Question about Sharp AL 1631 Copier
Upon replacing the drum on my Sharp AL-1631, the drum indicator light is still illuminated and the copier still won't function. Is there something I need to do after replacing the drum to get it to copy again? People have been talking about resetting the drum counter, but I don't see anywhere in which to do that. Please help!
  • 1,110 Answers
To reset the drum light on your Sharp AL1631 series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
If done correctly the display should go blank.
Then key in 24 as if you were going to make 24 copies.
Now press the "print" button
Now key in 7 as if you were making 7 copies
Now press the print button again.
You should now be getting flashing zero's on the display.
Turn the machine off then on again and your drum light should be gone.
Good Luck and Thank You for using Fixya.
Posted on Sep 08, 2010
After I replace the drum the RED indicator light is still on do I need to re-set the drum or something
Press - CLEAR - DENSITY SELECT - CLEAR - DENSITY SELECT - then 24 and 7 should reset drum counter. press CA to exit
Aug 31, 2010 | Sharp AL 1631 Copier
How do I replace the drum in this machine?
Pul out the drum unit, dismantle it, replace blade, drum and developer.
After that you need to clear drum counter.
Jun 29, 2010 | Sharp AL 1631 Copier
AL 1631. Indicates that a drum has to be
To reset the drum light press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Turn the machine off then on again and your drum light should be gone!
Feb 13, 2010 | Sharp AL 1631 Copier
I have a Sharp AL 1631 copier. The drum replacement indicator came on. I purchased a replacement drum. The indicator continues to blink and the copier will not operate.
You can reset this indicator by pressing these keys in sequence:
Press "C" then press "Exposure Mode" then "C" again then "Exposure Mode" again.
Note that the Exposure Mode key is the far left key on the panel.
One you press these 4 keys in sequence the display should go blank. Then key in 24 as if to make 24 copies. Then press Print (Green Button)
Then key in 7 as if to make 7 copies.
Press print again. You should now get flashing 000.
Turn machine off then back on and the light should be gone.
Here it is in a short version:
C, far left, C, far left, 24, print, 7, print,
then power off and back on.
Nov 22, 2009 | Sharp AL 1631 Copier
I've lost my manual. Does the red light that
The red light that looks like an empty cylinder on the Sharp AL 1631 Grayscale Copier panel is the "drum replacement required" indicator. The "cartridge replacement" indicator is represented by 6 dots forming a triangular shape.
The drum replacement indicator lights up when there are about 1000 copies left until its end of life. It is only when the indicator starts blinking that the drum really needs replacement.
The part number for the drum is AL-100DR.
I hope this helps.
Nov 19, 2009 | Sharp AL 1631 Copier
Sharp al-1631 copier. drum error code
Nov 16, 2009 | Sharp AL 1631 Copier
On a Sharp AL-1631 copier I installed a new TD Cartridge and ????
That must be the drum cartridge symbol anyway do this; Press C, Exposure, C , Exposure in that sequence.The display will go out. Enter 24 press print 07 print. Then press C twice and you are done.
Nov 12, 2009 | Sharp AL 1631 Copier
Fixya: Sharp AL-1631 copier doesn't recognize new drum?
press the following keys in this order:
  1. Clear Key (far right key on panel)
  2. Exposure Key (far left key on panel)
  3. Clear Key (far right key on panel)
  4. Exposure Key (far left key on panel)
once the panel goes blank make your display show
  • 24 then press your start key
  • then 7 press start
  • press C one time
  • 20 press start
  • 1 press start
Then press C until the copier restarts.
Oct 16, 2009 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
134 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
