The headphones are transmitting noises(beeps) but not voices. Tried to push green buttons but still no vioce. HELP!
    Sergeant:
  • 269 Answers
Have you checked in the control panel under sound, look down at the icons listed usually there are 3. see if you see one that shows a headset with a mic attached , that is the one you want. If that is not visable then i would select each making it your default dont forget, it wont happen unless you reboot each time. Now some stupid comments, are you sure you mic is not set on mute check your task bar most voice and music programs put a icon in the task bar for there control panel. If its there, open it and make sure all setting are correct this will superced all windows settings, make sure the volume is on an unbeaable high setting just in case. Follow cord of the headset if it has a control in line, make sure the little dip switch is not set on mute (been there done that, yes red in face) you never said if it is wireless, if so check batteries, take them out and put back in. And move any digital phone from your desk along with cell phones there interfere. (just till you eliminate causes) If its usb wired make sure the two plugs going into the usb adaptor are not switched on adaptor most have a little microphone and headset symbol (know its stupid but check anyway) if all else fails, take the name of the headset go to there web page and see if they have a driver to download it may as well be that, i know some time logitech has that issue.
If i can help further repost
Mel
Posted on Sep 08, 2010
Testimonial: "Thank you soooo much. Definitely a red face moment. Really appreciate it."
My T5950 won't stop beeping when I push the PTT button. I tried holding the PTT in when I turn the unit on and that didn't stop it.
Very likely it is the battery. Beeping means not enough power especially when transmitting. Try charging the battery again, try transmitting again and plan on new batteries. They "wear out" even when not in use.
Oct 16, 2016 | Motorola Talkabout T5950 (7 Channels)...
Can't transmit signal. Only get a 2 second beep when I push the transmit button
You have a poorly charged or bad battery. It takes more power to transmit than to receive. Usually the first thing you lose with a low, bad or poorly charged battery is transmit.
Try a known good battery in the radio. This should solve the problem. If not, check your battery contacts, as you may have one which is bad or not making good contact.
Clean your contacts with a pencil eraser to assure good connection with the charger.
Best regards.
Mar 18, 2014 | Kenwood Radio TK 260 360 270 370 2100 3100...
Ge plsh05 radio manual
Hi Howard,
Is there any noise or voice coming from the speaker before you try to transmit?
If so, you are trying to talk at the same time the channel is already in use, be it voice or someone holding down their PTT button without talking just to be a nuisance.
If this is correct, then nothing wrong with your radio, and nothing can be done about the button pusher blocking the channel.
Sorry if I have been of no help here, some things are beyond my scope.
Cheers,
Peter
Nov 13, 2011 | GE Radio Communications
There is not picture its just vioce
Battery OK, IR light up, no green image on the intensifier image tube, correct! What type of voices are you hearing? Give ATN Aries 390 two Zolof and wait two day, just kidding!!! The noise is a crackling, high freqencey hum, popping, etc. Also remove the eye lens, it screw off, then remove the scope to someplace where it semi dark. Turn it on and observe the 18mm white plate and see if it turn green---no green---no look see---no image intensifier tube, it dead that is the mage tube. stewbison.
Mar 15, 2011 | ATN Aries 390 Paladin Weapon Sight
How to enter new contacts to make calls using vioce
Does it have voice commands? On most phones there is a button on the side that you push to enable them. Then the phone usually says "PLEASE SAY A COMMAND..."
Apr 21, 2010 | Sony Ericsson W200i Cellular Phone
Black screen, hear voices , but no picture playing?
check your screen back Light or get a working screen and test it or your screen flax is bad
Mar 31, 2017 | Mitsubishi WD-73C9 73" DLP TV
I am running two 15 spl soundstream woofers with a soundstream 500sx amp how do I bridge them to get maximum performance
the 15 spl woofers are dual voice coil, i believe 2 ohms per voice coil.
the 500sx amp is rated 4 ohms bridged at 500 watts, it is capible of dropping to 2 ohms sterao, but no lower than 4 ohms bridged. to get maximum performance, you cannot use both voice coils of both speakers, you can only use one speaker, or both speakers, while only using one voice coil from each.
there is no point of bridging them, you can achieve maximum performance by attaching one voice coil from each speaker to each channel of the amp, while leaving one voice coil from each speaker unconnected. you could also use just one speaker, attaching one vioce coil to one channel, and the other vioce coil to the other channel. then, i would suggest getting a second, identical amp to run the second speaker.
if you are persistent on bridging to mono, then you can only use 2 voice coils (both from one speaker, or one from each speaker) and you must run the voice coils in series, that is, from the amp positive to the 1st vioce coil positive, then run a jumper wire form the 1st vioce coil negative to the 2nd vioce coil positive, then, finally, run the 2nd vioce coil negative back to the negative of the amp.
this is all assumming that each voice coil is 2 ohms and each vioce coil has seperate inputs, meaning that each speaker has 2 pairs of speaker terminals.
Oct 08, 2009 | Soundstream SPL 15 Car Subwoofer
We can hear the customers but they can not hear us! Help
Here's the troubleshooting from the manual:
  • Make sure voice tube positioned properly
  • Voice tube is not clogged (remove tube and see if works)
  • Verify transmit volume control of amplifier is set properly
Couple other suggestions to try:
  • Reseat all connections to make sure firm connection
  • Look for any other volume controls
Link to manual for headset:
http://www.plantronics.com/media/media_resources/literature/user_guides/supraplus_ug_en_fr.pdf
Apr 06, 2009 | Plantronics H251 SUPRAPLUS MONO HEADSET -...
2 questions
Hold down the Display/Menu function button (one of those three buttons on the left of the unit) for about 3-4 seconds until the display reads "t set". When this appears, push the track forward button once (>>|) so the display reads "beep"; now press the play pause button (>||) once. The display will now say "on", push the track forward button (>>|) once to make it read "off"; now push the stop play button. You're done. Enjoy the silence.
Mar 14, 2008 | Sony Walkman D-EJ100 Personal CD Player
Staying keyed up after button release
I have never seen this problem before, check if the VOX is activated, this could cause to transmit the radio, but the voice must be transmited. check if the Accesory connector is not dirty, clogged or damaged
Feb 08, 2007 | Motorola Talkabout T5720 (7 Channels)...
Computers & Internet Logo
David Payne
David Payne
