Question about Toshiba Satellite A135-S4527 Notebook
My-spacebar-is-not-responding,neither-is-my-#four-or#six.--what-should-do?
    President:
  • 2,291 Answers
U may have hard ware problem , to check the software error use registry cleaner reg in out to fix software issue
Posted on Sep 16, 2010
Im looking for the total combination for this nuber 13 20 31 36 41 45 permutations i think its called
Do you want combinations or permutations? They're different things. A combination of n items taken m at a time, sometimes written "nCm", selects m items from a group of n without regard to order. A permutation of n items taken m at a time, sometimes written "nPm", selects m items from a group of m with regard to order.
Given six numbers, there are six combinations of one number, 15 combinations of two numbers, 20 combinations of three numbers, 15 combinations of four numbers, six combinations of five numbers, and one combination of six numbers.
Given six numbers, there are six permutations of one number, 30 permutations of two numbers, 120 permutations of three numbers, 360 permutations of four numbers, 720 permutations of five numbers, and 720 permutations of six numbers.
Oct 22, 2014 | Office Equipment & Supplies
Logitech 350 spacebar sticking
Make your day easier-order a $30 replacement from Staples.
Jul 16, 2014 | Logitech Internet 350 USB Keyboard
What is the name of the manual 4 speed transmission for the 1984 dodge d100 with a 3.7 (225ci) motor, and with that trans match up to a 5.2 (318ci) motor?? thank you
The great Dodge slant 6 engine...these were very strong and dependable, i put 300,000 on a 1985 D100 and it was still going strong when i sold it. Your transmission is a "883"
Chrysler began using "833" four speeds in passenger cars in 1964. The transmission was designed by Chrysler and manufactured by New Process Gear Co. Chrysler installed the 833 four speed behind the Slant Six at two different times. The first production four speed slant sixes were the 1964-66 A-body four speed cars. The second run of production four speed slant sixes began in 1975 with the release of the Overdrive A-833. From 1975 until 1987 the Overdrive four speed was installed in slant six applications of A-bodies, F-bodies, and light trucks (D100 & D200 series trucks). These applications were not ultra rare, but the slant six four speed production figures pale in comparison to the number of V8 cars that received A-833 four speeds. Since the A-833s installed behind slant sixes were basically the same transmissions installed in the V8 cars, a slant six owner looking to install an A-833 should be familiar with all the A-833s produced, including the ones used behind V8s...There are several characteristics of the various A-833s that determine which four speeds fit in which chassis and with which engines. For the passenger cars, Chrysler manufactured two different length four speeds. The A/F-bodies received a short tailshaft A-833 and the B/C/E-bodies received a long tailshaft A-833. This difference is obvious when one of each type is sitting side by side, but either type is easily identified when it happens to be a stand alone unit.
If you are looking to replace your truck tranny, you will need to find another one out of a truck that had the slant 6 engine for it to be a direct bolt up. Chrysler made several variations.
1975 thru 1987 Overdrive 3.09:1 - 1.67:1 - 1:1 - 0.73:1 (Trucks used a 0.71:1 fourth)
Good luck, hope this helps.
Jul 11, 2011 | 1984 Dodge D150
I recently have been having problems w/certain keys on my Apple Keyboard with Numeric Keypad. I used some wipes to clean it the other day...and almost immediately the spacebar & a lot of of other keys...
some of the fluid from the wipes must have short circuited the keyboard! you may have to invest in a new keyboard and keep it away from water based wipes this time!
May 04, 2010 | Apple Macintosh Keyboard
SPACEBAR WILL NOT SPACE
Inspect the spacebar paralell guide wire. When depressing the spacebar on the right or left side extreme the spacebar other side should travel down at the same time. If not the spacebar will not actuate the electronic keyswitch under the spacebar. Most likely, the keyswitch is defective and requires replacement.
Oct 12, 2009 | Olympia Mastertype 3 Typewriter
How many spark plugs are there?
Depends upon if you have the four cyclinder model or the six cylinder. The four cylinder would have four spark plugs and the six cylinder would have six spark plugs.
Aug 08, 2009 | 2001 Oldsmobile Alero
How do you disassemble a Microsoft Natural Ergo. Keyboard 4000?
as mentioned, there are more screws under the spacebar. The only way to safely get the spacebar off is to wedge a flat blade into the front centre of the spacebar and lever it off. If you try to pull or lever it from anywhere else you'll just snap something off it.
Jul 28, 2009 | Microsoft Natural Ergonomic 4000
Spacebar not responding on Toshiba laptop Satellite
Since the spacebar is the most used key on the keyboard, it is likely a hardware failure of the spacebar itself. Replacement keyboards can be found on EBay and normally run about $20
Jul 05, 2009 | Toshiba Satellite M45-S331 Notebook
Compaq R4000 - Spacebar needs pressure
i) try connecting another keyboard( if you have any spare) if it working ok .... then there is problem with ur keyboard(>3 years)
Dec 19, 2008 | Compaq Keyboard
Toshiba Satellite A135-S4527 Notebook Logo
145 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
