Question about Intermatic Inc. ST01C Digital In-Wall Timer
I programmed the timer to go on and off at a specific time and it doesn't work. The time of day and the date are working fine. It is only programmed for one light.
To program the ST01C:
http://waterheatertimer.org/ST01C-program.html
ST01C manual:
http://waterheatertimer.org/Intermatic-st01c.pdf
1) Manual has troubleshooting. Since ST01C is battery operated, it will not work on loads farther than 100 feet away from timer. If a wire is buried underground, this can interfere with operation. Other electrical devices can interfere with timer operation.
2) Solution:
a) Check for interference issues listed above.
b) Press MODE and make sure it is set to AUTO. If timer will not enter AUTO then no program has been set.
c) Re-check your programming as shown in step 6 of manual. Remember timer offers 40 programs. To set Program 1 >> 'on' time has to be entered and saved for Program 1 >>> and then 'off' time has to be entered and saved for Program 1. And then press MODE and set to AUTO.
Posted on Sep 21, 2010
How to set specific dates to water with my T1030D? I don't need daily frequency for cool weather time. There is fequency dates to chooce on T1030, but not with T1030D.
1) Sept 2011.
If you have a T1030D timer instruction manual, then that would be helpful for many people.
Scan manual into .jpg format (file format) and then post images on Flickr.
Add a comment with link to those images so expert can access the information.
2) Currently the only instruction manual is the following, where you can also send information saying what your instruction manual says:
http://waterheatertimer.org/pdf/Instructions-for-setting-Gardena-T1030D.pdf
http://waterheatertimer.org/How-to-program-Gardena-C1060.html#manuals
3) That being said:
Let me add some guessing, and then you can add a comment with what you observe.
Between us we might be able to work out a solution.
4) I don't think you can set specific dates on either T1030 or T1030D
It appears the T1030D is a weekly timer, just like T1030.
The word 'date' does not appear in T1030 manual except 'date of purchase.'
http://waterheatertimer.org/pdf/Gardena-1030-MANUAL.pdf
5) T1030D: each day of the 7-day week is broken into hour 1 through 24.
Each day can have between 1 to 3 settings. I think this is frequency.
You can set the watering run-time from 1 to 120 minutes for each set time.
Sep 01, 2011 | GARDENA Water Timer
Hey i;m hector : MY PROBLEM / 7 DAYS SETUP NO WORK ; ( ej: TIME ON 8.00PM- TIME OFF 5.00AM( SEME DAYS MONDAY TO SUNDAYS?
Hi Hector.
You posted under ET171C8.
You have the timer in front of you, and whole manual cannot be repeated. So there are two options
1) Free option: Add a comment and say specifically where the programming is tricky. If you don't understand the buttons, or if display doesn't show, or if you can't find all days by pushing day button, or if you can't find the am pm choice.
2) Pay for fixya expert to walk you through each step via e-mail.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/et171c%20-%20english.ashx
http://www.intermatic.com/products/timers/electronic%20time%20switches/7%20day%2030%20amp.aspx
If display shows, then battery is correctly installed.
Instructions copied from manual:
1) RESET TIME SWITCH: Press the recessed RESET switch to reset the
microprocessor and delete any set point information which has been
programmed. NOTE: DO NOT press RESET after programming has
begun or you will lose all of your program information.
2) TO SET TIME AND DAY OF WEEK: Place the three position selector
in PROGRAM and the two position selector in CLK mode. Press the
HOUR, MINUTE and DAY buttons individually to select the current time
of day (12 hour AM/PM repeating) and the day of the week. Day 1 is
Sunday, day 2 is Monday, etc.
3) TO PROGRAM SET POINTS: Select PROGRAM mode with the three
position selector and OUTPUT mode with the two position selector.
Press the HOUR and MINUTE buttons separately to program the first set point time desired.
Press the DAY button to select the day the event is to occur.
Press the ON/OFF button to select an ON or OFF set point.
Press the ENTER button to enter that set point for the selected day.
Note that the ON or OFF indicator stops flashing only after pressing ENTER. If this set point is to occur for other days of the week, simply press the DAY button to select the next day then ENTER. Repeat for any additional days. Note that this allows you to utilize one set point for
any or all days of the week.
Then set timer to AUTO for programs to operate
Apr 26, 2011 | Intermatic ET171C8 Electronic Timer
I have GE Model #15089 digital timer. I want to reset time to come on to 7:30 pm and turn off at 10:30 pm. It was previously coming on at 6:00 pm and off at 10:30 pm and working fine but when I tried...
