Question about Dell UltraSharp 1909W 19 inch Monitor
How do I change the input timing on my Monitor
2 Suggested Answers
  • 10406 Answers
SOURCE: Change input timing for monitor when monitor ia
Restart your computer, and keep pressing F8 until you see the Windows "start-up" menu.
Choose "start in safe mode" (to get 800-by-600 mode, which the monitor should accept).
Change the "input timing". Shutdown & restart.
Posted on May 09, 2010
I am using FRONTECH LCD TV tuner MODEL NO:-JIL-0622.Recently connected to my new DELL LED then i was just changing the configuration of screen resolution but somewhere in middle it got stuck later on the...
update your driver of tv tuner for os of your computer.like win7 or win8.
second do windows update for your computer and do update for your graphic card--and do update bios of your computer.
thanks
Jul 14, 2014 | Philips SAA7130 TV Tuner/FM Radio/Video...
Change input timing for monitor when i can't do anything
Hi Austin
it sounds as though you have a problem with your graphics card drivers and your tv will not accept the lower resolution. Do you have another screen that you can connect to prove/disprove my theory? If your tv will not accept the lower resolution input then you need another screen to enable you to sort it out. Hope this is helpful.
Feb 19, 2013 | Computers & Internet
I have a lg flatron LCD w1934s-bn when I switch on the computer display coming and with in seconds monitor going in power saving mode. I change the VGA cable, change the system also same problem.
If your monitor goes into Power Saving Mode with different computers, it is most likely the signal input board in the monitor. I'm sorry to tell you your monitor is shot. It is probably repairable if you can find the correct board. Monitors are relatively inexpensive at the moment, and going by the "VGA only" input, it is time to upgrade, You will also get better resolution and picture quality.
Apr 20, 2012 | Computers & Internet
May 09, 2010 | Dell Inspiron 530s Desktop Computer...
How to change input timing without a monitor
you will not able to do it without a monitor. you'll need to get another montior in order to change the settings on computer. you need to change the resolution on that computer. sounds like the resolution is either too big or too small that it will not display it.
Oct 17, 2009 | Computers & Internet
The screen powers off very often but turns back on upon pressing the input button but offers no other input options
had the exactly the same problem with exact same monitor, if under warranty get it changed else get a replacement. Monitor is overheating after a certain period of time.
Sep 30, 2009 | Dell E228WFP LCD Monitor
No DVi input, then computer goes to sleep
Hi publicworker,
I had a similar problem whereas my monitor went to sleep mode after a few minutes. I'm running an HP LP 2065 in dual mode with another HP flat screen. However, I did resolve the issue after resetting the output settings.
How to do that:
  • right mouse click on the desktop
  • select graphic options
  • output to
  • extended desktop
Maybe some changings/modification will help you too.
Stefan
Jan 31, 2009 | HP 2025 20.1" Flat Panel LCD Monitor
Benq FP222W
Your monitor must have multiple inputs (Dvi,D-sub) so it searches when you start for which input is connected.
If menu popping up intemittently is your problem,The culprit is generally defective (Leaky) Key switches.You need to pen up monitor and replace.
Normally BenQ has a 3 year warranty.
Dec 28, 2008 | Computers & Internet
Dell UltraSharp 1909W 19 inch Monitor Logo
433 people viewed this question
Alun Cox
