Panasonic scanner f40-30000000 error feeder does not go down
3 Suggested Answers
  • 16 Answers
SOURCE: Scanner No Paper Detected Error
There is a narrow FFC cable that connects the sensors between the hoppper assembly and the main scanner unit that may be loose. Check both ends. This cable can also develop small fractures over time. These fractures can cause the sensors to not be noticed by the scanner or give false info. The cable may need to be replaced.
Posted on Sep 08, 2009
SOURCE: panasonic scanner kv-s3065c error code
F40-30000000 Solution You have to replace under the hopper cable part number PJJEC3437Z and board part number PPB747ADF25H from www.partstore.com this will take about 2 hours to do because of the covers you have to take off.
Posted on Jul 26, 2011
There is a red light error on the scanner and it beleives there is paper in the scanner. I have unplugged and replugged everything. I have reset the scanner and I have also turned the paper feeder to...
I found someone had placed a piece of tape on the cork where the scanner feeds in which was causing the sensor to believe parper was there. When I removed the tape the red light went off.
Feb 24, 2011 | Panasonic KV-S2026C Pass-Through Scanner
Our panasonic scanner has a error message that states " place paper in feeder" There is paper in the scanner to be scanned. How do we get rid of this error???
This error occur for some reason, please check each one:
1; ADF document feeder is not closed really and
2; You are put the documents into a wrong place
3; the sensor of the ADR is wrong or is dirty (in this case you need a mechanic)
Please read carefully the ducument below (be care of page 23)
http://office.manualsonline.com/regman/exit/ct?url=aHR0cDovL3NlcnZpY2UudXMucGFuYXNvbmljLmNvbS9PUEVSTUFOUERGL0tWUzEwMjVDLlBERg,,&target=productDoc&idDeviceType=2727&idMfg=1569&idProduct=191533
Rgd,
Sly
Nov 22, 2010 | Panasonic KV-S1025C
Machine keeps jamming and pulling up a code E01-31. Also, the doc feeder will not work. Is there anyway to do some type of reset and see if it's just an internal computer error,etc?
This is due to feeder roller or paper out roller may having issues due to which paper got jammed frequently. Check all the rollers with help of expert engineer or from service center.
Revert back for more assistance.
Jan 26, 2010 | Panasonic Workio DP-3520 Copier
Feeder scanner stop after 1cm scan/fax
You need to clean the rollers inside the feed section, use an alcohol wipe.. or something like methylated spirits and a rag..
Oct 16, 2009 | Panasonic KX-FL611 Plain Paper Laser Fax
Jul 30, 2009 | Panasonic KV-S3065CL Path-Through Scanner
System error 39,012.40:49875
If after cycling the power to the machine and this problem still exists you may need to replace the ADF assembly. Here's a video that shows you how
Jun 26, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
ADF paper jam, when there is none
If you are receiving an Error Code 103 or a Paper Jam error, but there are no pages in the ADF (Automatic Document Feeder), follow the steps below:
  1. Close the scanning application (such as PaperPort)
  2. Turn off the scanner and the computer
  3. If you have a combination ADF with a Flatbed scanner, unplug the ADF cable from the base of the scanner
  4. Plug the ADF cable back in
  5. Turn on the scanner power
  6. Turn on the computer
  7. Try scanning again
For a Paper Jam or Error Code 103, make sure that the ADF cable in the rear is connected to the scanner base. Check the flatbed to make sure that it is clear. A page incorrectly placed on the flatbed may interfere with a page feeding through the ADF.
If your scanner stops scanning due to a paper jam in the Automatic Document Feeder (ADF), a warning dialog box appears after a few moments.
To clear a paper jam:
  1. Open the Automatic Document Feeder cover.
  2. Remove the jammed paper and close the cover.
If you are receiving a paper jam error, or if the scanner is running continuously, check to make sure the paper sensor arm is not stuck down.
  2. Look for the small black plastic arm
  3. When you press on this arm, it should move freely up and down
  4. If the arm is stuck down, please contact Technical Support for troubleshooting options
  5. Close the ADF cover.
May 26, 2009 | HP Scanjet 8350 Flatbed Scanner
Panasonic UF-490 - Two streaks down page
Either the glass is scratched or the sensor has gone bad that is used to scan the image.  Are you using a document feeder or laying it flat on the glass?  If you are laying it flat on the glass then it is most likely a sensor going bad.  If you are feeding it through the document feeder it could be that the feeder itself needs to be cleaned, or the paper path through the feeder.
If it is the sensor you will need to send it out for repair.  There may be an option to re-calibrate the scanner in the software, that may help if the sensor has just degraded and not failed.
I hope that helps.
May 02, 2009 | Panasonic PanaFax UF-490 All-In-One Laser...
Feeding photos into scanner
try different position and push down into feeder.
Feb 09, 2009 | HP LaserJet 3050 All-In-One Printer
446 people viewed this question
k24674
