Question about Yard Machines Garden
I have a yard machine 42 inch cutting deck 14.5 HP.The blades will not disengage.How can I fix this?
  • 472 Answers
Ck to see if the spring is broke it has one that pulls it back
Posted on Sep 08, 2010
Yard works 4.5hp 42" cut lawn tractor cuts fine when mower deck is up on 4, but when it is lowered it cuts out and won't cut the grass.
4.5 hp will not power a 42 inch deck any way you cut it quite likely the blades need sharpened real bad .motor needs to run fast when tryng to cut also as that throws the grass out of the deck
May 27, 2015 | Garden
I changed the deck drive belt & the baldes spin but when I lower the cut height from the highest setting(5) down one (4) the blades spin slows down too much & it's not cutting the grass. I need to...
Sounds like you had to change the belt because their is too much resistance in the shafts that the blades are attached to. This may be from grass. Anyway, that is where I would check, to make sure everything turns freely when not connected to the belt .
May 17, 2014 | Yard Machines 13AN772S000 42-Inch 500cc...
I have a yard machines 46 inch cut 18.5 hp riding mower that wont start. i changed ignition swith and soleniod. if i cross wires on solenoid it will start after putting gas in carb. it runs till gas runs...
I would start with the safty switches. Look for them on the deck engager, seat??, break/clutch pedel,blade engager lever. Remember the blade sw. must be disengaged be fore it will start. Ifit runs as you said It is in the wiring/ electrical system. I know it is not in the ignition sw. or seloniod. szm230
Apr 15, 2011 | Yard Machines Garden
42 inch jd la115, hit stump in yard, changed blade cause I thought I bent the baldes still cuts uneven. Could the shaft be bent or broken? It appears to be cutting properly on the right side but the left...
try pushing the blade up into the deck,,,if there is any lift in it there is the fault,,the top nut has come off the blabe drive pully and let the drive shaft drop a little this will lower the cutting blade,,,fix it before the blade falls right out
Aug 15, 2010 | John Deere Garden
My riding lawnmower blades will not disengage or engage Now my lawn mower will not start
just replaced some pulleys on my craftsman 42 inch cut and now the blades are ingages all the time, but it will start
Jul 17, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a Kraftsman 91.5 42 inch cut model #
Safety switch at seat or reverse. Mower will cut of when blades are engaged if you get off the seat or put into reverse. Check these switches for stuck on, damaged, disconnected, or just plain broke. Good luck.
Mar 19, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed My mower is a 42 cut and leave a row in the middle of the cut
SOUNDS LIKE YOU HAVE A BENT BLADE TRY PUTING A 2X4 UNDER THE DECK THEN LOWER IT TO HOW IT LOOKS IF ITS THE SAME ON BOTH SIDES THAN YOR BLADE IT BENT
Sep 30, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I have a problem with my cut deck on a ys4500 42" yard tractor. one blade has play in it between the pulley and the blade. The blade cuts gouges in my yard, how do I fix this?
You need to replace the bearing.This job is best undertaken by two people, (because it makes it easier) and with the use of oxy-cetalene, to free off the fixing. Because generally they seize on.
There ya go. Happy gouge free mowing.
Jul 27, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Engine cuts out when engaging clutch or engaging blades..
lift the seat and make sure the connector is firmly plugged into the seat switch
Jun 01, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Garden Logo
580 people viewed this question
Top Yard Machines Garden Experts
Phil Walker
Phil Walker
Dean Gruber
Tim Whalen
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
