Question about Husqvarna Garden
Have 455 with oiling problem. Replaced oil pump and pinion gear. Saw is oiling with no bar on saw. Install bar and chain and oil drips from bottom of saw but none getting to bar and chain. What do I need to check next.
    Brigadier General:
  • 4,088 Answers
Remove the bar and chain again, and check the two small oil passages that run out to the chain groove on either edge of the bar for plugging--they commonly fill with sawdust and dirt. Clean the entire chain groove, then reinstall the bar and chain. Make sure the bar fits up to the engine case tightly and that the chain adjustment 'tang' drops into one of the large holes in the bar end. There is usually a rubber seal on the engine case side where the oil oozes out--make sure it is intact and in place. Hope this helps!
Posted on Sep 09, 2010
How to stop the bar chain oil leak
There should be an adjusting screw around the bar somewhere. Turn it anti clockwise until it stops and then just crack it one turn. If it still leaks too much then turn it down slightly.also try and store the saw on its side to stop the oil just coming out.
Apr 20, 2017 | Garden
I have a rancher 455 chain saw and i dont think my oil pump is oiling my chain is there a way to turn it off and on
Remove the bar and chain, then start the engine. If the pump, lines, and filter are good, oil will ooze out of the engine side port. If it does, clean the oil passages in the drive end of the bar that run from the large holes out to the chain groove on each side of the bar. Clean the entire chain groove and oil the sprocket on the tip. Clean the port area on the engine case. Re-install the bar and chain, then run the engine at speed for a few moments with the bar tip near a piece of cardboard--it should throw off a thin line of oil onto the cardboard. Hope this helps!
May 22, 2010 | Husqvarna Chain Saw 20" Bar
455 chain saw does not seam to be oiling the chain enough,checked an cleaned oiler chain an bar ,i cant find my book but i know it can be adjusted but dont know how
Caution it is probably only a 3 position oiler, forcing it beyond either stop may cause failure. The 2009 om (may not be your saw) adjustment is on page 33 of the Operator's Manual (below).
Oil System Plugged.
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar) Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up. If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear. Please see the IPL to aid in oiler component identification.
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
HTH
Lou
Jan 05, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
455 rancher will not oil, replaced complete oiler,
An IPL with oiler components and part numbers can be here:
HusqvarnaUSA.com
Serial number decode – for use with IPL
06 1500198
Our job is to provide the knowledge and illustrations available to help you determine which oiler component has likely failed. Your job is to apply that knowledge and make the final determination. If you aren’t comfortable doing that then your only option short of saw disposal is your friendly local chainsaw seller/mechanic. You might be pleasantly surprised at how reasonable they are.
Oil System Plugged.
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar) Clean the saw’s oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw.
  2. If no, continue with 2.Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out (clean or replace, difficult to determine serviceability). Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is probably left handed thread). Please make extensive notes & some digital pictures will help during reassembly. GL
Lou
Nov 08, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
The chain saw is not oiling the chain. NO oil is coming out. It is not reaching the bar.
Oil System Plugged.
Remove the clutch cover, bar and chain. Clean the oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw.
If no a blunted, hooked piece of wire can be used to pull the hose in the oil tank out. I recommend the filter be replaced. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is probably left handed thread). Please make extensive notes & some digital pictures will help during reassembly. GL
Lou
Oct 12, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
455 rancher will not produce oil for the chain. Oil pump replacement? Need repair manual or parts breakdown. Thanks Warren
Also make sure that where the oil is pumped against the side of the bar that the oil port (little hole) that feeds oil into the bar's slot is clear. Mine would go through a tank of oil with each tank of gas, but the chain wasn't getting oiled until I cleaned out this little hole.
Jun 29, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna chain saw, model 455 will not oil properly bar and chai
hi cindilou50
check the oil filter from the oil tank,the oil line ,the worm gear and the oiler under the clutch.Clean the ways where the oil goes with compresed air.(after you fill out the oil tank)Also check the oil hose.
best regards savumihai71
Nov 30, 2008 | Husqvarna Chain Saw 20" Bar
Bar oiling problem
Just a thought: Is it cold where you are? At this saw mill where it is my job to keep chain saws running, learned years ago that you cannot use "bar oil" in winter. Need thinner oil, like motor oil. ....preferably a "non-detergent" motor oil, plain 30-weight is OK, HD30W will work, but the HD part causes the chain to stretch more so than standard bar oil. The bar oil literally is so thick in cold that it stripped the worm gear out of a Poulan Pro oil pump (plastic gear, anyways, wasn't much to begin with.) But thought you may want to try thinner oil, if it is cold where you are. Oh yea we also have 2-Husqvarna 359's with 20-inch bar, and use thinner oil in winter. Our Husqvarnas have an oil adjuster located on bottom, on clutch side. Straight slot screw adjustment.
Nov 18, 2008 | Husqvarna Chain Saw 20" Bar
Garden Logo
223 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
