refrig is on 60 degrees, i noticed the flap that...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 28, 2011 | Refrigerators
My sub-zero 642 will not get colder in the freezer than about 9 degrees and the fridge won't get colder than about 45 degrees. I turned off the breaker and vacuumed the coils, but still no change. ...
The Sub Zero 642 uses independent refrigeration meaning the freezer and refrigerator each has their own system. Best to have an "Authorized Factory Service Company" check it out.
Jun 08, 2011 | Refrigerators
The ge refrig. is 9 years old. Regardless of the refrig. setting, from 5 down to one it is too cold. set on 3, after 24 hours it is 28 degrees in the crisper and 32 degrees in the main refrig. tried...
ok u ok u turning wrong knob..turn other knob the one with the letters. make the freezer colder than u make ref. warmer. that knob controls a flap that controls how much cold air flows from the freezer to ref. ok
Feb 12, 2011 | GE Refrigerators
I have a 20 year old side by side sub zero. For the last few months i have had problems keeping the temp even in the refrigerator side, either freezes or gets too warm. Now it wont get colder than 45 or...
heatman101
Sep 09, 2010 | Sub-Zero Refrigerators
Fridge does not stay cold but the freezer works
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 19, 2010 | Sub-Zero 650 / O Bottom Freezer...
Frigidaire refrigerator with a broken freezer
He is correct. The temp in the refrig controls how often and for how long the refrig runs. Lets say the temp in your garage is 34 degrees, and you have your refrig set to 36 degrees: The refrig will never run, the fresh foods section will cool to 34, and the freezer will warm to 34. Even if the temp is 45 in the garage and you set the fresh foods to be 33, the refrig will not need to run long enough and often enough to keep the freezer temp cold enough. You will most likely need to have the ambient room temp at least 55 degrees to get satisfactory refrigerator performance. Insulating the refrig will not help. (by the way, outdoor beverage vending machines use an internal heater in cold weather to prevent liquid beverages inside from freezing,..... so using that info, you could put a low wattage heater in your refrig to make your refrig run enough to make the freezer section work. The %&#* with that, just move it into the house!)
Feb 06, 2010 | Frigidaire FRT17B3A Top Freezer...
Freezer and fridge not cool enough
Check if the syrofoam pieces block air inlet. If so then this may be the problem.
May 08, 2017 | Admiral Refrigerators
Frig is turned down to low and everything is still freezing. Ice maker not making ice.
icemaker not working because to cold in freezer;water transfer tube frozen and will need to be deiced, but first must solve refrig. to cold, making freezer to cold, thermostat problem which is common it is a presure filled and in time can loose presure and will run colder, some have adjustment scew with arrows warmer or colder adust warmer and only turn a 1/4 turn or less until you get in middle of dail range. or replace thermostat. refrig. temp. should be 38 to 40 degrees frenhiet. freezer no colder then 0.
Nov 29, 2009 | Frigidaire GLRS234ZA Side by Side...
Whirlpool refrig not cooling
is the fan in the freezer working when compressor is on? if not you need to replace it. do you have a large frost build up on the back wall of the freezer? if so you have a defrost problem, or back to the evaporator fan. If the fan is working you have a defrost problem which could mean a bad heater, timer, or bad defrost thermostat....
Jan 03, 2009 | Whirlpool GS6NBEXR Side by Side...
GE 18.2 Cu. Ft. Top-Mount Refrigerator - Black-on-Black Logo
232 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
