Question about Weather King 10AJA6001AH Air Conditioner
How do you clean the coil, and clear condensation lines?
  • 674 Answers
You can buy some cleaner at a heating and air supply that doesn't have to be rinsed off to clean the evaporator coil. You just spray it on the indoor coil and normal condensation takes care of rinsing. I use a shop vac to clear the condensate drain. I hook it the drain line outside and let it pull all the muck out. A little Clorox in the condensate pan every now and then will help keep it clear(1 to 2 tablespoons). You can also buy cleaner for the outdoor coil and can rinse the coil with a hose. It's best to rinse from the inside to outside.
Posted on Sep 09, 2010
Refigerator runs but does not get cold
Check the fridge's temperature or thermostat control to confirm that it was not accidentally turned up.
Inspect the appliance's door seals to ensure that they are not cracked or have come loose.
lean the fridge's condenser coils. Condenser coils displace hot air from the refrigerator by drawing heat away from the appliance with a fan. Vacuum the condenser coils to remove any dust and dirt accumulated on them, then use warm, soapy water and a clean cloth to clean the condenser coils of any remaining debris. Examine the drain line, located under the refrigerator, if above does not fix it , it may be low on freon, or there is a hole in a line.
Apr 21, 2012 | Frigidaire Refrigerators
My frigidaire window unit is leaking into my house. I removed the unit to clean the coils, this didn't remedy the problem. It is properly tilted to the outside.
behind the dilter is the evapator and behind the evaperator and underneath is the pan that holds the condensate. look at the pan and see how dirty if it is then clean it . Check the evap coil to be certain it is clean . and double check that it is tilted enough . 1 inch or a bit more hope this help let me know
Jul 24, 2011 | Frigidaire FAC126P1 wall/window Air...
My drain pan is leaking
You need to access the evaporator coil on the inside of your air handler and unplug the drain for the condensate. It should be the 3/4 inch line, if the 1/2 inch line is capped then it is not doing anything and has probably been abandoned.Open up the unit and clean the drip pan and drain hole where the 3/4 line starts. This should clear up your water leak problem.
Also
Water leak due to dust block in air filter,cooling coil,drain pan and blower wheel.
Jun 29, 2011 | Carrier 38CKC060 Air Conditioner
My coleman rv ac unit is dripping condensation inside the camper, what is causing that?
It is possible that the drain hole on condensate pan is plugged and causing water to over flow pan. Remove cover from unit and check drain line.Clean coils andpan as best you can and clear drain hole. Add a small amount of bleach to water in drain pan.This will kill any algea or bacteria that may be growing in condensate water and plugging the drain. Thank you
Jun 20, 2011 | Coleman Mach III Air Conditioner
I have a York Diamond 80 air conditioner/heating unit. How do I stop the water from leaking every where?
the condensate line from the coil must be blocked. Use compressed air to clear the lines. Or possibly a crack in the condensate pan where the fitting goes in or not sure if it is old enough but the older coils had steel condensate pans that will rust through
Sep 04, 2010 | Heating & Cooling
I have a Goodman system and I have water leaking from the the small box next to my furnace. I have what looks like 3 lines running from unit to this box. One is a small copper one, another is a line...
the clear plastic hose is the condensate drain .. indeed they clog frequently .. lthat will allow water to overflow the pan that is desined to capture condensed water from the evaporator.. the plastic hose and the pipe it is attached to need to be cleaned out periodically ... allowing water to overflow can damage other things so its important to get the drain cleared .. however that drain has little to do with cooling efficiency .. your lack of cooling performance could be another problem ... sometimes the evaporator coil gets clogged (large finned unit behind where the overflow hose is attached inside furnace) .. that has to be cleaned once in a while but is tricky to do ... how often depends on how good the furnace air filter is and how often its changed ... as the evaporator becomes clogged with dust the cooling efficiency goes down .. same with the outdoor unit ... you have to wash out leaves and such periodically from the condenser coils .... if every thing is clean but the cooling efficiency is still low then have the unit checked for refrigerrant pressure .. it could be low .. of course make sure the furnace filter is not clogged ... also for cooling make sure all of the registers are open ... closing some can reduce overall efficiency ... make sure the outdoor unit fan is working properly ..
Jul 25, 2010 | Goodman Heating & Cooling
We have water that appears to be leaking from the top, right side of the furnace. what is the cause and how do we fix it?
Hi, what this is is you're evaporator coil sets on top of the furnace. The pan that catches the condensation could be rusted out and will need to be replaced. This is something a service tech would have to do, as the unit will have to be pumped down ( freon pumped to the outdoor unit) and the freon lines cut at the coil to remove it. You have a 3/4 " condensate drain coming off this pan that may just be plugged with dirt from the coil. If you can remove the face of the coil to expose the coils and drain line, you can clean out the drain by using compressed air or something with pressure that you can blow through the pvc line and clear it. This may be all that's wrong. Keep me posted. This will sovle you're problem .
Sincerely,
Shastalaker7
Jan 22, 2010 | Heating & Cooling
When the ac unit is on the water comes in the house
The condensate drain line is clogged, causing the condensation water to overflow. You can use a shop vac to clear the line. attatch it to the outlet side of the line. also clean out the condensate drain pan located at the bottom of the indoor coil.
Sep 25, 2009 | Amana MH09A3PA235 Comfort Zone Room Air...
Refridgerator side not cooling. No air movement.
vent clear but vent opening arround vent frozen or coil is frozen eithor way you probably need a thermostat and a timer
Jul 29, 2009 | KitchenAid KSCS25FKSS Side by Side...
Furnace is leaking water
This is not a lot to go on.
I assume since you called it a furnace, you have hot air heat and central air conditioning. If so, the only way a furnace/AC unit can generate water is by condensing moisture from the air. This is common to all air conditioning and removes humidity from your home. If so, this water, called condensate, must drain. The condensate is collected at the AC cooling coil that is typically located on top of a vertical upflow furnace or downstream of a horizontal furnace. If the drain is clogged, it will overflow and create a mess in and around the furnace. If this is your problem, cleaning and clearing debris may solve the issue. I suggest starting with the easiest accessable part of the drain path. You may need to open the panels enclosing the AC coil and clean the small pans at the bottom of the coil and clear openings from above that look similar to a laundry tub drain. If you get that far and find rust holes in the pan, repairs are needed. If you have an electric condensate pump that may also be the cuprit and require cleaning. Check and clear all drain lines from the coil connection to the final dicharge - sump pit or outside.
Oct 05, 2008 | Goodman Heating & Cooling
Weather King 10AJA6001AH Air Conditioner Logo
211 people viewed this question
Top Weather King Heating & Cooling Experts
Donni Steen
Tim Whalen
John Tripp
John Tripp
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
