Question about Garden
I can not get my mower to start. It goes putt, putt, putt but won't fully idol. I put new SAE 30 oil in but didn't seem to help. What's wrong with my mower?
  • 17,130 Answers
Please remove plugs an clean, adjust spark gap, check spark or clean the electrics, put back plug fully dry and clean.
Check fuel flow, if overflown allow it to dry before plug is put in. Pump off all overflow.
This must work.
Posted on Sep 08, 2010
Ihave a Briggs&Stratton 450 series 148cc push lawn mower it has seperate compartments for oil&petrol it ran out of oil 2day what type of oil do i need?
Hi SAE 30 in warmer temp ::::::: SAE 10W-30 in colder temperatures... also in temp below 5° C SAE 5W-30..... Cheers
Oct 25, 2016 | Garden
What oil do you put in a sp470 mountfield
Hi use SAE 30 in warmer conditions or SAE 10W-30 for varying condition's improves cold weather starting ... Cheers
Sep 06, 2016 | Garden
What type of fluid goes in husqvarna yth 150?
Hydro gear box takes a sae 20w 50 motor oil, Tuff Torq takes a sae 10w 30 motor oil
Oct 20, 2012 | Husqvarna Yth 150 Riding Mower Illustrated...
What engine oil do I need for my yardman 6.0 HP push mower?
SAE 30 only; if using conventional oil. I recommend using synthetic engine oil. If you go with synthetic, you can use a multi-viscosity oil like 10W-30, but only use staight SAE 30 if using conventional oil. Many benefits to using synthetic oil. It cleans the engine as it runs, it provides superior protection and helps cool the engine parts better, and it almost assures you 100% that your engine won't fail because of the type of oil used.
Jun 18, 2011 | kawasaki Garden
Can you please advise which oil to put in my B & S rideon mower. Model 261777 Type 013801
Hi verndono,
Briggs and Stratton recommends to use SF or SG. SAE-30 or 10w-30 oil for temps above 40F (4C) , SAE 10W oil for temps between 40F (4C) and 0F (-18C) and SAE 5W-20 (or 10W oil diluted with 10% kerosene) for below 0F (-18C). I suggest you use 10W-30 or SAE-30 and you will be good to go. Hope this helps. Best regards. Denis.
Mar 01, 2011 | Briggs & Stratton Garden
What type of oil and gasoline do you nee d to run Craftsman 6.5 lawn mower?
generally all 4-cycle lawn mower engines are tuned to use regular unleaded gas ,(I personally use mid or high grade unleaded)....and for engine oil use strait 30 WT engine oil...... I often put a dash of fuel system cleaner in each gallon of lawn mower gas,it is not absolutely neccessary but seems to help moisture stay out of gas..(DO NOT USE HEET or other methenol based fuel additives for this can cause overheating or scoring of piston and cylinder...but rather use a petroleum based additive,this allows the small amounts of moisture in fuel to pass through the carbeurator without clogging filters or fuel system for smoother running)..also...if you put lawn mower up for winter it is always helpful to use a fuel stabilizer such as "STABIL" or other such products (follow directions for use) and be sure to change the crank case oil in the spring before using....this will give you much longer life from your lawn mower...
Keep air filter clean!!!..... Happy mowing!!!....so, the answer?...regular unleaded and 30wt engine oil...if you would like..they have special engine oil for 4-stroke engines at most hardware and walmarts n such...but is just expensive 30wt oil... Enjoy your day,Todd
Nov 23, 2010 | Garden
Need to put oil in and don't know what kind of oil to put in or if it's gas oil mix????
ADD SAE 30 SMALL ENGINE OIL. 18oz TO 20oz
SEARS SALES A 20oz BOTTLE OF CRAFTSMAN SAE 30 OIL FOR $2.59
Oct 12, 2010 | Poulan Pro PR550N22SH 22Inch Briggs ...
What kind of oil for a husqvarna riding mower?
Yes SAE 30 is the recommended oil for B & S engines. You can find it on amazon for good price. here: Amazon com oil 30w . Hope this was helpful. cheers
Jun 14, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
