Question about Cardo scala-rider Headset
Hello, I use my recently purchase scalarider G4 with my iPhone 4. Unfortunatly the bluetooth connection does not operate automaticaly neither when I press the power button. I need to enter my iPhone bluetooth parameter and force the 'Connect to device' process. It is obviously not very handy ! When the connection gets up I can here 'GPS Connected' witch seems to be a wrong phone / type recognition. What should I do ?
2 Suggested Answers
  • 4 Answers
SOURCE: can't get existing bluetooth headset to work with new phone
I had that problem when I changed handsets. You need to:
  1. ensure the bluetooth setting is turned on on the handset
  2. switch on the scala 500
  3. press and hold the scala 500 power button until the red and blue lights are both flashing (you have to hold the button in for quite a few seconds)
  4. now you can search for new bluetooth devices from your handset and it should find it to enable you to connect
Posted on Jun 05, 2009
I have purchased 2 of these speakers. I want to Bluetooth connect them to my iphone. How do I do this and get music from both speakers?? Thx
If you have purchased Speakers with Bluetooth Connectivity capability you can do this by switching on the speakers and on your iphone use the Bluetooth Pairing Option from Bluetooth settings to establish connectivity and play music to hear from speakers
Jun 15, 2015 | Audio Players & Recorders
Iphone bluetooth drops to headset if in my hand
hello, I also meet this error about my iphone, I get many help from this forum, and also bought many DIY repair tools from china supplier, and vipprogrammer help me fix this error. maybe you can try it. or contact they WhatsApp:+ 8615986801289
hope can help you!
Aug 20, 2017 | Apple iPhone 3G
Connect to iPhone 4
Hold the "Answer/End" button on your Jabra Bluetooth headset down until the LED light on the headset turns solid blue. The location of the button may vary based on which headset you have, but its appearance will be the same; it is the button that has an image of a telephone on it.
Click on the "Settings" icon from the main screen of your iPhone 4 .
Click on "General" in your iPhone's "Settings" menu.
Click on "Bluetooth" to access your iPhone's Bluetooth menu and then click the option to turn on your iPhone's Bluetooth connection. Once your iPhone's Bluetooth is turned on, it will search for available Bluetooth devices.
Select your Jabra headset by clicking on the icon that appears on your iPhone's screen.
Enter the passkey for your Jabra Bluetooth headset. The default passkey on Jabra headsets is "0000."
Click on "OK" on your iPhone 4 to complete the connection to your Jabra headset.
Tips & Warnings
The LED light on your headset must be solid blue to pair to your iPhone. A flashing light indicates your headset is not yet in pairing mode and your iPhone will not be able to connect to the headset.
Having your iPhone 4 Bluetooth turned on will drain your phone battery faster than normal.
Apr 13, 2011 | Jabra Bluetooth Headset - BT2070
Where do I find the blue tooth connection?
hello there!
Like most smartphones, the iPhone has the ability to connect via Bluetooth devices. Unlike features like Wi-fi, Apple did not make activating Bluetooth obvious or quick.
Here are the steps on how to turn on and off the Bluetooth on your iPhone:
1. Select the "Settings" application from the main menu.
2. Select the "General" option in the settings application. It is usually in the second group of items.
3. Select the "Bluetooth" option. The option is located in the second group of options.
4. Select the off switch to turn on the Bluetooth. Then, Congratulations, the iPhone has now turned on its Bluetooth, follow the same steps to toggle this switch to the off position.
Hope it helps.
Mar 22, 2011 | Apple iPhone 3G
My i phone 4 is not detecting jabra bluetooth device first it used to tetect but i purchased ne blutooth device while scanning for that device i found the old one i.e jabra so i clicked the option forget...
Does you new blue tooth device appear on other device or not. Reset you iphone setting and then again try to detect your new bluetooth device. Also check your bluetooth setting on your iphone to. Here is how to fix computer does not detect iphone or ipod
Dec 26, 2017 | Apple iPhone 4 Black Smartphone
How to pair with iphone
1.From the main home screen of the iphone open "SETTINGS".
2.From the setting menu go to "GENERAL".
3.From General go to "BLUETOOTH".
4.In the Bluetooth menu you will see an on/off switch. Make sure you turn the switch to "ON".
5.From here you want to go to your bluetooth headset. Hold the on button for about 5-10 seconds until the light starts blinking. Once light is blinking go back to iphone.
6.In the Bluetooth menu (same as step 4) your iphone should have discovered your bluetooth headset. However if it is not paired yet. Open the headset menu.
7.In the headset menu you are required to enter the appropriate PIN number (which should be given inside your bluetooth headset instruction manual).
8.After you have entered the correct PIN number press connect.
9.From here your Bluetooth Headset should be connected and ready to use.
NOTE:Fully charge your bluetooth headset before syncing it to your iphone
Apr 16, 2010 | Samsung WEP410 Bluetooth Headset Wireless...
Bluetooth problems
Hi tapper24,
unfortunatly the iphone can only provide mono audio for bluetooth headsets. This is currently the limitation of the iphones bluetooth capabilities.
I hope i helped you with an answer. Sorry i couldn't do more to help, but there is no current way around these hardware restrictions.
Apr 14, 2009 | Apple iPhone Smartphone
yes you can connect bluetooth to iphone you go into your settings and register bluetooth
bluetooth has to be on and charge while the phone searchs for bluetooth
some bluetooth are compatible with i phone some are not
May 13, 2008 | Apple iPhone Smartphone
Cardo scala-rider Headset Logo
164 people viewed this question
Top Cardo Radio Communications Experts
Eric Sutherland
Tom Chichester
Are you a Cardo Radio Communication Expert? Answer questions, earn points and help others