The problem with answering questions where somebody cannot program a timer, or programming stopped working, is that expert doesn't know if timer is defective, or needs to be reset, or timer has conflicting programming, or if person has mis-read the instruction manual, or if wrong button sequence is being used, or if internal battery has gone bad, or if circuit has interference or loose wiring, or if light bulb burned out, and however expert guesses, the person asking question is unhappy because the timer still doesn't work and/or the manual still doesn't make sense.
I work with timers every day and suggest the following steps to get started:
Reset timer and try setting program again.
Write out steps in manual at point where timer doesn't seem to work.
Double-check that you are pushing correct buttons all the way down.
Make sure same days of operation are selected for ON and for OFF. For example if ON is set for all days, and OFF is set for Tuesday, then timer will not work as expected.
Reset timer and make sure there are no conflicting or overlapping programs, or timer will not work as expected.
Test outlet with cheap circuit analyzer from home center, try timer on different outlet, try timer on different Load, check that Load works when plugged into outlet without the timer.
Save some headaches listed above, and buy another 15089 at Home Depot and return defective one in new package.
http://waterheatertimer.org/GE-timers-and-manuals.html#15079
http://waterheatertimer.org/Woods-timers-and-manuals.html#troubleshoot
Add a comment for more free help
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 25, 2011 | Hardware & Accessories
I have a double pol 208 dgm100 and i conect whith contactor and i cant able to program please can you help
Tork digital timers and manuals appears on following link
http://waterheatertimer.org/Tork-Digital-timers-and-manuals.html#DGM
DGM100 programming manual:
http://waterheatertimer.org/pdf/TORK.DGM100.INSTALL&OP.pdf
DGM100 is single channel timer, so timer operates all Loads at same time.
In other words, if you have 2 different contactors, the timer cannot set different schedules for each.
7-day programming
32 set points
Programming buttons:
1) When powering up the unit, model number 100P appears on screen.
LCD displays 12H which is an automatic (AM/PM) format.
Press ENTER to keep 12hour am pm -or- press HOUR to change to military time, and then press ENTER
2) Unit is in RUN mode and time displays.
3) Set current time:
Press DAY/Month key to select current Day.
Press HOUR key to set current hour (with AM/PM).
Press MIN key to set current minutes.
Press ENTER key to confirm.
Unit now stores present time. Seconds are set to zero.
4) Daylight savings time (DST) automatically adjusts for daylight savings time, if you choose this option.
In step 3 you set current time, but you did not set the Month and date.
YES DST: If you want DST then follow step 5 and enter Month and date.
NO DST: If you don't want DST, then skip Month and date, and move forward to step 6
5) Set month and date.
Press MODE until DATE displays
Press Month button to set current month
Press Date button to set current date
Press ENTER to confirm
6) Set programs
Press MODE key until SET displays
Display shows --:-- 01 which is program1
-Press DAY/MONTH key to set day(s) you want program1 to turn ON
Following are choices that display on screen:
MO to FR (MO, TU, WE, TH, FR)
SA and SU (SA, SU only)
MO to SA (MO, TU, WE, TH, FR, SA)
SU to SA (SU, MO, TU, WE, TH, FR, SA)
Individual days: SU, MO, TU, WE, TH, FR, SA, and D
for Special Day (usually a holiday).
-Press HOUR key to set hour {check AM/PM} you want program1 to turn ON.
-Press MIN key to set minutes you want program1 to turn ON.
-Press ON/OFF button to select ON, and then program1 will turn ON at your set schedule.
Press ENTER to confirm setting.
Display now shows --:-- 02 which is Program2
-Press DAY/MONTH key to set day(s) you want program2 to turn OFF
Choose same days you chose for Program1 ON so timer does not have conflicting programs.
-Press HOUR key to set hour {check AM/PM} you want program2 to turn OFF
-Press MIN key to set minutes you want program2 to turn OFF
-Press ON/OFF button to select OFF, and then program2 will turn OFF at your set schedule.
Continue setting up to 32 different programs.
When finished programming, press MODE button until RUN appears
Manual shows more programming options such as override, reviewing programs, setting special days.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 04, 2011 | TORK Timer 1 Channel Signal Timer Dgs100
Intermatic Timer HB88RC unable to program it following instructions. Will not turn on in Automatic mode. Works fine in manual On mode.
HB88RC manual online:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/hb88rc%20-%20english.ashx
These timers are frustrating sometimes, fortunately this timer can be unplugged to set programs under good lighting.
When I have problems, I set it down for a while and then go back to it later.
