Question about Acer AL1715 17" LCD Monitor
My monitor comes on for approx. 1 minute then blacks out. Any hope?
  • 11,361 Answers
Look at the power supply and caps per Loiue suggestion.
http://s807.photobucket.com/albums/yy352/budm/ACER AL1715b/
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Sep 09, 2010
  • 732 Answers
Ltr2jackie, although your unit is Acer brand, you might want to visit this blog and see if something sounds familiar!!! http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ Do some reading there and then come back to fixya and rate this response and would like more info on lcd monitor power supply repair. Also do some reading in my fixya profile. 12fixlouie
Posted on Sep 08, 2010
Why does my gateway fpd2185w monitor screen go black after showing my desktop for about 1 minute
David
That problem is calle,refresh, thats happend when the monitor try to refresh the page or "clean" the page, you can set that in your video driver options. but if you don't have a video driver for your particular video card already installed, you don't have a right refresh rate and this delay, may happend.
Carl
Mar 22, 2016 | Gateway Computers & Internet
ASUS monitor is plugged into MacBook Pro. Has worked fine over the last 12 months with both screens working independently. Recently unplugged for 2 months. Plugged ASUS back in. After approx.5 minutes, the...
(1) If you have connected windows cpu to monitor then when you power up the computer press F8 key then enter in enable vga mode then go to control panel ->display property -=>settings change screen resolution to 1024*768.
then check .
(2)But if you are not able to see any display on screen then open cpu cabinet and refix ram memory pull cmos cell from motherboard for 10 minutes ,if there is any pci card or vga card installed on motherboard reattach it into motherboard.Then check.
If you have mac book then follow my second solution.
Let me know if you need further assistance.
Thanks for using Fixya.
Apr 07, 2010 | Computers & Internet
I have an hp w1907 monitor i start up puter and after about 15 miniuts the monitor goes black i turn the monitor off and about 5 minutes later i turn it back on and works fine for about another 15 minutes
You could have a faulty inverter board. The inverter supplies high voltage to the CCFL lamp/s, these lamps are mini fluro tubes approx 1,5mm dia. and the length of the screen.
Check the inverter output/inverter board and you maybe able to get parts from
www.lcdparts.net
Dec 13, 2009 | HP w1907 LCD Monitor
Monitor image comes up, then blacks out, power still on
Hello David,
This is very common problem and is heat/age related, but It can happen to monitors that are no more than a year old. It is usually bad capacitors on on power inverter board. I just fixed two monitors with this problem. This problem is common across all brands. Look for several radial capacitors in a cluster on the power inverter board. If some are bulging or have a slightly domed top, they are the ones that are bad. I usually replace all the capacitors in this small cluster because some may be marginal. This is easy to do if you have a bit of electronics skill.
Dec 27, 2008 | Rosewill MNTR |LCD 19' 8MS DVI R912E...
Monitor is blinking out
Hi...there,
It's seems you got a busted backlight inverter problems...
Dec 17, 2008 | ViewSonic VX2025wm 20.1" LCD Monitor
LCD Screen problem
You have a failed inverter circuit. This is a very common fault with BenQ and other LCD monitors. I have seen more FP737 and FP731's and all their cousins in the last 2 years then I care to count.
You will be best to take it to a TV technician and have them do the repair. There are ways to fix it yourself, but the chances of success are not great without a decent amount of electronic knowledge.
Call several places and get approx quotes based on the inverter fault. A lot of TV techs will not work on LCD monitors and is another good reason to call around first.
One final thing, check the manufacture date on the back of the monitor, these normally come with a 3 year warranty and it will be either expired now, or very close to it. If it is still under warranty, then contact BenQ near you to facilitate the repairs.
BenQ support webpage.
Apr 15, 2008 | BenQ FP731 17" LCD Monitor
PC or monitor, signal problems
your monitor is telling you it's on it's last legs..either that or your compaq has a bad video section. either is more vital than a video cable being loose.
Mar 10, 2008 | Computers & Internet
Fp91e
Problem with Inverter circuit.
Check with BenQ They offer a 3 year warranty.
Samir
Jan 19, 2008 | BenQ FP91ESIL (Black) (Silver, Black) 19"...
Acer AL1715 17" LCD Monitor Logo
271 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
