Question about Ascaso ARC Dark Black Espresso Machine
I need a new heating element for my Ascaso Arc but can't separate the old one from the chromed grouphead. As the new one is non returnable I'm hesitating buying it. Fairfax would not give any advice. Any clues?
  • Ascaso Expert
  • 54 Answers
Hi Isle,
To separate the group from the chrome group head - you can use a screwdriver to pry them apart. it will be bonded with lime.
Failing that you could try rubbing some descaling liquid around the side with a paint brush, this will help dissolve the lime and then pry it off.
You could always replace the whole group - more expensive option but a lot easier that replacing the boiler. ASCASO Dream brass group
Posted on Apr 28, 2017
  • 100 Answers
Do not do this repair. We do it, and even for us it is pretty hairy.
Posted on Feb 15, 2011
My coffee maker stopped heating.
The heating element has burned out - it can be replaced relatively easy if you can get the part.
Jul 23, 2015 | Ascaso ARC Fun Espresso Machines - Black &...
I purchased an Ascaso Dream espresso machine on ebay without reading the fine print that it was not working by not heating up. Is it merely the heating unit/part that needs to be replaced? Also it only...
If when you switch on the machine and the water is cold then, you should replace the boiler element.
There are a number of ascaso boiler elements, depending on the year. Dream Arc Basic Ellipse Page 2
It it works and you get steam , then the boiler is fine.
It may be that wires are loose inside?
Mar 05, 2014 | Ascaso Dream Espresso Machine
Replace group head seal ascaso ARC
Hi There, If you need a group gasket for the ascaso Arc
Try links below. If machine is the older model Ascaso gasket kit Dream Arc Basic If made after 2012 Ascaso group gasket Set 2012
Jan 04, 2013 | Ascaso ARC Dark Black Espresso Machine
Ascaso Dream steam wand leak
Hi Emily,
You have 2 issues.
Steam wand leaking while making coffee - This indicates that the seals on the steam tap o rings need replacing.
Coffee pouring over the handle when making coffee - this indicates that the group gasket needs replacing.
Replacing the group gasket is easy takes 10 min
Replacing the o rings on the steam tap may take a little longer..
All you need is a group service kit Ascaso gasket kit Dream Arc Basic
Feb 28, 2012 | Ascaso Dream Espresso Machine
My ascaso epresso machine does not heat water, I would like to buy parts for it.
We do not advise you attempt to install a new heating element in this machine. It is extremely meticulous work involving many small parts, you will need metric tools, meters, etc, it requires removing the old boiler, disassemble it, purchasing a new one with the correct gaskets and moving over all the sensors to the new boiler. We do this repair and even for us it is somewhat hairy.
Jan 05, 2011 | Ascaso Dream Espresso Machine
Ascaso Dream Leaking Water
Correct, inside the grouphead their is a gasket which is the same diameter as the filterholter which make the perfect fit so the presure of the water will not leak out. So now either the gasket is damage in one point so you have the leak from that point. Second the gasket have become hard so it can not make perfect fit with filter holder. In both above case you have to replace the gasket. Finally their is aposibility that the gasket is dirty with coffee remains and again we can not have a perfect fit. You can use a hard brash with the water running so you can clean the gasket.
With this case you can unsrew also the shower from the grouphead and clean it also for better coffe results
May 05, 2010 | Ascaso Dream Espresso Machine
I think our heating element is bad on our Ascaso...we checked it with an ohm meter. When we turn it on, the water doesn't heat up, and there's no steam. Is there anywhere we can get a new element for...
Sounds very much like the element has gone. Mine went after I moved house (suspect something happened during transit). Mine was replaced by a heating technician who wasn't even an official Ascaso agent, so I guess the answer I would give would be go to a local heating systems technician/company. Mine cost a bit more than that, but I got them to change it, so if you're doing it yourself you might get it for under $100.
Oct 21, 2009 | Ascaso Dream Espresso Machine
Innova Dream espresso machine
Hi Jah510,
My espresso machine turns on but it doesn't heat up..
You may need to replace the ascaso boiler element, if machine is between 3-6 years old then it probably is the element.There are a few of these, you just need the the manu date under the machine. Dream Arc Basic Ellipse 150 Products
Apr 04, 2017 | Ascaso Dream Espresso Machine
Ascaso ARC Dark Black Espresso Machine Logo
121 people viewed this question
Top Ascaso Coffee Makers & Espresso Machines Experts
ray gallant
Are you an Ascaso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
