Question about Hayward 250kbtu Ng Pool Heater - Inground
First year with my new Hayward H 250fd heater. Closing pool this weekend and live in Michigan so you understand our winters. What do I have to do other than opening the drain plug if anything.
    President:
  • Hayward Master
  • 1,378 Answers
Other than the drain you'll need to remove the pressure switch from its feeder tube and leave it hanging by its wires for the winter. Be sure the heater is level or tilted towards the header to allow all the water to drain out. More than a few people have lost a heat exchanger to freeze damage after draining it because the heater wasn't level and water remained in the low end of the tubes.
John
Posted on Sep 08, 2010
Testimonial: "Thanks John."
How do I winterize my Hayward pool heater
either blow water out with a blower then follow with a little antifreeze to make sure all water is out then remove freeze plugs on sides of heat exchange then remove pressure switch turn off gas valve and put a board or something on the top to keep out snow and weather
Sep 24, 2014 | Hayward H Series Pool & Spa Heater 400k...
How to winterize the h100id1 hayward pool heater
disconnect or blow out with air and antifreeze then pull freeze plugs and disconnect pressure switch and turn off gas
Sep 23, 2012 | Hayward 100,000 BTU Pool Heater H100ID1 -...
Hayward HP error
check voltage coming in if ok check voltage after transformer if ok check safety circuit pressure switch voltage both leads if not replace or check for plugged copper line
May 04, 2012 | Hayward Heat - Pro 2100 Heat Pump Pool...
Make sure that you drain all of the water out of the pool heater to prevent damage during freezing weather. That is the most important thing you can do to winterize pool heaters. If you have a cover, you might want to use it to prevent weather related exposure, but as long as you have the water out, you will be ok.
Oct 29, 2011 | Hayward 100,000 BTU Pool Heater H100ID1 -...
HELP! I have Hayward 400K pool heater. Try to start last weekend and got SF code which is temperature sensor error. What/how I can solve this? Thanks for any help. My email coastalway@yahoo.com
Replace the thermistor. It is a stainless steel plug ~1/2" pipe thread with three wires leading from it to the back of the control panel. Shut the heater down and the pump too; remove it from the header and install a new one. Route the lead wire thru the chassis to the control board and plug it in...problem solved.
John
Jun 16, 2011 | Hayward H-series Electronic Gas Pool...
How do I drain the water from my Hayward heater for the winter
There should be a drain plug on the bottom of the header. This is common on most of Hayward's in-ground pool heaters. Since you did not give your model Number, I can't say 100%. You can also check Hayward's website for the manual and look under "winterization". you should be able to find your product manual here: http://www.haywardnet.com/inground/products/manuals.cfm#HeatersGas_Heaters Hope this helps. If you need further assistance post a reply in the comments, and don't hesitate to leave good thumb rating if you found this helpful. Thanks, and good Luck!
Oct 01, 2010 | Hayward 250kbtu Ng Pool Heater - Inground
Pool heater will not ignite
check pressure switch,if it is faulty or out of adjustment it wont allow it to go tomain burner
Jun 17, 2009 | Hayward 100,000 BTU Pool Heater H100ID1 -...
Hayward Heatmaster will not light
Find the pressure switch that senses H2O is going to the heater. There is a hose for the H2O on each side. Use a wire to "jump" the two electrical connections, which will simulate them closing from proper H2O pressure. If the heater actually lights, you need a new pressure switch(assuming H2O is actually going through the switch). You can buy one "on line" cheaper than the pool stores.
Mar 17, 2009 | Hayward H Series Pool & Spa Heater 400k...
How does heater work to keep freeze off pool in winter
What state do you live in, what is the brand name and model number of the heater. If you live in a state that gets cold during the winter, call you local pool store and schedule a closing. If the pump is running and water is not circulating, most likely the pump lost prime or your filter needs to be backwashed, or there is some debris in the impeller.
Nov 25, 2008 | Hayward H Series Pool & Spa Heater 400k...
Hayward 250kbtu Ng Pool Heater - Inground Logo
410 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
