Question about Foxconn 661FX7MF-S Motherboard
How do I access the bios on the foxcomm 661mxplus?
  • yadayada
    yadayada Sep 08, 2010
    CONTACT THE MANUFACTUERS SUPPORT SITE
Need to find out how to reconnect front panel earphone plug and mic plug to a Foxcomm PC661M05-6LS motherboard
check motherboard input and see where you see audio input or mic input for that and try again
May 31, 2012 | eMachines Computers & Internet
What is the one time boot key for the Foxconn 661MXPlus mother board? to enable me the option of which operating system on which hard drive to select? Thankyou
Start your PC. Press Delete button from keyboard,it will open your BIOS setup.
Now go to boot options and select your hard drive to boot.
Hope this will help you.
Thanks for using FixYa.
May 17, 2011 | Foxconn 661FX7MF-S Motherboard
Does the 661MXplus support optional boot up of of hard drives@
yes in cmos but if you do not know how to use cmos do not go there if you have a friend that knows how it and only then ok jim
May 15, 2011 | Foxconn 661FX7MF-S Motherboard
How to download ethernet driver
I understand that you require ethernet driver for your FoxComm Motherboard. Here is the weblink below, that would help you to download the drivers:
http://www.foxconnchannel.com/en-us/support/downloads_detail.aspx?ID=en-gb0001017
Thanks,
Shiva
Dec 18, 2010 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
Driver
You'll find it from the Drivers link at this page on Foxconn's website.
http://www.foxconnchannel.com/en-us/product/Motherboards/detail_spec.aspx?ID=en-gb0000241
Simonides
Oct 09, 2009 | Sport & Outdoor - Others
Microphone not working on foxcomm ebot computer
Sir,
U absolutely right...the problem is comes from driver also. First uninstall the drivers and reinstalll it with other drive(other than C:/). Also check the audio setting in right lower side of corner of your system, in which the audio properties the LINE IN mode is checked and the scroll bar of volume is full.
Thanks Good Luck
Aug 07, 2009 | Computers & Internet
Board will only show display
plz check wether the hdd and cdrom drives r connected properly. when a drive is not detected the system hangs, check the bus and the led connections and if possible u change the ram and check out
Oct 07, 2007 | Foxconn 661FX7MI-RS (661FX7MIS)...
Foxconn 661FX7MF-S Motherboard Logo
54 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
