Question about Shure Beta 58A Professional Microphone
Hi the front of my shure58a beta is broken on the front but Ive always been using a hairgrip to flick the switch across and make the green light go on but tonight its not working and the light is staying off.any ideas?
    Prodigy:
    An expert who has answered 500 questions.
  • Shure Expert
  • 611 Answers
I'm guessing that you have a wireless microphone. It appears that the transmitter will need to be sent to Shure for repairs.
Shure Service
Posted on Sep 13, 2010
Break light not coming on on my motorcycle whats the problem?
could be the globe or the actual brake switch or a short
you will need to remove the tail light cover to check the globe usually with a phillips screw driver remove the globe by pushing it in and turning it to have a look inside there will be two spring bars across the top of stems inside the globe on might be broken give a flick with your finger the broken one will vibrate
hope it helps
May 15, 2012 | Suzuki GSF 1250 Bandit Motorcycles
Hi i have a injusa battery childs car,when i attached the charger plug the green light goes off,but when the charger is not attached to the battery and i flick the switch to on,the green light comes on...
Hi, Check the charger that it is charging.Use a volt/ohm meter to check for power on cable. If battery does not hold a charge. replace battery with new one. Hope that helps.
Nov 27, 2017 | National Kids Mini Cooper Racer Ride On...
I need a radio wiring diagram
Constant 12V+ Green/Purple
Switched 12V+ Yellow/Black
Ground Black/Light Green
Illumination Light Blue/Red
Dimmer n/a
Amplifier Remote Blue
Antenna Right Front
Front Speakers 5" x 7" Doors
Left Front (+) Orange/Light Green
Left Front (-) Light Blue/White
Right Front (+) White/Light Green
Right Front (-) Dark Green/Orange
Rear Speakers 5" x 7" Rear Doors
Left Rear (+) Gray/Light Blue
Left Rear (-) Tan/Yellow
Right Rear (+) Orange/Red
Right Rear (-) Brown/Pink
best wishes
Jan 01, 2011 | 1992 Ford Explorer
The DELL E172FPb LCD Monitor (switch light flicks green)scr black
hi, extremely common problem for dell 17 in monitors. the capacitors and transistors on the power board internally have gone bad. to get repaired, it may cost 40-50 at a shop. i have repaired these in the past and they always come out well for at least 3 more years. may want to find another monitor though. if you would like steps on how to repair, let me know and i will find my old repair threads to give to you.
May 12, 2010 | Dell E173FP 17" LCD Monitor
My hi beam head light gose on and off by it self.. every ones a wile the hi beam light will start coming on and off like i was flicking it my self
it is most likey the switch itself.that joint gets loose from using the turning sigals.so some people put a matchbook cover behind the switch.whenever i ask why they do that. they always tell me to fix the problem you are having.they just stuff it in there.I personally think the switch should just be replaced.about 200.00 at your local shop.
Mar 11, 2009 | 1999 Ford Explorer
Front sidelights and tailights inoperative
the switches are a nightmare they always play up,if your good with a multimeter check the supply at the switch (feed in)flick the switch to on and check the output,no input broken or damaged wire or relay if you have input but no output its a switch fault....
Jan 29, 2009 | 1999 Ford Escort
Grey cable in dash
Hi again,
Appreciate the update and additional information. If I understand it right, your vehicle then has two connectors at the back: 1 big black/red/gray plug:
  • Yellow/light Green - always ON B+12;
  • Yellow/Black stripe - ACC B+12 goes to the IGN switch;
  • Black - chassis/ground;
  • Blue - remote trigger for add-on amplifier (if connected);
  • Blue/Red stripe - illumination (can go to parklight switch).
and the 2nd smaller gray 8pin plug:
  • White/Red Stripe Right Front +
  • Brown right front -
  • Green Left Front +
  • White/Orange Stripe Left Front -
  • Light Blue/Black Stripe Left Rear +
  • Yellow Left Rear -
  • White/Blue Stripe Right Rear +
  • Light Blue Right Rear -
Cheers.
Aug 28, 2008 | 1994 Ford Explorer Limited
Car stereo wiring (1993 Ford Taurus GL)
My guess is that ford did not change that much in a year.
1994 Ford Taurus Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Green/Yellow
Radio Ignition Switched 12V+ Wire: Yellow/Black
Radio Ground Wire: Black/Light Green
Radio Illumination Dimmer Wire: Light Blue/Red
Radio Antenna Trigger Wire: Orange/Blue
Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Green
Right Front Speaker Wire (-): Green/Orange
Rear Speakers Size: 5′ x 7′
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Pink/Light Green
Left Rear Speaker Wire (-): Dark Blue/Orange
Right Rear Speaker Wire (+): Pink/Light Blue
Right Rear Speaker Wire (-): Tan/White
Jan 13, 2008 | Car Audio & Video
Shure Beta 58A Professional Microphone Logo
79 people viewed this question
Top Shure Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
Jerry Greenberg
Jerry Greenberg
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
