Question about Kenmore Dryers
80 Series- dryer was running fine, until I cleaned out the lint drawer and lint vent. Now it won't turn on. Checked the breaker-set, plug is in, light inside is on.
  • Kenmore Master
  • 8,220 Answers
The fuse is on the backside mounted on the blower housing More here80 Series- dryer was running - dedcd69.jpg
Posted on Sep 08, 2010
Dryer has power to timer, but won't start...I have an Amana electric dryer that allows me to set the timer and I can hear it running, but when I push in the the timer knob to start the dryer (drum
The fuse is mounted on the heater element. When it blows nothing in the heater or motor circuit works but the power to the timer is not interrupted therefore you can hear. Service manual
Feb 11, 2013 | Amana Dryers
Dryer keeps saying check filter - lint screen is clean-dryer won't run
Had the same problem. Filter was clean. Vacuumed out the area under the filter. Still had problem. Unplugged the dryer. Removed the hose vent (back of dryer) and checked the exhaust -- all clean. Plugged the dryer back in and was fine. Still going to check the vent to the outside for lint buildup.
Jan 17, 2011 | LG DLG2524 Gas Dryer
I have a kenmore dryer 80 series it only makes a lite sound when I push the start button. I won't come on. The power is good.
The Kenmore 80 Series of dryers are consumer grade dryers for home use. As with most home appliances, the Kenmore 80 series dryers will occasionally not work as intended. If a problem occurs with your dryer, however, you do not necessarily need it serviced by a technician. You can attempt to troubleshoot and fix any problems with your dryer before contacting a technician.
  1. Kenmore 80 Series dryers may not run for several reasons. First, make sure that the power cord is plugged into a working power outlet. You may need to plug a different device into the outlet to check that it is receiving power. If the second device does not run on the power outlet, you may have blown a fuse or tripped a circuit breaker. Check your fuse box or circuit breaker box and make the change as needed.
    Next, make sure that the dryer door is fully shut. The dryer will not run with the door ajar.
    Finally, check that the "Start" button was fully pressed and that a cycle was chosen on the machine. If you do not choose a cycle for the dryer, it will not run.
  2. If your Kenmore 80 Series dryer does not heat up during use, check that a heat cycle has been chosen for the load. There are several different dryer cycles you can choose, some of which do not use heat. Make sure that you have chosen a heated cycle.
    As above, check that you have not blown a fuse or tripped a circuit breaker. The dryer may use more than one fuse or breaker: one is used to power the drum, and the other for the heating element. Make sure that both fuses or breakers are in working order.
  3. There may be times when Kenmore Series 80 dryers do not fully dry your clothes. When this occurs, check the lint screen and clear out any lint. The air may not flow as well if the lint screen is clogged.
    Next, check to see if the exhaust vent is clogged. Lint and other particles may clog the exhaust vent over time, restricting air flow and making it more difficult to dry your clothes. To check the vent, run the dryer and hold your hand under the vent. If you do not feel any air flow, clean or replace the vent.
    If you used cold water to rinse the clothes it may take longer than normal to dry. The same is true if the load of laundry is very wet or is filled with items that are very absorbent.
    Finally, check the load size. The more clothes in the load the longer it will take to dry. If you want to reduce drying time, separate the clothes into piles of light and heavy items and dry them separately.
  4. please comment on these solution by saying how helpful.
Dec 22, 2010 | Kenmore Dryers
Kenmore 80 series. No lint in the lint trap, going directly into flexible hose leading to dryer vent.
lint trap is blocked.Take off back cover, clean it out. un-plug it.theres about 15 screws
Sep 03, 2010 | Kenmore Dryers
We just finished a load in the dryer and it worked fine. When we went to start another load it wouldn't start. The circuit works, it is plugged in, and the door is shut
Are your lint traps clean? Also, your vent hose going out the back of the dryer sometimes gets clogged up, and this will shut down your dryer until it is cleaned out. Try this, and if it still doesn't work - try shutting the dryer's circuit breaker off (or if its easier to unplug the dryer), and then back on again. This will reset the breaker, and then you can try running your dryer again. In fact, you can do the circuit breaker step first. If this doesn't work, then clean the lint trap, vent, etc. - and then return to the circuit breaker step. I hope this works for you. If not, let me know. I'll check back with you in a little bit. Good Luck!  Jim
Mar 29, 2010 | Maytag Dryers
I have an kenmore 80 series dryer and it stoped all of a sudden. I cleaned out the duct system, when I press the start button no sound.
If the belt has broken the belt safety switch will shut the dryer down and it will not start.
You can verify easily if you have a broken belt by manually trying to move the drum. If the drum turns and the motor does not move then either the belt is really worn or has broken which would activate the belt safety switch.
You did not mention if you checked the circuit breakers for the dryer so that is on the to do list also.
Additionally if the dryer got too hot there is a one time fail thermistor that will have to be replaced before the dryer will operate again.
Thermistors fail due to clogged airflow in following areas:
the vent ducting,
the lint filter,
air passages around the lint filter
or the outside thru the wall vent flapper assy.
Thanks for using FixYa.
Kelly
Mar 10, 2010 | Kenmore 63942 Dryer
My kenmore 80 series dryer won't heat but everything else works fine I cleaned the vent duct of all lint [ there was alot ] and checked the electrical conections
Had similiar problem once and it turned out to be one leg of the 240 volt
supply was dead. The drum motor only needs one leg (120V) to run, but the Heating elements require both legs (240v). Make sure you have 240V at the recep.
Nov 27, 2009 | Kenmore Dryers
Kenmore 80 series keeps shutting off. new motor and lint line cle
take off the vent line from the back of the dryer,if it runs fine your vent line is blocked or the outside vent where the flapper opens might have a cage on it to keep animals out of the line,it keeps the animals out but it's a lint trap.if you have a long run use a leaf blower and blow out the vent line,if that's ok check the t-stats on the heater box,
Nov 12, 2009 | Kenmore Dryers
Knemore 80 series dryer won't start every time
Go to www.repairclinic.com and enter your model number and it will show you all your parts, but I suggest you change your thermostats and basically have the dryer cleaned out of possible lint build up on the interior
Mar 20, 2009 | Kenmore Dryers
Fisher and Paykel electric top load dryer
Dd you try to unscrew the larger lint trap underneath the lint cup collector. My serivce person showed me how to do this and after a year I cleaned it out and was surprised how much lint was caught in there. My dryer was not heating and drying quickly, this helped the problem.
Sep 11, 2008 | Fisher DEIX2 Dryer
Dryers Logo
44 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
