Question about Sport & Outdoor - Others
My York r201 air rowing machine has lost it's resistance. I have taken it apart, but been unable to fix. How do I repair it? Thanks Ty
3 Suggested Answers
  • 3 Answers
SOURCE: Slack in line on rowing machine
extend the line to its max required length while you are sitting on the machine { as using } then get someone else to adjust the slack on the line and make it taught , the adjustment should be a bolt and nut type located on the main wheel . do not adjust the line from the seat as this may dislodge the seat . happy rowing
Posted on May 06, 2009
  • 3194 Answers
SOURCE: how do i repair the hydraulic unit it leaking oil on my 2010 bh rowing machine
Hello Garth,
Posting a question about washing machines alongside a picture of a washing machine isn't helpful when it is a rowing machine you want advice about. I am smiling...
The exercise machines that use a hydraulic unit I have seen use units that are cosmetically superior vehicle shock absorbers or dampers with a cylindrical container for the oil and valve mechanisms and a piston rod.
A long time ago it was possible to overhaul these telescopic dampers but for many years they have been considered a sealed-for-life throw away item, though the unit manufacturer might have the facilities to cut them open, replace the seals and valves and then weld them together again, it is doubtful.
The manufacturer of the hydraulic unit will not be the manufacturer of your rowing machine. A replacement unit will be a great deal cheaper from the former and there is generally a name and a part number somewhere on the hydraulic unit though it is often obscured by paint.
Dampers and suchlike tend to be standard items and replacements can often be found in the catalogues of the various manufacturers by matching the dimensions exactly.
I hope this helps if only a little.
Posted on Jan 26, 2015
Testimonial: "sorry about about washing machine add . i did not put that in ,but thank you for your answer,food for thought."
My york fitness r201 air rower wont retract
Did you get this fixed? Mine just broke too.
Mar 03, 2014 | York Exercise & Fitness
Won't click a picture; when you push the button to take the picture, it just goes down. it does not click. the lens does not open. can't advance film. totally dead. new battery, yet that really is for...
Sounds like the shutter is stuck. Same thing happened to my ALPA. I like you was unable to take it apart to repair, so many small tools required to take it apart. You could be better off sending it to New York.
Sep 01, 2010 | Pentax K1000 35mm SLR Camera
My rowing machine is no longer reeling back the rowing strap after it is pulled on a stroke, how do I fix this? The stap is attached and coiled around and smaller wheel that is linked via a chain to a...
I don't what type of rower you have, but for the most part you will have to pull the unit one layer at a time ( suggest you take picture of the process) and one point a return mechanism should be visible that may have detached or broken. After identifying then contact the manufacturer sometimes they may even e-mail the procedure of replacing the defective component or components.
May 21, 2010 | York Exercise & Fitness
I have a Weider Platinum crossbow and the resistance isn't setting properly if at all. Is there a simple solution that I can do to fix this?
This is a common problem with this machine, the wiring inside the back. Mine was broken too, it was just a loose wire, but the stupid wire is so inside a protective case, you have to take the whole machine apart to be able to reach it.
You'll need a technician to come to your home. Call Icon to get a reference.
Jul 14, 2009 | WEIDERFITNESS.COM Weider Platinum Plus
What are the benefits of a Rowing Machine?
One of the major benefits of the rowing machine is that it assists in strengthening the torso, the upper body where most of our main muscles are located. In addition to, legs is constantly work out although in the lifestyle of today, the area around the upper body is used more than the legs. The use of resistance to workout the area around the upper body significantly contributes to improving the core strength of the chest, shoulders and forearms. With improved strength, it gives rise to an upper body strength that is more stable and solid to carry out our day-to-day tasks easily. The legs are firmly workout as well although not as much as the upper body but you will be able to notice the difference when you work out consistently. One of the better benefits of a rowing machine is that of calories burning but few use it mainly for that purpose as other fitness equipments such as the Nordic Track, stationery bike and treadmills can do so effectively. In addition to, the rowing machine can help to improve lean muscle mass and given that lean muscle mass burn off more calories for a given size, the body will utilize more calories to nourish the muscle. As a result, rowing machine effectively increases metabolism so as to feed the lean muscle with the requisite calories. Very few people know that rowing machine help to reduce the stress level and anxiety through the frequent use of it. Exercising makes a person less depress and edgy and it is one of the most beneficial and least appreciated of all the rowing machine benefits. Keeping our mental faculties alert and well is as important if not more than physical aspect of our health. To derive all the benefits mentioned, we need to effectively make the most out of the rowing machine. The information that we gather here will be very relevant to utilize the most from the rowing machine. Fully understanding the machine itself and its functions can contribute to us getting a complete and beneficial workout. Rowing machine mimic the actual rowing experience of a boat for the sole function of aerobic and strength training workout as well as for those training for rowing. The machine has been in existence for more than a century but only in recent years that it gains in popularity. The market for rowing consists of a few types of resistance and they are the air resistance, piston resistance, water resistance and magnetic resistance. All are equally effective and none can claim to be better than the others. Each has their own admirer and the types of resistance you choose will hinge on the relevance of your exercise as well as the state of your fitness level. To derive the most out of the rowing machine, you need to know the different types of resistance levels and the air resistance will increase in resistance as you increase your pace. The piston resistance is the most popular as it is so small and compact that allows the machine to be foldable and move around as well as easy storage. Water resistance comes close to the actual rowing experience and the workout is as intense and the magnetic resistance makes use of electromagnets which make it very smooth and quiet in operation. With lesser noise, similar to air resistance, it provides a great workout without disturbing other. Besides understanding resistance levels to fully utilize the rowing machine, the other extras are as important. The computerized digital display that provide all the functions of the rowing machine such as calories burned, distance covered, time and speed to better gauge our training. All these may come at an additional price but all is worth it. Rowing machine remains one of the best fitness equipments out there and with regular workout, the results are there to see.
Dec 01, 2008 | Kettler Rowing Machine Kadett Rowing...
The touch lift drip tray is broken its the plastic shaft that holds it together so its unusable.. I think someone lifted the machine by the lift tray or the shipper put the box upside down and it broke.......
The entire machine need to be taken apart to repair the auto drip tray. I would reccommend a Authorized Service Center to replace the tray. It is again not a simple fix.
Saeco's First Authorized Service Center of New York
Cerini Coffee Service
718-584-6120
www.CeriniCoffee.com
Oct 08, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Where do I send this watch for repair
I had this same problem with mine. Jeweler was unable to fix but still had never to bill me. The warranty repair shop was some place in new york. I purchased in fall of 04, broke fall of 04.
Nov 01, 2006 | Prague Skeleton EG-8901
Sport & Outdoor - Others Logo
171 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
