Question about Oasis Refrigerators
Compresser making strange rumbling noise - Oasis Refrigerators
  • Oasis Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 11, 2010
Recently developed a whinning when I first start to move
Where is the whining noise actually coming from .. engine/gearbox or elsewhere?
A whining/screeching noise could be a drive belt .. such as the belt that drives the alternator.
On a manual car it could be the clutch bearing making the noise until it warms up. Does the clutch make a noise when you depress the pedal? That's the thrust bearing .. the bearing that operates the clutch.
I don't think you have too much to worry about. If you had engine trouble there would be knocks, rumbles and strange noises at all speeds.
A whining noise is usually associated with something spinning/turning .. such as a pulley/idler on a drive belt or a bearing alternator.
Put your mind at rest - get a mobile mechanic's opinion.
Feb 16, 2016 | 2001 Buick Park Avenue
Rumbling noise
the fan may need to be replaced. try first to use a compressed air can to see if this fixes the problem or replace the fans
Mar 29, 2014 | Apple Air Computers & Internet
Rumble noise right front wheel
Sounds like a wheel bearing assembly failing.
Jan 04, 2014 | 2001 Dodge Dakota
Rumbling noise under neath car
I am at a loss knowing what gear box your referring to and if the rumbling noise began before or after changing the box. There are many things that could simply be loose underneath a vehicle. A wheel bearing can definitely make a rumbling noise. Sure you changed the right one. Can be hard to tell which one sometimes. Sorry I couldn't help more than I did.
Jun 25, 2013 | 2000 GMC Sierra
Chevy s10 engine low power
Unusual to obtain exactly the same reading from each cylinder during a compression check, however good compression can be misleading when looking for problems.
To achieve it's potential, assuming an engine is in good order, the engine must be able to breathe efficiently and easily. Air and fuel must be able to get into the engine unimpeded and then leave without resistance. You mention a strange noise - might that be the noise of a strangled intake or perhaps a half-blocked exhaust, maybe the CAT is breaking up...
Jun 11, 2017 | Chevrolet S 10 Cars & Trucks
The Fan is rumbling, making noises- can it be
Often simply cleaning them carefully (no water of course) and oiling the motor will fix these noises. Occasionally they are too far gone, but this will fix most of them. Good luck.
Mar 22, 2010 | Broan-NuTone QT100L Fan
Within the last month fridge started making a strange rumbling noise that lasts about 1-2 seconds. It occurs every hour or so. What is that and how can I fix it?
If the refrigerator is working ok,it may be the defrost drain pan vibrating when the compressor shuts off. You will need to see if it is out of position. Also, does this refer have an icemaker installed and if so is it working ok.
Dec 21, 2009 | Whirlpool ET8WTKXK Top Freezer...
Frigidaire dryer making rumbling noise .
I work for an Appliance Wholesale Company at www.appliancepartsonline.net
Is the dishwasher a front loader or a top loader? That will matter!
Give me the model number of the unit and I will tell you how to stop the "rumbling"
thnx
info@appliancepartsonline.net
Feb 16, 2009 | Frigidaire Dryers
Rumbling in front tires
You probably have a bad wheel bearing or bad tire on left front. when making right turn left front wheel wil spin faster than right making noise louder.
Oct 16, 2008 | 2002 Buick Century
Refrigerators Logo
116 people viewed this question
Top Oasis Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Oasis Refrigerator Expert? Answer questions, earn points and help others
