Question about Regina ElectrikBroom RG100 Vacuum
How do you remove dirt from the regina electric broom
It's not the best design. Grab the canister push down hard while pulling top out. If you look you can see the tab you have to clear at the top. It gets easier the more you do it.
Posted on Jan 10, 2011
Why vaccum not emptying
Hi! If no dirt is entering into the dirt cup it could be that you have a clog in your hose. Detach the hose from both ends and use a broom stick or something similar to carefully loosen and remove any clogs in the hose. Hope this helps! If not you can always reach out to us here on Fixya, Facebook.com/dirtdevil, or Twitter @DirtDevil. Thanks!
Aug 29, 2014 | Dirt Devil Breeze Cyclonic Bagless Upright...
Hoover troubleshooting
Hello! The umbrella tube is a stationary part, it does not rotate. The dirt that enters in the dirt cup spins around the umbrella tube. If no dirt is entering into the dirt cup this can mean there is a blockage either in your hoses and/or your filters. Try these quick trouble shooting steps below.
1. Remove the dirt cup canister from the vacuum. Twist off the dirt cup lid.
2. Remove the primary foam filter. Hold filter under running water until water runs clear. Allow 24 hours to air dry. If the filter is really dirty it may need to be replaced.
3. Slide the Hepa filter out. Tap the filter against the trash can until dirt stops falling. Replace the Hepa filter. (Do not wash)
4. Remove the hose from both ends. Use a broom stick to gently loosen and clear any clogs from hose.
5. Use a wooden spoon or something similar to loosen and remove any clogs from the lower hose. Hope this helps!
Aug 09, 2014 | Hoover Nano Cyclonic Compact Bagless...
My Dirt Devil Reaction vacuum cleaner has a plugged hose.
Hi! A broom stick or something similar is probably the best tool you can use to remove a clog. Try pushing the broomstick in an up and down motion gently against the clog until it starts to loosen and slide out. If you are unable to remove the clog the hose can be replaced. I have included a link where you may go to purchase a replacement hose if needed. Good luck!
Search
Jun 06, 2014 | Dirt Devil Reaction Twin Cyclone Upright...
Why is my hoover spirit spitting dirt out the sides?
Hey there! Sounds like you have a clog somewhere in the vacuum. Try removing the hose completely from the cleaner. Use a broom stick to gently loosen and remove any clogs from the hose. Use a wooden spoon to break up and remove any clogs from the lower hose area. Also check that your bag is not full and your brushes are still spinning. Hope this helps!
Jun 03, 2014 | Hoover U5068-900 Sprint Upright Vacuum
I sucked up a sock and think it's in the hose
Remove the hose from the vacuum cleaner and push a broom handle all the way through the hose. If its in there, that will remove it.
Dec 15, 2013 | Dirt Devil Vision Wide Glide F16...
Good day, I have a EN Vision Dirt Devil upright, 12 amp, wide 15" nozzle. My vacume is blowing out insead of sucking up the dirt from the carpet. Can you help me? What should I do? Thank you...
It's probably the brush "kicking" the dirt out, rather than it being blown out. This happens if there's a clog in the airflow system somewhere. This could be anywhere from the power head above the brush to the tank where the hose connects.
1. Detach hose at both ends. Drop a coin in one end, lift that end up until coin falls out the other end. If it doesn't, there's a blockage that needs to be cleared. You may be able to do this by using a broom handle to push the clog through. Push the broom handle through the power head end.
2. With the hose detached, check the power head connection for blockages. Drop the coin in and see if it drops through. If not, use a wooden spoon handle, or similar blunt object to push the clog back toward the brush, then pull or vacuum it out.
3. Check the filter and make sure it's clean,
4. Remove the dirt catcher and check bottom of holder right above motor. There's a screen here to prevent debris from getting to the motor. Clear any dirt and debris from it.
Try the vacuum and see it this has helped.
Jan 19, 2011 | Dirt Devil Vacuums
When I vacuum the floor dirt falls out on the floor
blockage in the hose sounds like the culprit remove the hose and inspect, push a broom stick through it while off and push a open coat hanger through the canal where the hose connects, if not the filter must be blocked
Jan 18, 2011 | Dirt Devil M086700 Vision Bagless Upright...
I need an owners manual for my regina steemer pro model: rg4152-1. it is a 7 amp cleaner. where can i find one?
Regina is now part of the Dirt Devil, your nearest dirt devil dealer should be able to assist you.
Oct 05, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
I have acquired an old Regina Electrik Broom
Hi jmathe, Looking at the back (business side) of the vacumn: Underneath the white plastic dirt cup, please find a cast aluminum latch, that secures the part you will empty. To remove the white plastic part, turn the aluminum latch handle downward, and to your right, while you are holding on to the dirt cup with your left hand. I usually wear a dust mask, and empty the dirt into a small grocery bag, to tie shut, before placing it in the trash. To replace the dirt cup, turn the cast aluminum handle back to where it was before, handle pointing left. The more often you empty the cup, the longer your Regina Electrik Broom will last. Mine is forty-five years old. Allow the motor to cool, often, as well.
Jan 07, 2009 | Regina ElectrikBroom RG100 Vacuum
Vacuums Logo
445 people viewed this question
Top Regina Vacuums Experts
JoeVacs
Are you a Regina Vacuum Expert? Answer questions, earn points and help others
