Water temp. keeps going to HOT no matter the setting.
    Top Expert:
  • Washing Mach... Master
  • 78,267 Answers
REPLACE THE COLD WATER SOLENOID VALVE ON THE BACK OF THE WASHER
Posted on Sep 08, 2010
Electric wh high temp shut off button keeps resetting
Water heater has upper and lower elements. Only one t-stat. Check to see where tstat is set to. Turn down to lowest level. If breaker still resets then replace tstat. It is letting the water get to hot no matter what setting it's on. So water is getting so hot that it trips breaker.
Dec 28, 2012 | Water Heaters
I set the water temp setting to cold, but it keeps filling with hot water. No matter where I set the dial, it fills with hot water.
check whether the hoses are mismarked when they come out of the wall.
the same thing kept happening to us (whirlpool cabrio) and i checked the temperature on the hoses coming out of the wall - cold was mislabeled as hot by the builder, and vice versa.
Aug 31, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Runs fine til the temp out gets hot enough then dies. Wait ten mins and it will start again and run for a few mins then dies again
you didn't say if it was hot on the temp gauge? no matter, it sounds like you have a stuck t-stat. when the engine is cold, a mechanical valve keeps the water from coming out of the engine block until warmed up, then opens and lts the cooler water in. this cools down the engine and the colder temp of the water shuts the valve again. this happens constantly while the engine runs, and if your t-stat is stuck, the engine heats up the water in the block, but with nowhere to go, simply overheats the motor. a good repair book will locate the thermostat housing for you and should you the repair procedure. (i assume you have checked the water in the rad. low water will give you same symptoms). good luck.
Jun 10, 2010 | 1998 Chevrolet Express
I have a jackson Low Temp single door model.. I
you may need to clean out your hot water heater depending on how old it is and yes 80 gal should be more than big enough adj. thermostat to the next level
Jun 09, 2010 | Jackson 25 in. Conserver XL Free-standing...
Heats up the rapidly decreases within in minutes.
Problem new or old? How long you have unit? Sounds like not enough flow to keep burner on. Tankless need at least .6 gpm to keep hot water flowing or else the burner fires then shuts fires then shuts and you get a sandwich effect...hot cold hot cold. If you have new diverter valve in shower -vs- old two handle type try turning hot water ALL the way ON and see if hot stays hot. If it does stay hot then slowly adjust to cool and see if you maintain a good MIX for proper temp. If it goes cold again try this......LOWER control pad setting to a comfortable 105 degrees (ladies) 100 degrees(men) and turn shower valve all the way to HOT. See if your temp remains consistant now and if it does then problem solved. Tankless mindset...set temp on control pad and stop trying to MIX at shower valve. Thats how these things work. Thats why I install a control pad in each bath and one in the kitchen for adjusting ash temp during dishwasher on time. ditto for wash machine. You should never need to turn on cold water if your unit is set to proper temp at controller. Hope this helps
May 17, 2010 | Rheem Tankless Hot Water Heater...
No matter what the temp setting is at it only has very hot water
Your water temp is determined by 2 things. First the hook up to your water supply. If you are able to turn off the hot water valve that feeds the unit and then select a cold water only wash, do you get cold water?? If not then someone hooked up the hoses to 2 hot water feeds. If hot and cold feeds are installed right, the second thing is your computer which monitors the incoming temp through the boards atc control and a thermister. If you select cold, and only get a hum and the cold water valve is on, you may have to clean the screens in the valve of any sediment. If no hum, and no cold, dead solenoid on valve, but that would throw an error code usually. All fills are monitored by the board and usually begin with a hot/wrm mix and then changeover to a monitored cold temp , about 70 degrees.
May 05, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore HE 3.8 washer has only hot water even with cold settings
If the washer fills very slowly when you have it on a cold setting the cold water may be shut off behind you washer or possibly the hot and cold are switched. if that is not the problem then you have a relay problem with the machines electrical system.
Jul 01, 2009 | Kenmore Washing Machines
Frigidaire washer hot water only
sundsas if you have a bad temp select switch. only selecting hot/hot
Oct 31, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer is a top load set it hot water and starts with hot and then will go cold willnot stay on hot G E Profile ,model wwa8350g
most new washers sense water temp and will try to adj final tub water temp by alternately running cold or hot as needed ..most hot settings are not faucet temp but a predetermined temp so if your hot water is 140 degrees coming in the control will switch the cold on to bring final tub water temp down to preset ..which could be as low as 100 degrees the industry's way of energy conservation
Sep 23, 2008 | GE Washing Machines
Washing Machines Logo
60 people viewed this question
Top Washing Machines Experts