Right now I own 25-30 different Intermatic, Woods, GE, Utilitec timers for testing and programming difficulties. Each one offers different points that are confusing.
Some new timers are simply defective. One guy today had 2 defective Woods timers, which made me suspect electric line needs line analysis. You might try your timer in another plug, for example indoor plug in another part of house to double check line is not interfering with timer electronics.
Reading HB88RC manual, there is not Dusk-dawn option, and programming steps are pretty straightforward compared with other timers.
This leads me to believe there is some small thing missed or line is bad, or timer is defective.
Return it if it's defective.
Here are some trip-up points, and they may not apply to you.
1) Current day has to be set. Hold clock button down while setting current time.
2) When programming, each event requires ON time and OFF time. For example event1 ON has to be set and then event1 OFF has to be set. Then set event2 ON and then event2 OFF.
3) When programming, check screen carefully to make sure 1ON appears, and then 1OFF appears in screen exactly like Fig1 and Fig3 shows.
Now I frequently e-mail Intermatic asking for manual clarification, and they e-mail back ... sometimes their manuals are a little bit off here and there. But this manual looks clean and matches what I see in other timers.
4) Each ON time requires OFF time for same choice of days. For example ON 7pm Tuesday and OFF 9pm All-days-of-week will not work correctly.
5) ON 7pm Tuesday and OFF 7pm Tuesday will not work.
6) Conflicts in programming cause some timers to skip programming: For example event1 says ON
at 7 pm Tuesday and OFF 9pm Tuesday, but event2 says opposite.
7) Since manual override works correctly, we know Load is functioning, and we know plugs on timer are working. Timer load can be lighting or pumps or heaters, but manual does not specifically say florescent. So timer MIGHT not work for compact florescent bulbs. If you have CFL bulb, try another type of Load: for example incandescent table lamp.
And that's everything I know, like Bubba Gump shrimp.
Nov 25, 2010 | Intermatic HB88RC - 7-Day Programmable...
My ST01C works fine for a few days and then resets itself. The clock flashes 12:00am every time it resets and their is no pattern to it resetting. Sometimes it works for 2 days; sometimes 4-5. I reprogram...
My guess, it's the battery... Manual has troubleshooting steps that point to battery.
1) Timer requires CR2 battery to work ... double check markings on your battery. Programs will not function without battery. Battery can be low without BATT warning on screen.
2) ST01C has 1 year limited warranty. Things wear out.
3) When reprogramming, do you Reset timer? Or just reprogram Time-Date. Last-ditch troubleshoot says to Reset and Re-program timer.
Oct 02, 2010 | Intermatic Inc. ST01C Digital In-Wall...
We have 2 DZS400 digital tork timers. unfortumately when DST days were changed we have not been able to use the automated dst transition and must manually change the clocks twice each year. is there a way...
DZS400 product descriptor shows DST, and many other programming options:
1) This might help or not:
You can modify DST start & end times > Press MODE until dSt shows > Press MONTH, DATE, DAY to modify start times, and then press ENTER. (or press DEL and ENTER to delete) > Press MONTH, DAY, DATE to modify end times, and the press ENTER > press MODE to return to AUTO.
2) According to DZS400 product descriptor "The controller has 365 day holiday capabilities with 24 single dates" ... if above solution doesn't work, the 24 single dates might provide enough days to fill in programming gaps in the DST. Your manual should have programming steps.
Sep 18, 2010 | TORK Hardware & Accessories
How do you program different time for day & night outlets? When you program setting 1 how do you know if it is day or night.
The timer doesn't know what time it is until you set current time.
The yellow outlets are controlled for 12 hours, and you can determine when those hours occur when setting current time.
http://waterheatertimer.org/GE-timers-and-manuals.html#zilla
Absolutely feel obligated to upvote the help.
Or take advantage of fixya expert assistance live.
Jan 05, 2010 | Coralife Zilla Aqualight Power Center
My Coralife aquarium lamp does not turn on once it is turned off.... until the next day. Other times it seems fine.
If you want timer to control one lamp with both day and night schedules, you have to adjust current time setting so lamp schedule falls within a 12 hour period. If that schedule doesn't fit, then buy a second timer.
Dec 20, 2009 | Coralife Zilla Aqualight Power Center
Orbit sprinkler system
Have you programmed the new one with all the info for date and time? Did you set the zones for the days you want and watering times?
Jun 16, 2009 | Orbit Sprinkler System Power Source...
Intermatic Inc. ST01C Digital In-Wall Timer Logo
412 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Hippy_dd
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
