I have an Onkyo HT-R560 that suddenly started turning itself off after a few minutes. I did some basic troubleshooting checking wiring and moving to a more ventilated location, but to no avail. After several tries of turning it back on and it turning off in shorter intervals, now it will not turn on at all. This unit is less than 2 years old and does not see heavy use. Typcially only used for football game and movie surround. Onkyo technical assistance was less than helpful. I can perform more specific troubleshooting and possibly repair with a little instruction. Can someone provide some guidance and/or point me to a location where I can download a service manual for this unit?
    President:
  • 2,047 Answers
Home theatre sets are quite tricky to deal with because of the sensitive components which they are made up of. Initially when the unit kept on turning itself off it was as a result of one of two things (Either a high voltage or a low one) But with the eventual outcome of not coming back on i suspect it is as a result of a higher voltage.
These units come with an inbuilt circuit breaker which ensures that instaed of the main unit to get fried just a fuse inside the unit gets fried. This fuse is burnt hence the refusal to come on.
simply open the unit try to locate the exact location of the burnt fuse and replace it. But be warned that if you dont have the technicak know how around the device refer it to an expert as you might further damage other components. You can get manuals from the following
http://www.retrevo.com/support/Onkyo-HT-S5100-Home-Theater-Systems-manual/id/18378dj389/t/2/
http://www.zarekmanuals.com/htr560-p-310244.html
Feel free to request any additional feedback.
Hope this solution has been helpful to you?
Posted on Sep 08, 2010
What rca outputs should be used to connect an Onkyo RT 560 receiver's tuner to a Sonos system?
Hi Dennis, could you confirm the model number? Is it an HT-R560?
Thank you, Onkyo USA
Nov 08, 2016 | Onkyo Audio Players & Recorders
I have an onkyo HT-R560 receiver that won't turn on. the standby light light up and when you hit the power button you can hear a click-like sound but nothing happens. what should i do to fix my...
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the
speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
May 07, 2011 | Onkyo HTR500 Receiver
I have a n onkyo av reciever ht-r560 only the front 3 speakers go on when im using it i know the rest work and are plugged in correctly because the volume tester outputs sound through it. Is there an on...
Your sound might not be working because the HDMI and optical audio inputs might not be working.
I made the mistake of buying the Onkyo HT-560 and in less than two years all of the HDMI video inputs started intermittently breaking. Sometimes when you selected the channel both the image and the sound would not come though.
Also the rear speakers stopped working from time to time and I have to run the setup again to get them to turn back on.
I am not sure that Onkyo was ready to introduce this technology, it has been a nightmare and my stereo is going to cost almost as much as I bought it for to fix it.
Oh and there customer service was no help, they just told to bring it to an "authorized service center for repair". They had also had no idea where there was one in my city it took them a day to get back to me.
The Onkyo HT-S5100 looks almost identical to the HT-560 not sure if they are different in anyway.
Stay away from Onkyo in the future! I know I will.
Sep 02, 2010 | Onkyo HTR500 Receiver
Onkyo remote code for Insignia Blu-Ray?
Unfortunately, Insignia can't provide a code. We recommend using your universal remote control's scan/learning feature to find a compatible code.
Feb 06, 2010 | Onkyo HTR500 Receiver
There is no sound coming no matter what source
Have you checked the speaker select switch on the front of the receiver? "A" "B" or "A +B" or "Off". Sounds simple, but it happens! If you still have an issue post a comment and I can help you troubleshoot some more.
Aug 17, 2009 | Onkyo TX-SR602 Receiver
No audio from my PS3 through the Onkyo 5100 7.1
if you are using an HDMI cable dont expect sound to come out (even thought HDMI carries both audio and video) the onkyo HT-s5100's Receiver is the HT-r560. the 500 models of the onkyo receiver does not allow HDMI to carry both audio and video. it only allows the video signal to pass to the receiver.
if youre using optical for audio w/c is what you need then these are the steps you need to follow.
*first make sure that the optical connections are ok at the back of the receiver.
*make sure that your DIGITAL INPUT is set to either OPT1 or OPT2 whichever optical input you used to connect the optical cable.
*then go to your PS# settings : go to sound settings / audio moutput settings/ select digital out (optical).
then enjoy.....ü
Jan 27, 2009 | Onkyo HT-S5100 Theater System
Onkyo HT-SR800 won't turn on
If you call Onkyo directly, 201-785-2600, there is a procedure to "reset" the system, something like holding the power button on and holding down another button for a few seconds. Can't remember which, so I can't be sure, but try giving them a call.
Jan 02, 2009 | Onkyo HT-SR800 System
259 people viewed this question
 Grubhead
Grubhead
