Question about Baby Lock Esante
MY Esante touch screen is off by about 1 cm low. If I touch about 1cm lower that the icon it works. I can live with that, but the help, layout, tension forward and reverse icons are at the bottom of the screen and I cant get those to work. I am well out of warranty so thats no help. Does anyone know how to get the cover off- I am hopefully that the screen just slipped down a little. Thanks
  • 19,396 Answers
Hi.
Touch the screen and keep holding the finger on the screen, while turning the main power off and then back on at the same time, the screen should go in self calibration.
If that does not work, contact Baby Lock using this form (click) and ask the display calibration procedure for this module.
Posted on Sep 08, 2010
Flashing Display, Won't Connect to Computer.
I have not yet seen babylock release a driver for windows 8 and the BLN. The dealer likely has a computer with an older operating system.
Jun 09, 2015 | Baby Lock Esante
Reset button on Esante ESe2
1. Turn the power on while holding down the [Start/Stop], [Reverse stitch], and [Needle position] buttons.
2. Touch the positions marked with crosses (+) on the touch panel in order from 1 to 5.
NOTE
• Setting is successful if a single beep sounds when "5" is pressed.
• An error has occurred if two beeps sound when "5" is pressed. Repeat from position 1 again.
3. Turn the power off and then on again. Check that the screen display matches the positions on the touch panel
May 17, 2015 | Baby Lock Esante
Touch screen
the machine should be checked to see if there is something wrong with the motherboard.
Sep 03, 2013 | Baby Lock Esante
My touch screen is offabout one half inch how can i fix it?
the touch screen is part of the computer & since it's about 1/2 inch off the I suggest taking it to a sewing machine shop to fix it. a part of the computer may need to be replaced.
Mar 04, 2012 | Baby Lock Esante
Won't work at all-esante ese baby lock
Check that the button used to snip your thread at the end of your seam is not stuck. Mine will sometimes stick and if I just touch it again it will again activate and the red start/stop button will work again.
Apr 08, 2009 | Baby Lock Esante
Can't see LCD on Babylock Esante
When your BabyLock Esante ESi2 is otherwise working fine but the LCD display screen begins to grow darker and you find you just can't read it, the only thing you can do is replace the BabyLock Esante ESi2 LCD screen, or buy a new machine. BabyLock no longer stock this item direct, but there is an affordable replacement available....Check this Link
Feb 28, 2009 | Baby Lock Esante
Touch screen very light
I selected the basic operation, adjustment, then brightness of lcd.
Nov 15, 2008 | Baby Lock Esante
My touch screen doesn't always work. Sometimes I have to touch all around the square and even then, it won't come on. At times, it stops working when I want to change patterns. It seems to work most of the...
Yes, I have a solution for this problem. Your screen needs to be recalibrated and you can do it yourself. Don't you wish they would just tell you this stuff instead of charging you an arm and a leg? Here's what to do: Before turning on the machine, press the start/stop button, the reverse button, and the needle position button all at once with one hand (one finger on each button). Hold them down and turn on the machine. What will come up is a recalibration screen. You will see the numbers 1-5 with a little plus sign beside them. Find a small blunt object (I used the tip of a mechanical pencil with the lead in instead of out) and while holding the start/stop button, touch the plus sign beside 1-5 in numerical order. Then, turn the machine off and on again in the normal way. This should recalibrate the screen. Pass it along, people! This is something no one should have to pay for!
Nov 03, 2007 | Baby Lock Esante
Sewing Machines Logo
256 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
SewTechWayne
SewTechWayne
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
