Question about KitchenAid KSCS25FKSS Side by Side Refrigerator
Our freezer is not making ice any longer. How do we fix it?
  • KitchenAid Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Posted on Sep 11, 2010
Can I fix refrigerator that no longer defrosts?
maybe it some sort of losing your freon you may need to refill it again but first do this //
1. check the bottom of your fridge, there is an air intake grill at the bottom, make sure this is clean and free of lint/ dust
2. make sure the thermostat inside is set properly
3. don't overload the freezer section. the cold air for the fridge comes from the freezer, and if you have too much stuff in the freezer, it will stop the air from being able to flow to the refrigerator section
4. Finally, if you're a little bit technically capable, check the back of the refrigerator, for a small 1/8" hose going down the back of it- make sure this line is clear and free of gunk
May 17, 2014 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker has water but no ice
HI.TERRY.freezer has to work at its optimum.for the ice maker to work. i would try to defrost the freezer completely first and try.good luck.Ali
Jun 28, 2012 | Samsung Refrigerator Ice Maker -...
System working make smell ice filter clean water flowing
check the float. May need to be lowered. Also, check the length of the freeze cycle. Should be at least 20 minutes but usually longer on Hoshizaki machines
Oct 16, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Freezer light, ice maker, and ice/water dispenser stopped working
did you replace the light . or just tighten it . and is ice cream soft . it sounds like the tempt is above 15 deg . and needs to be colder . this may be a control problem . but ck the little things first . clean the coils / make sure inside fan and under neath fan are going . re ck control settings . .. if problem does't go away . then look at control ..
Jul 29, 2010 | Frigidaire Refrigerators
Frig no longer cold
Hi, look inside freezer and see if there is a frost build up on the rear wall. Also listen to see if the evapotator fan motor is running.
Please let me know so I can assist you further.
Vic
May 27, 2009 | Frigidaire Freezer Refrigeration White...
Kenmore model 46 76249 (22 CU F OVR
Freezer must be 12* F for making ice
May 13, 2009 | Kenmore Refrigerators
Water line to ice maker frozen
Check to make sure that the damper between the freezer and fridge is not broken or frozen open. Make sure that you shut off the water supply to the fridge until you get this fixed because the line could crack and then you could flood the house.
Jan 20, 2008 | Whirlpool GS6NBEXR Side by Side...
Jen aire ice maker not working
change filter and defrost water lines if frozen
Dec 10, 2007 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Ice maker is not getting water.
check and reset the temp in the ice maker freezer coils them self's
Aug 08, 2007 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
KitchenAid KSCS25FKSS Side by Side Refrigerator Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
