Question about Echo Garden
I have a 452 echo. lost the manual in a move. the boys 8-9 decided to tune up the saw and now I can't get it running...can you help me with the begining setings..Thanks John
    Brigadier General:
  • 4,088 Answers
Likely, they have adjusted the H and L jet needles and maybe the idle speed screw. Turn both jet screws CW to stops (lightly), then back out each CCW 1-1/2 turns. This is a basic setting and should let the engine start and run. Start the engine and let warm up, then pull the throttle full on. Adjust H jet needle CW until the engine starts to speed up, but 4-stroking. Proper adjustment is when the engine 4-strokes unloaded, but immediately 2-strokes when cutting. Release the throttle and adjust L jet needle CW for better idle, but allows the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops turning, but allows the engine to continue to run. Hope this helps!
Posted on Sep 09, 2010
I want to wire my superstar dm452 power echo mic to my realistic trc 465 am ssb and need to know what color goes to what pin?
its a 5 pin which all radshack radios are and they are all,99% anyway, wired the same . So take an old radshak mic apart at the plug and see how it is wired then experiment from there.
Apr 07, 2015 | Workman Publishing Workman DM-452-5 model...
Echo chain saw has no spark how to fix
Not being facetious here... change the spark plug as a first step. They require regular replacement. If that doesn't work, use a multimeter to check that the spark plug wire is actually releasing electrical pulses. If it isn't, you'll need to keep moving further up the line to the coil.
Sep 01, 2014 | Echo Chain Saw Service Repair Manual...
I have a Echo 452 CS, exchanged piston and rings, engine starts and runs perfect only when I start cutting wood the engine dies immediatly. Air filter is clean, spark is OK. What could be the problem?
Fuel starvation, either due to a blockage in the fuel filter in the tank, or a split fuel hose, or dirt in the carb, it may also be due to the carb settings set too lean, when you re fitted the new piston are you sure the base gasket was correctly seated? and any pulse holes were not covered ( gasket correct orientation ).
Oct 05, 2012 | Echo 452 Chainsaw Piston Cylinder
I purchased an Echo CS-400 a month ago, put the oil in the gas as required, and after using it for an hour, it stopped and would not start. I brought it for repairs to a shop, and they told me the pistons...
Hi, basically this is partially correct. It will have this damage with not enough oil added to the fuel, also by having the incorrect type of oil added to the fuel. Also all new saws must be tuned rich for the first 5 litres of fuel consumption to allow for run in. If the dealer tuned the saw prior to delivery you could try this argument. First I would take it to another dealer and get them to verify that the high speed mixture screw is at least 1 and1/8th turns from seated. If not it was tuned too lean. Hope this helps, regards Phil.
Sep 01, 2011 | Echo CS400 18" Chain Saw
I would like some advice on how to tune a cs 3400 echo chain saw
Hi, you can't tune these, so if its not running smoothly, check air filter, clean and replace. Check spark plug, clean if necessary and replace. If problem persists it could be dirt in the carbretta, so flush this out with clean fuel, after this, drain fuel tank and replace with fresh fuel, ensure you have the correct mix of fuel.
Hope this helps
Aug 19, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
A fellow firefighter was cutting with his Echo
The cylinder (if engine running too lean) would be badly scored as well as the piston and rings. Knowing today's prices for parts and labor, $300 is probably not too far off. At that price though, he might consider replacing the entire saw rather than repair. I have noticed a number of Echo saws that don't seem to 4-stroke when running at speed, but not cutting. A properly tuned 2-stroke should always 4-stroke at speed, but immediately 2-stroke when cutting--this produces the most power and least heat. The fuel should always be premixed in the can, agitated well during mixing and again before using in the saw. Agitate the saw after adding the new fuel as well. At 50:1 ratios, there isn't much spare lubrication in the engine. He might consider another brand of saw if buying new. Hope some of this helps!
May 10, 2010 | Garden
ECHO CS 3000 chainsaw-while idling, shuts off if held on an angle
The idle speed screw may be set too low--adjust so that the chain stops moving, but the engine keeps running. Drain the fuel tank and see if the filter falls to the lowest point of the tank whatever the position. If it doesn't, replace the fuel line hooked to the filter as it may have lost flexibility. Hope this helps!
Apr 11, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Would like info on wiring dm 452 echo mic on icom 400 pro
There is a users group on yahoo that you could join and ask your question. I am not too familiar with this radio and this is the best I could do...
Jun 23, 2009 | Uniden Bearcat Pro PC68XL 40-Channels Base...
John deere chain saw model ev55 (1986)
I don't know where you can get a service manual. You've described the symptoms of a dirty clogged fuel filter down inside the fuel tank at the end of the fuel pickup.
Carl
Nov 02, 2008 | Electrical Supplies
Garden Logo
115 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
