Question about Evenflo Generations
How do you remove the cover and belts on an evenflo car seat with this number on the side 25801158?
    Problem Solver:
  • 12 Answers
Turn the booster seat around to the back and locate the metal splitter plate that the harness is attached to. Remove both harness straps from the splitter plate. Locate the TensionRight knob located on each side of the seat in the front by the baby’s foot area. Turn the TensionRight knob to the back as far as it will go to take up the slack on the splitter plate strap. Pull both harness straps through the seat back to the front of the seat. Remove the harness strap from both sides of the chest clip and from the buckle tongues. NOTE: Please leave the buckle tongues locked into the **** strap for storage. Remove the harness strap from the seat. NOTE: Reattach the chest clip to the harness strap so they don’t get lost. Turn the booster seat upside down and locate the metal harness anchor. Turn the metal anchor sideways and push it through the slot to the front of the seat.
Posted on Sep 09, 2010
How to convert symphony car seat to booster seat
Watch these 2 instructional videos on how to convert the Evenflo Symphony car seat here:
http://www.evenflo.com/support.aspx?id=452
http://www.evenflo.com/support.aspx?id=460
Aug 12, 2012 | Evenflo Baby Gear
Hi, how do i attach the belt clip that comes with the evenflo booster seat?
If it is the one that is on the end of a strap, at the end of the strap is a loop.
Feed the loop thru a small set of holes in the back of the seat. The seat should have 2 small, close to eachother, holes. It goes in one, out the other and then slide the clip thru the loop and pull it back tight.
The only other design I know of uses a screw to attach the belt, the clip is on, to to a nub with a hole in
it on the back of the car seat.
If by "clip" you mean the little bracket that looks like an "H" you thread the car's seat belt thru it, where the belt goes up to the highest point, and use the H clip to keep that part of the car's seat belt away from the child and car seat by weaving it behind the edge of the car seat.
Use Evenflo's site to download a free manual and it shows you how to do it. All you need is Model number and date of manufacture and it will give you your manual. Save it to your computer. Click this link.
Evenflo Care Seat Manual Downloads
Mar 17, 2011 | Evenflo Baby Gear
Needing to know how to remove the seating cover and belt harness for the Evenflo model 3971536 L1 car seat
hi here is a link that may help not sure if correct without the date of manufacture just double
check the date
https://plweb.evenflo.com/product_search.aspx?txSearchModelNo=3971536%20L1&txSearchDOM=1/1/2010
Oct 22, 2010 | Toys
Take cover off to clean
If you go to this site you should be able to get the instructions for your model car seat. https://plweb.evenflo.com/replacement_parts.aspx It will be helpful if you know your model number and date of manufacture.
Thank you
Apr 30, 2010 | Evenflo Triumph 5 - Playwright Ash
HOW DO I REINSTALL THE BELT FOR MY EVENFLO GENERATIONS BOOSTER SEAT?
you can use from your seat belt of the car and pass the seat belt on the back of the car seat .also you can use the hook of the car seat.
Aug 19, 2009 | Evenflo Generations
Model Number on my Evenflo On My Way Travel System - Need Cover
My used Evenflo On My Way travel system model number for the stroller is 4951F7. The model number on the car seat is 4951F7P2.
Question for you - Is there a front tray to snap on when not using the car seat? Mine is missing that part. Thanks.
Feb 23, 2009 | Evenflo Aura Traditions Travel System...
Instruction for installing Evenflo Triumph Car Seat. We are the grandparents and our granson is staying with us for a few days. Our daughter is loanig us their car seat, but won't be there to help instal...
On the back of the car seat you should have a black hook with a safety latch on it connected to a adjustable strap. You will require an anchor point to connect this to in the back of your car, depending on your car (sedan, station wagon,4x4 ect) your anchor point will have a small removable cover over it about 1 inch square or so, if you have not got one already installed make sure you get the anchor as well. This will be a small metal latch with a spacer and bolt with a safety nut the nut goes under the bottom of the parcel shelf if it is a sedan if not you won't need the nut. The the hook will attach to the anchor and then you just loosen the adjustable strap out until it is fairly loose (about 3 or 4 inches of play between the car seat and the baby seat will be fine) now if the baby is small and needs the seat to lay down ie they can't hold there head up or are to small to face forward, have the head end of the baby seat to the front of the car and set the seat belt throught the hole thats horizontal to the car seat. If they can face forward same thing just stand seat upright and feed the seat belt through the horizontal holes. The hole for the seat belt should be about 2 to 3 inches high and about 4 or 5 inches long. Just becareful not to put the seat belt over the childs belts on the baby seat. Then just tighten the adjustable ******** the baby seat until firmly tightened against the car seat and you are done. The baby seat will still move a bit from side to side but if it moves more than 3 inches or so tighten the adjustable strap even more.
Jul 26, 2008 | Evenflo Triumph 5
How to use seat belt with seat
Here is the link to the product page for the seat; http://www.evenflo.com/Default.aspx?tabid=203&productid=2b49c217-5716-4e6a-bf7a-0895dd0fe596 click on "demo" and you get a few videos showing how to install etc. Check this link for FAQs about the model; https://plweb.evenflo.com/faqs.aspx?catid=9&subcatid=806 and this link for the full user manual; https://plweb.evenflo.com/replacement_parts.aspx Basically what evenflo say is that if you can't teach the child not to climb out, you need a different type of booster with a traditional restraint. if thrown forward as described the belt should function as usual for an adult, assuming the belt is correctly positioned on the child. Contact evenflo on; http://www.evenflo.com/Home/ContactUs/tabid/175/Default.aspx if you have any doubts at all. They can also point you towards a qualified installer who can verify the safety or otherwise of your setup. Sorry if not great news, hope it helps keep your son safe :)
Jun 27, 2007 | Evenflo Big Kid Deluxe - Fairbanks
Need Installation Manual for Evenflo Generations Car/Booster Seat
Just in case you don't still have the number; 1-800-233-5921, Monday - Friday from 8 am to 5 pm. I've asked them to send me a manual but i doubt if i can get it before the end of the holidays - here's hoping. :)
Apr 06, 2007 | Evenflo Generations
Evenflo Generations Logo
899 people viewed this question
Top Evenflo Baby Gear Experts
Joyce Nokleby
Shehu Pro
Shehu Pro
Rick Moore
Rick Moore
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
